Arduino Due resettet sich alle paar Tage 24. November 2019 10:05 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 480 |
ok 48577 > 13:25:05.839: T:244.62 /245 B:53.96 /54 B@:24 @:164 T0:244.62 /245 @0:164 T1:31.97 /0 @1:0 T2:53.96 /54 @2:19 > 13:25:06.387: ok 48578 < 13:25:06.387: N507331 M117 ETA 05:13:38 day 17 > 13:25:06.917: T:244.62 /245 B:53.96 /54 B@:24 @:164 T0:244.62 /245 @0:164 T1:31.97 /0 @1:0 T2:53.96 /54 @2:18 > 13:25:07.277: start > 13:25:07.277: Info: PowerUp > 13:25:07.277: Detected EEPROM version:20 > 13:25:07.277: XY jerk was too low, setting to 10.90 > 13:25:07.277: Z jerk was too low, setting to 0.34 > 13:25:07.277: Free RAM:81212 > 13:25:07.277: SelectExtruder:0 > 13:25:07.277: FlowMultiply:100 < 13:25:07.277: N0 M110 N0 < 13:25:07.277: N1 M999 ; In case we did not reset recover from fatal state < 13:25:07.277: N1 N1 M110 < 13:25:07.277: N2 M105 ; fetch first temperature > 13:25:07.277: ok < 13:25:07.277: N3 M115 ; Check firmware and capabilities > 13:25:07.277: ok 1 > 13:25:07.292: DebugLevel:6 > 13:25:07.292: info:Continue from fatal state > 13:25:07.292: ok > 13:25:07.292: ok 2 < 13:25:07.292: N4 M220 S100 ; set speed multiplier < 13:25:07.292: N5 M221 S100 ; set flow multiplier > 13:25:07.292: T:0.00 /0 B:0.00 /0 B@:0 @:0 T0:0.00 /0 @0:0 T1:0.00 /0 @1:0 T2:0.00 /0 @2:0 > 13:25:07.292: ok 3 < 13:25:07.292: N6 M355 ; get light status > 13:25:07.292: FIRMWARE_NAME:Repetier_1.0.4 COMPILED:Jul 3 2019 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:3 REPETIER_PROTOCOL:3 > 13:25:07.292: Cap: PROGRESS:0 > 13:25:07.292: Cap:AUTOREPORT_TEMP:1 > 13:25:07.292: Cap:HOST_RESCUE:1 > 13:25:07.292: Cap:EEPROM:1 > 13:25:07.308: Cap:AUTOLEVEL:0 > 13:25:07.308: Cap:Z_PROBE:0
Re: Arduino Due resettet sich alle paar Tage 24. November 2019 11:19 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 3.969 |
Re: Arduino Due resettet sich alle paar Tage 24. November 2019 12:36 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 556 |
Re: Arduino Due resettet sich alle paar Tage 24. November 2019 13:30 |
Peter1956
Arduino interner 5V Regler überlastet / defekt?
Spannung nach dem internen Regler messen / oszillographieren / mitschreiben.
Fridi
Sowas hatte ich auch mal.
Scheinbar macht der Arduino ein Reset. Macht er das auch, wenn Du nur von Karte druckst? Ist der Minus auch sternförmig verdrahtet. Ist das Gehäuse geerdet. Verbindung Minus zur Erde ausschließen. Mit Ohmmeter nachmessen. Starten von Leuchtstoffröhren und Motoren unterbinden.
Re: Arduino Due resettet sich alle paar Tage 24. November 2019 15:59 |
Re: Arduino Due resettet sich alle paar Tage 25. November 2019 00:09 |
Re: Arduino Due resettet sich alle paar Tage 25. November 2019 03:12 |
Administrator Registrierungsdatum: 16 Jahre zuvor Beiträge: 13.874 |
Re: Arduino Due resettet sich alle paar Tage 25. November 2019 12:46 |
Re: Arduino Due resettet sich alle paar Tage 26. November 2019 05:18 |
Registrierungsdatum: 5 Jahre zuvor Beiträge: 143 |
Re: Arduino Due resettet sich alle paar Tage 26. November 2019 15:56 |
Re: Arduino Due resettet sich alle paar Tage 26. November 2019 16:28 |
Re: Arduino Due resettet sich alle paar Tage 26. November 2019 16:44 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 337 |
Re: Arduino Due resettet sich alle paar Tage 28. November 2019 12:20 |
Re: Arduino Due resettet sich alle paar Tage 28. November 2019 14:55 |
Re: Arduino Due resettet sich alle paar Tage 28. November 2019 18:01 |
Fridi
Dann bau doch mal alles vom Bord ab und lass es so laufen. Dann nach und nach die Bauteile wieder anstecken.
Re: Arduino Due resettet sich alle paar Tage 29. November 2019 17:03 |
Re: Arduino Due resettet sich alle paar Tage 23. December 2019 13:29 |
start info: Power-Up info: Continue from fatal state
start info: Watchdog Reset
Re: Arduino Due resettet sich alle paar Tage 30. December 2019 06:57 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 201 |
Re: Arduino Due resettet sich alle paar Tage 30. December 2019 08:36 |
Inhumierer
2 Extrudermotoren?Quote
Legion 2.3
Womöglich hängt das Problem irgendwo hinter dem Extrudermotor. Am Treiber hängen parallel 2 Motoren.
Re: Arduino Due resettet sich alle paar Tage 01. January 2020 05:02 |
Re: Arduino Due resettet sich alle paar Tage 06. January 2020 11:30 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 1 |
Re: Arduino Due resettet sich alle paar Tage 06. January 2020 15:55 |
Re: Arduino Due resettet sich alle paar Tage 06. January 2020 16:05 |
Re: Arduino Due resettet sich alle paar Tage 24. December 2020 03:45 |
Re: Arduino Due resettet sich alle paar Tage 27. December 2020 20:01 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 100 |
Re: Arduino Due resettet sich alle paar Tage 28. December 2020 05:38 |
Registrierungsdatum: 7 Jahre zuvor Beiträge: 616 |
Also ich finde den Konfigurator perfekt(und ich habe keine Option ausgelassen), auch das Radds funktioniert mit den Raps128 normalerweise sehr gut. Was hat denn bei dir nicht funktioniert? Häufig ist das Problem vor dem Computer, aber natürlich bei weitem nicht immer.Quote
mw2matze
allerdings ist die Software so hart verbuggt und vor allem der Konfigurator!!! dass ich es einfach ausgebaut habe.
Re: Arduino Due resettet sich alle paar Tage 03. January 2021 11:52 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 46 |
Re: Arduino Due resettet sich alle paar Tage 03. January 2021 16:01 |
20:16:46.967 wait --> USB-Kabel gezogen-->USB-Kabel wieder eingesteckt 20:16:51.570 N18 M105 20:16:51.967: start 20:16:51.967: InfoowerUp 20:16:51.967: Detected EEPROM version:20 . . .
< 18:33:06.059: N1540884 G1 X170.590 Y272.590 E19.2989 > 18:33:06.074: ok 33552 < 18:33:06.074: N1540885 G1 X169.970 Y270.658 E19.3891 ---> Reset--> > 18:33:23.902: start > 18:33:23.902: InfoowerUp > 18:33:23.902: Detected EEPROM version:20 > 18:33:23.902: XY jerk was too low, setting to 14.08 > 18:33:23.902: Z jerk was too low, setting to 0.34 > 18:33:23.902: Free RAM:72252 > 18:33:23.917: SelectExtruder:0 > 18:33:23.917: FlowMultiply:100 > 18:33:23.917: Warning: Seems like we missed a ok - continue sending. > 18:33:23.917: wait > 18:33:23.917: Warning: Seems like we missed a ok - continue sending. > 18:33:23.917: wait < 18:33:23.917: N0 M110 N0 < 18:33:23.917: N1 M105 < 18:33:23.917: N2 M115 < 18:33:23.917: N3 M220 S100 < 18:33:23.917: N4 M221 S100 < 18:33:23.917: N5 M355 < 18:33:23.917: N6 G92 E0 < 18:33:23.917: N7 G90 < 18:33:23.917: N8 M82 < 18:33:23.917: N9 G21 < 18:33:23.917: N10 M114 < 18:33:23.917: N11 G90 > 18:33:23.917: ok > 18:33:23.917: ok 1 < 18:33:23.917: N12 M111 S6 > 18:33:23.917: T:217.87 /0 B:67.86 /0 B@:0 @:0 T0:217.87 /0 @0:0 T1:33.33 /0 @1:0 T2:46.47 /0 @2:0 > 18:33:23.917: ok 2 < 18:33:23.917: N13 M360 > 18:33:23.933: FIRMWARE_NAME:Repetier_1.0.4 COMPILED:May 30 2019 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:3 REPETIER_PROTOCOL:3 > 18:33:23.933: CapROGRESS:0 > 18:33:23.933: Cap:AUTOREPORT_TEMP:1 > 18:33:23.933: Cap:HOST_RESCUE:1 . . .
Re: Arduino Due resettet sich alle paar Tage 04. January 2021 04:44 |
Re: Arduino Due resettet sich alle paar Tage 04. January 2021 09:51 |
