Heatbed turns off when press printing.
Posted by Nimal
May 20, 2012 07:18AM
Dear Guys,-
I have a Huxley printer and it prints fine, but when I press print in pronterface it takes a while before the printing starts and the heatbed turns off and the heater temperature is only measured. When it then begins printing the heatbed temperature is available but I need to set the heatbed again since it is turned off.
Does anyone have a suggestion?
/Nimal
Re: Heatbed turns off when press printing.
May 20, 2012 09:33AM
What are you using to slice your files? if using slicer and you have compatable heat bed control, you can set the heat bed temp when you slice the model.
Ryan
Quality Engineer & Hobbyist
thingsandtrains.blogspot.com
May 20, 2012 10:55AM
Hi Ryan,-
I am using Skeinforge. When you write "if using slicer" do you mean slic3r?
/Nimal
May 20, 2012 03:55PM
Yeah i mean slic3r, and i dont know anything about skeinforge, maybe someone else has some ideas?
Ryan
