problam printing small things
Posted by moroz.a24
March 29, 2012 06:34AM
hey
i have a big problam with printing small things.
evry time that i print small things i get distortions in the print.
its looks like the plastic dont have time to cool down and solidify.
it happens with part no biger then 20mm*20mm.
plz hellp
Re: problam printing small things
March 29, 2012 06:48AM
That's normal. You can use some solutions (possibly mixed) :
- print slower.
- print multiple small objects together.
- use a fan to help the object cool down faster.
March 29, 2012 06:56AM
i tride it alredy and it didint work.
i have a fan pointed to the nuzzel to cool the object and its still not working
March 29, 2012 07:14AM
Can we haz picturez ?
March 29, 2012 07:57AM
I can print tiny things like this: [www.thingiverse.com] simply by making the minimum layer time 20 seconds, no fan.
March 29, 2012 08:00AM
i use slic3r 7.1 i dont have this option!
March 29, 2012 08:17AM
You do. See the "cooling" tab, change the "Slow down if layer print time is below" option.
March 29, 2012 08:39AM
pic1
pic2
Edited 1 time(s). Last edit at 03/29/2012 08:40AM by moroz.a24.
March 29, 2012 09:03AM
Looks like your are using a 0.35 nozzle, right ?
Could you please let us know what are :
- you layer height (seems quite thin).
- the plastic you use (kind seems to be PLA, what is the vendor).
- your print speeds.
- the extrusion temperature (and did you verify the actual nozzle temperature with a thermometer to rule out temperature reading errors).
It's possible you're going too fast / too hot.
Other optional informations which could help people diagnose your problem :
- Electronics
- Firmware
- Hotend
- Extruder (and wether it is a bowden setup or not).
