Hallo,
Ich verkaufe dieses Hotend, es ist am 31.08.2013 von mir bestellt worden, aber seitdem nicht gebraucht. Es kann für 1.75 und 3.00 ausgerüstet werden und ist mit 0.5 mm und 0.4 mm Düse bestückbar, liegt alles bei.
Preis: VB
Liebe Grüße,
Ingo
Hier die Details:
It is based on the Budaschnozzle 1.1 design by Lulzbot, which is currently the BEST hotend on the market for RepRap 3D Printers (MendelMax, Prusa, Rostock) and the various 3D printers. The wood parts was replacement on special arcylic parts. Hole for heater was rebuild and we put a high quality ceramic heater (diameter 6mm/0,24inch), also was added the additional hole on the small hex screw which is used to stable mount heater.
Features:
- Aluminum Block Resistor Hotend
- Easily assembled and torn down without glue or ceramic
- Wire Strain Relief
- Includes machined aluminum and steel parts, and laser cut special arcylic parts
- Compatible with Wade's and Greg's accessible extruder and almost every available extruder/carriage
Specification:
- Size at longest parts: (H,W,L) 57mm, 40mm, 40mm / 2,24inch, 1,57inch, 1,57inch
- Aluminum heater block
- Machined aluminum heat block: 18.4mm x 25mm x 8.3mm / 0,72inch, 0,98inch, 0,33inch
- M10 x 1.0 internal thread
- Machined aluminum nozzle, M10 x 1.0 internal thread, 0.4mm/0,0157inch and 0,5mm/0,0196inch (both are included) orifice
- Thermistor temperature reading: EPCOS 100k
- Ceramic heating element: 40W/12-24V (Diameter: 6mm (0,24inch), Tube Lenght: 25mm (0.98inch)
- Aluminum and copper heatsink
- Black PEEK insulator
- PTFE inner sleeve
- Laser cut special acrylic plates
- For use with 3mm filament. 1.75mm filament can be used by changeing the inner PTFE tube (Included only 3mm PTFE tube)
- Machined stainless steel back-up plate
Kit includes:
- Heater Block
- Nozzle (0,4mm/0,0157inch and 0,5mm/0,0196inch)
- Black Peek Isolator
- Aluminum extension
- Upper Plate
- Lower Plate
- Backup Plate
- Copper Heatsink
- Budaschnozzle Mount
- Ceramic Heater (40W/12-24V) with 1meter length cable
- EPCOS 100k thermistor with 1meter length cable (40')
- Fan Cooler (for cooling upper part of hotend for PLA printing) - 10cm of white plumbing tape (for secure threading in case if you want to printing using PLA which is more liquify) - screws, washers, spacers set
Budaschnozzle HotEnd
