we use 1 /16 mirco stepping , lcd display , sd card support
and our printring area is bigger than all other printers its come with 250 mm * 250 mm * 200 mm for 800 $ with 6 months minum warranty for full machineray parts
and also we are providing the 1 kg of pla or abs or polyprolene and shipping charges extra.
* now our machine can go with 3 materials ( we are manufacturing silicon rubber and hdpe as 1.75 mm & 3 mm dia ) once the complete R &D finish then you can also printing in any material from the pla , abs , pp , silicon ruber , hdpe and etc with using same nozzle and extruder .
note for multi material extruder you cant print in the size of 200mm * 200 mm * 200mm and for normal extruder you can only go with abs and pla with 250 mm * 250 mm * 200 mm ( if you want we can also make 300 mm and 500 mm bigger machines ) www.cad3dprint.com
youtu.be]
call to +91- 9043003838
www.cad3dprint.com]
