Marlin+RADDS+TMC5160 kein Mucks 10. December 2020 11:40 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 46 |
Testing E connection... OK 00:00: E driver overtemperature warning! (800mA) E driver error detected: 0xBF800000 overtemperature coil short circuit E Enabled false Set current 800 RMS current 792 MAX current 1117 Run current 15/31 Hold current 7/31 Global scaler 133/256 CS actual 0/31 PWM scale 4162846720 vsense stealthChop false msteps 256 tstep 1006632960 PWM thresh. 8 [mm/s] - OT prewarn true triggered OTP true off time 0 blank time 16 hysteresis -end -3 -start 1 Stallguard thrs 0 uStep count 0 DRVSTATUS E sg_result 0 stallguard * fsactive stst olb * ola * s2gb * s2ga otpw * ot * Driver registers: E 0xEF:E0:00:00 Errorrinter halted. kill() called!
TCM5160 definition RADDS Pin SDI-------MOSI---------33 SCK-------SC-----------35 CSN-------CipSelect----31 ist default jedoch auch gesetzt SDO-------MISO---------37
#define E0_DRIVER_TYPE TMC5160
#if AXIS_IS_TMC(E0) #define E0_CURRENT 800 #define E0_MICROSTEPS 16 #define E0_RSENSE 0.075 #define E0_CHAIN_POS -1 #endif . #define E0_CS_PIN 31 . #define TMC_USE_SW_SPI #define TMC_SW_MOSI 33 //blau #define TMC_SW_MISO 37 //rot #define TMC_SW_SCK 35 //grün . #define SOFTWARE_DRIVER_ENABLE . #define CHOPPER_TIMING CHOPPER_DEFAULT_12V #define MONITOR_DRIVER_STATUS #define HYBRID_THRESHOLD #define TMC_DEBUG
Re: Marlin+RADDS+TMC5160 kein Mucks [gelöst] 10. December 2020 15:07 |
//#define SOFTWARE_DRIVER_ENABLEdarf nicht enabled sein
