How to stop convex overhangs curling up? February 05, 2012 06:31PM |
Re: How to stop convex overhangs curling up? February 10, 2012 04:03PM |
Re: How to stop convex overhangs curling up? February 11, 2012 04:07PM |
Re: How to stop convex overhangs curling up? February 11, 2012 04:56PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: How to stop convex overhangs curling up? February 18, 2012 05:31PM |
Re: How to stop convex overhangs curling up? February 18, 2012 05:58PM |
Re: How to stop convex overhangs curling up? February 21, 2012 09:46AM |
Re: How to stop convex overhangs curling up? February 21, 2012 10:15AM |
Re: How to stop convex overhangs curling up? February 21, 2012 11:20AM |
Re: How to stop convex overhangs curling up? February 25, 2012 08:05PM |
Re: How to stop convex overhangs curling up? March 21, 2012 02:45PM |
Re: How to stop convex overhangs curling up? March 23, 2012 01:55PM |
Re: How to stop convex overhangs curling up? May 30, 2012 07:57PM |
Re: How to stop convex overhangs curling up? June 01, 2012 03:46PM |
Re: How to stop convex overhangs curling up? August 01, 2014 12:59AM |
nophead
Yes the height doesn't affect the stretching if you keep the width constant because lower heights get proportionally lower flow. It is the width that counts. SF is better than SFACT and I think Slice3r because it relates the width to the height. If W/T is constant then thinner layers does stretch it more.
0.35 width is very thin for ABS and a 0.35 nozzle. If you measure the plastic extruded into free air it will be substantially bigger diameter than the nozzle, maybe 0.45. That is before you squash it flat by having the layer height lower than the width.
Typically I would use 0.30 layers with a 0.35 nozzle with W/T of 1.5 giving a width of 0.45. Or 0.35 layers giving 0.525 for even less stretch. The most stretch I would use would be 0.25 layers with a width of 0.375, still more than yours. For lower layer heights I would increase W/T, so W would never be less than 0.375.
Re: How to stop convex overhangs curling up? August 03, 2014 06:45PM |
