i3 CNC routed Aluminium frames, i3 Plastic Kits, i3 Assembled printers
Posted by Shannon-create3D
June 09, 2013 05:29AM
Plastic Parts printed with 100% infill and in ABS (from current git)
304 stainless smooth rods and 304 stainless and zinc for the threaded rods
(Includes 10mm smooth and threaded rod on the Y axis)
Rattn Stepper motors and mechanical endstops
Hex head bolts
3mm Magma hotend .4Ø 24V heat cartridge and thermistor
Prusa MK2B Dual Power Hotbed and thermistor
Borosilicate glass
Aluminum Y carriage
8 LM8UU Bearings
3 LM10UU Bearings
3x 608 Bearings
4x 624 Bearings
2x GT2 20 groove Pulleys and belts
RAMPS 1.4, Taurino power (Improved Arduino Mega2560R3)
Kliments 8825 drivers, SDcard reader and Ceramic screwdriver
Hyena Hobbed Bolt
Wiring harness
Frame made using DIBOND® aluminium composite panel
Print area 200x200x170+/-
Control board flashed with Marlin firmware and is ready to run all you need is a 24V power supply like this [www.ebay.com]
High quality sturdy printers which use only the best components and wired using twisted pair motors wires, high current wires for the heatbed and secured to the frame. These are capable of printing in PLA, ABS and Nylon to name just a few thermoplastics.
Assembled Printers $1100 - Shipped within Australia between $60 - $100,
Frames includes nuts, bolts and washers $130 - Shipped within Australia between $20 - $35,
I3 Plastic kits $60 - Shipped within Australia $15 (Note: these are ABS kits not PLA)
More images can be found at [imgur.com]
More information can be found at [www.create3d.com.au] - Site is currently being rebuilt and atm has no information about i3's.
PM me for details
