bekomme Marlin, Bigtreetech pro und TMC2130 nicht zum laufen 25. March 2020 05:36 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.516 |
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\dev\\3dPrinting\\Firmware\\BIGTREETECH-SKR-PRO-V1.1\\firmware\\Marlin-bugfix-2.0.x SKR ProV1.1-Dmeo\\Marlin-2.0.xSKR ProV1.1-Demo\\.pio\\libdeps\\BIGTREE_SKR_PRO\\_tmp_installing-_y72_o1q-package\\U8glib-HAL-bugfix\\src\\clib\\HAL_example_files\\LCD_I2C_routines.c.example': File "C:\Users\XXXXX\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 156: env.SConscript("$BUILD_SCRIPT")
Re: bekomme Marlin, Bigtreetech pro und TMC2130 nicht zum laufen 26. March 2020 09:54 |
Registrierungsdatum: 5 Jahre zuvor Beiträge: 143 |
Re: bekomme Marlin, Bigtreetech pro und TMC2130 nicht zum laufen 27. March 2020 02:27 |
Re: bekomme Marlin, Bigtreetech pro und TMC2130 nicht zum laufen 02. April 2020 04:46 |
/** * Select the serial port on the board to use for communication with the host. * This allows the connection of wireless adapters (for instance) to non-default port pins. * Serial port -1 is the USB emulated serial port, if available. * Note: The first serial port (-1 or 0) will always be used by the Arduino bootloader. * * :[-1, 0, 1, 2, 3, 4, 5, 6, 7] */ #define SERIAL_PORT 1 /** * Select a secondary serial port on the board to use for communication with the host. * :[-1, 0, 1, 2, 3, 4, 5, 6, 7] */ #define SERIAL_PORT_2 -1 /** * This setting determines the communication speed of the printer. * * 250000 works in most cases, but you might try a lower speed if * you commonly experience drop-outs during host printing. * You may try up to 1000000 to speed up SD file transfer. * * :[2400, 9600, 19200, 38400, 57600, 115200, 250000, 500000, 1000000] */ #define BAUDRATE 250000
Re: bekomme Marlin, Bigtreetech pro und TMC2130 nicht zum laufen 02. April 2020 11:06 |
Registrierungsdatum: 3 Jahre zuvor Beiträge: 24 |
C:\dev\3dPrinting\Firmware\ BIGTREETECH-SKR-PRO-V1.1\firmware\Marlin-bugfix-2.0.x SKR ProV1.1-Dmeo\Marlin-2.0.xSKR ProV1.1-Demo\.pio\libdeps\BIGTREE_SKR_PRO\_tmp_installing-_y72_o1q-package\U8glib-HAL-bugfix\src\clib\HAL_example_files\LCD_I2C_routines.c.exampleDas fett läßt sich sicherlich verkleinern , oder ?
