To start with it was the first 2 or 3 layers then slip, print upto the last 2 or 3 layers then slip.
After adjusting the current it removed the slip on the last 2 or 3 layers.
I think I've solved the issue, but I'll run some more prints tonight then update this post with the fix/cause just incase anyone is having the same issue.
UPDATE
It was the large washer holding the X belt, after updating to a larger (self printed
) washer it solved the issue. The first print I did jumped but that was only the belt finding its place.
Edited 1 time(s). Last edit at 02/16/2012 03:46PM by JoeDaStudd.
My Reprap blog
jds-reprap.blogspot.com
