Print pauses momentarily... causing small blobs on perimeter...
Posted by verohomie
August 14, 2012 04:46PM
Hi All -
During perimeter printing, the print head is pausing momentarily. As a result, little blobs are forming in the perimeter. This only happens in curves. It is like the Arduino can't keep up. I have a MendelMax 15+ and I am using Slic3r 0.9.0 with Maxbot's Marlin ZIP. The source file is from Alibre PE.
Any ideas appreciated.
TIA - Brad
PRINT SPEED
Perimeters 80mm/sec
Small perimeters 60mm/sec
External perimeters 100%
Infill : 80mm/sec
Solid Infill 80mm/sec
Top solid infill 60mm/sec
Bridges: 60mm/sec
Travel: 130mm/sec
First layer speed ratio: 50%
PRINT SETTINGS
Perimeters: 3
Solid Layers: 3
Fill DensityL: 0.5
Fill Pattern: Rectilinear
Solid Fill Pattern: Rectilinear
Randlmize Tsarting Points *YES!*
Generate Support Material *NO!*
RETRACTION
Length 1mm
Lift Z: 0
Speed: 30mm/s
Extra Length on Restart: 0mm
Minimum Travel after Restart: 2
Re: Print pauses momentarily... causing small blobs on perimeter...
August 14, 2012 06:28PM
This can happen on curves with a lot of segments when printing over USB.
What serial speed is your firmware set to?
Are you seeing comms errors?
The only real solution is to print from SDCard.
August 14, 2012 06:46PM
Polygonhell -
USB set to 115200. I will try 250000 in Marlin.
Correct me if I am wrong... I can't us SDCard when using 24v power? I think it required D1 diode.
- Brad
August 14, 2012 07:23PM
Yes should be able to use it with the USB still plugged in. The diode is needed to run it stand alone.
