Just some info regarding the ALU frames.
They are 6mm aluminium water jet cut. They have been slightly improved over original.
Such as square holes for Z-Motor cable plugs to fit through frame, Hole to accomodate Z-Endstop cable.
Electronics are mounted on a separate plate. This so you do not have to drill the frame if your electronics do not match the holes in the frame.
You can also make/print your own plate this way. The left side has been slightly widened as the original does not cover/hide the electronics if you enclose them in a box etc.(See photos of my first i3 on my blog)
There are some extra holes for future addons.
10mm threded rod on y-frame (this is a must to make it rigid)
(I supply mainly in SA but can post to other states. (E-mail me for freight info)
Regards
Jan
Edited 1 time(s). Last edit at 07/24/2013 05:57AM by IceMan.
3dprinting4u.wordpress.com]
