I found that i must ask for one (maybe more) basic question.
I have nozzle of 0,5mm
In Skeinforge when I set layer height to 0,3 and Edge Width over Height to 2,2 i get 0,66mm wide extruded thread. (0,3 * 2,2 = 0,66) correct?
If so, then when i print [
reprap.org] object from layer height step, i must get wall with width of 0,66mm?
when i get different, what is better to change, because i was told that flow rate and feed rate must be same...
Thanks for reply
vlastni navrh plus ve vystavbe CoreXY
Thingiverse : [www.thingiverse.com]
git: [github.com]
shop: [shop.daje.cz]
Teorie relativity:
vysvetleni 1: sahnes-li na rozpalenou panev, vteriny jsou jak hodiny. sahnes-li na rozpalenou zenu, hodiny jsou jak vteriny...
vysvetleni 2: strcis-li mi nos do zadnice, pak ja mam nos v zadku, ty mas nos v zadku, ale ja sem na tom relativne lip
