Löcher in der Oberfläche 17. August 2015 14:35 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 73 |
# generated by Slic3r 1.2.9 on Mon Aug 17 20:32:57 2015 avoid_crossing_perimeters = 1 bed_shape = 0x0,220x0,220x220,0x220 bed_temperature = 60 before_layer_gcode = bottom_solid_layers = 3 bridge_acceleration = 1800 bridge_fan_speed = 100 bridge_flow_ratio = 0.98 bridge_speed = 40 brim_width = 0 complete_objects = 0 cooling = 1 default_acceleration = 1000 disable_fan_first_layers = 1 dont_support_bridges = 1 duplicate_distance = 6 end_gcode = M104 S0 ; turn off temperature\nM140 S0 ; turn off heatbed\nG91 \n G1 E-10 F1800\n G1 Z5 F100 \n G90 \nG28 X0 Y0 ; home X Y axis\nM84 ; disable motors external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0 external_perimeter_speed = 65% external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extruder_offset = 0x0,0x0,0x0 extrusion_axis = E extrusion_multiplier = 1 extrusion_width = 0 fan_always_on = 0 fan_below_layer_time = 60 filament_colour = #FFFFFF filament_diameter = 1.74 fill_angle = 45 fill_density = 20% fill_pattern = rectilinear first_layer_acceleration = 0 first_layer_bed_temperature = 65 first_layer_extrusion_width = 200% first_layer_height = 0.25 first_layer_speed = 60% first_layer_temperature = 215 gap_fill_speed = 20 gcode_arcs = 0 gcode_comments = 0 gcode_flavor = reprap infill_acceleration = 600 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 15% infill_speed = 50 interface_shells = 0 layer_gcode = layer_height = 0.2 max_fan_speed = 100 max_print_speed = 80 max_volumetric_speed = 0 min_fan_speed = 90 min_print_speed = 10 min_skirt_length = 25 notes = nozzle_diameter = 0.4,0.4,0.4 octoprint_apikey = octoprint_host = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 1 perimeter_acceleration = 50 perimeter_extruder = 1 perimeter_extrusion_width = 0 perimeter_speed = 40 perimeters = 2 post_process = pressure_advance = 0 raft_layers = 0 resolution = 0 retract_before_travel = 2,2,2 retract_layer_change = 0,0,0 retract_length = 5,4.5,4.5 retract_length_toolchange = 10,10,10 retract_lift = 0,0,0 retract_restart_extra = 0,0,0 retract_restart_extra_toolchange = 0,0,0 retract_speed = 50,30,30 seam_position = aligned skirt_distance = 10 skirt_height = 1 skirts = 2 slowdown_below_layer_time = 15 small_perimeter_speed = 30 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0 solid_infill_speed = 50 spiral_vase = 0 standby_temperature_delta = -5 start_gcode = G28 home all axes\n\n\n\n support_material = 0 support_material_angle = 0 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = honeycomb support_material_spacing = 2.5 support_material_speed = 50 support_material_threshold = 0 temperature = 210 thin_walls = 1 threads = 2 toolchange_gcode = top_infill_extrusion_width = 100% top_solid_infill_speed = 40 top_solid_layers = 3 travel_speed = 100 use_firmware_retraction = 0 use_relative_e_distances = 0 use_volumetric_e = 0 vibration_limit = 0 wipe = 1,1,1 xy_size_compensation = 0 z_offset = -0.26
Re: Löcher in der Oberfläche 17. August 2015 15:02 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Löcher in der Oberfläche 17. August 2015 16:42 |
Re: Löcher in der Oberfläche 18. August 2015 00:34 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 176 |
Re: Löcher in der Oberfläche 18. August 2015 00:36 |
Re: Löcher in der Oberfläche 18. August 2015 01:24 |
Re: Löcher in der Oberfläche 18. August 2015 04:42 |
Re: Löcher in der Oberfläche 18. August 2015 07:47 |
Re: Löcher in der Oberfläche 18. August 2015 11:14 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 3.385 |
Wurstnase
Ich konnte die Fehler die andere haben nicht nachvollziehen. Ich habe als default meinen Düsendurchmesser und den ersten Layer ~1.2*Düsendurchmesser dort eingestellt und bei mir passt das alles. Soweit ich das bisher bei den anderen gesehen habe, tritt dieser Fehler wohl auch nur bei mehr als 2 Perimetern auf.
Re: Löcher in der Oberfläche 18. August 2015 16:39 |
Re: Löcher in der Oberfläche 18. August 2015 16:58 |
