I use Parametric Better Coin Calibrator (http://www.thingiverse.com/thing:11270)
Pls see attached image for size measurement.
The problem is when i use value of coin hole (23.95mm) to calibrate both X and Y. After insert new value, i got coin hole almost 23.95mm but the edge (47.90mm) is exceeded 1-2 mm. So, i try again using value of Edge to calibrate (47.90mm). After calibrate i got edge value calibrated but Coin hole short by 1 mm (Coin can't insert).
What i need to do to get calibrated both Edge (47.9mm) and Coin Hole (23.95mm)?
I'm using Mendel with Marlin 1.0 (Slic3r 0.72b) setting as below
- Machine : Mendel
- Firmware : Marlin 1.0
- Extruder : J-Head 0.5mm
- Program : Slic3r 0.72b (Setting below)
; layer_height = 0.3
; perimeters = 1
; solid_layers = 1
; fill_density = 1
; nozzle_diameter = 0.5
; filament_diameter = 2.9
; extrusion_multiplier = 1
; perimeter_speed = 30
; infill_speed = 60
; travel_speed = 130
; extrusion_width_ratio = 0
; scale = 1
; single wall width = 0.70mm
