printing only perimeter (no infill)
Posted by ntar827
July 23, 2014 12:16PM
I assume that my problem is with Slicr3.
Prints first 2 or 3 layers completely then starts to print perimeter with no infill.
Tried regenerating the STL file and reslicing but same problem.
Funny thing is that it worked well on a part of almost identical sie and shape.
Any ideas?
Nick
Re: printing only perimeter (no infill)
July 24, 2014 01:12PM
Um, did you double check your settings so infill is enabled usually lower than 15% will barely fill most areas. and make sure that you selected those settings to slice.
July 27, 2014 09:08PM
Have you recently upgraded your version of Slic3r? The latest version only infills as required (if that checkbox is ticked). The first time I used it, I went back to my source file to see why my object was so hollow before realising it was the new Slic3r. I like the new setting - much less plastic means much faster prints.
July 31, 2014 05:48AM
I managed to print without infill, only because I used a comma instead of a period when setting the percentage... Slicer would recognice it as 0 instead of 0.5. Might be that smiling smiley
