Hole, inside and outside dimensions wrong
Posted by MotoBarsteward
June 27, 2012 03:27AM
I've sent an email to the guys who look after Slic3r but I thought I'd better post here as well so I can post their response incase others are having the same problem as me.
The Problem. I have an ABSPrusa Mendel that I have had up and running for several weeks and it's print quality is excellent. I have one niggling problem left to address though.
When I print things, they come out the wrong size. This is not a scaling or axis calibration issue because the parts are all out by the same amount. Holes are 0.25 mm too small and outside dimensions are about 0.25mm too big. This is normally ok but is a real problem when parts ar specifically designed to give a tight fit, i.e captured nuts and bolts, holes for screws.
I think I've followed the correct calibration procedure.
1. Calibrate the extruder so that when told to extrude 30mm of stock, 30mm gets extruded. Measure the diameter of the stock.
2. Print the perimeter test piece: -Peg and hole test. Parts did not fit together Peg = 10.12mm, hole = 9.6mm
3. Print thin wall test: - Thin Wall Wall came out 0.55mm so set Filament multiplier to 0.76 (0.42 / 0.55)
4. Ran thin wall test and it came out at 0.42 mm which is correct for my 0.4 mm J Head Mk IVb for a 0.3mm layer
5. Ran perimeter test again. This time was better at peg = 10.14mm and hole = 9.77mm but still not right. Parts are also more brittle and top layer does not fill properly.
What am I doing wrong? 0.76 sounds like a big adjustment for the Filament Multiplier and I think it's had an adverse effect on my print quality. I don't know if my printer is producing extrusions wider than it should or if Slic3r is making some kind of mistake in calculating flow rates.
Using ABSPrusa Mendel Zaphod with Pronterface and slic3r 1.3.0. Printing well with 3mm PLA and ABS through 2 x J Head Mk IV b and Wade Geared Exruders. Controlled using RAMPS1.4 board running Marlin_v1.1.9
Re: Hole, inside and outside dimensions wrong
June 27, 2012 11:48PM
It sounds like it is your multiplier and the reason the layer adhesion is weak is because the 0.3 layer height is to high for a 0.4 nozzle. Try a layer height of 0.25
Edited 1 time(s). Last edit at 06/28/2012 01:46PM by Sublime.
June 28, 2012 02:44AM
So, are you suggesting that I keep everything as it is but go for a 0.25mm layer height i.e. the Filament multiplier should be 0.76? Or, go through my calibration procedure again but use a layer height of 0.25?
> reason the layer adhesion is week is because the
June 28, 2012 07:41AM
OK, time to move over the Skeinforge as I'm not getting anywhere with Slic3r as this does appear to be an issue that has already been discussed by several sages in Reprap with no successful conclusion.
I have an ABSPrusa Mendel with a 0.4 J Head Mk IVb head and I'm extruding 3mm PLA. The machine was bought in its entirety from thereprapkitstore.co.uk. If there is anyone out there using such a machine with Skeinforge, can you please let me have your config files so that I can state experimenting? Either zip and post them here or IM me.
Thanks in advance.
June 30, 2012 08:02AM
Hmmm,
I've just printed a peg and hole combination and they do seem a little out! I think we will have to wait for an update to slic3r and see if this addresses the problem.
How you getting on with Skeinforge? I might have to try that also!
Keukpa
July 03, 2012 12:29AM
welcome to FDM printing.
this is a universal problem for all machines that do not have some type of software correction.
The important dimensions are your OUTER dimensions. The reason holes come out smaller than designed is that the extrusion is pulled toward the centre of a hole by the nozzle while it is printed.
ways around this:
design a test piece with the desired hole and modify the hole diameter until it fits what you want it to fit
use skeinforge stretch and tune it until you get proper results
or the best solution in my opinion, check out nophead's polyholes. read his blog and find out why this is happening and his simple and universal solution. Then, help write a script for skeinforge so that all holes are converted into polyholes and come out the proper size.
July 03, 2012 06:08AM
Thanks for your response. I fully understand that I have built a machine for very little money that runs using free software and that my expectations of accuracy are adjusted accordingly. I realise that fdm, as a process, has fundamental limitations in accuracy. What I am trying to point out in this post and the issue raised in GitHub for slic3r is that the Gcode files generated by 084 also throws away potential accuracy because it is making a mistake in calculating the external perimeter. The path it chooses does not take into account some or most of the filament width. All solutions that I've tried up to now just work on reducing the filament widt. While helping reduce the size of the problem, they will not get rid of it until slic3r is fixed.
> printed.
> ways around this:
> want it to fit
> proper results
July 03, 2012 02:25PM
Looks like there was a bug and it has been fixed and will be available in the next release.
Edited 1 time(s). Last edit at 07/03/2012 03:23PM by Sublime.
July 04, 2012 04:40PM
I have just built my own Slic3r Dev0.8.5 from the master and verified that the issue is fixed. Well done and thankyou
July 04, 2012 06:34PM
Can you share the fix here? I think I have the same problem.
Thank you
Ernesto Pareja
dcctrains.netne.net
July 04, 2012 06:49PM
You have two choices:-
1. Wait until 0.8.5 is released.
2. Follow the relevant instructions here to get and build the latest master.
I did 2.
I don't know when they will release 0.8.5
> same problem.
> Thank you
