Periodic error ?
Posted by Walther
Periodic error ?
August 17, 2014 05:44AM
What could be the cause of this periodic error, most visible in the yellow print, but also present in the blue ?
Thank you,
[Mendelmax 1.5]
Re: Periodic error ?
August 17, 2014 08:15AM
I think that is what is often referred to as z wobble, I had that happening and in my case it was due to backlash and generally things not being tight and stable
August 18, 2014 03:29AM
Thank you,
That was the keyword I needed for further investigation.
Some oil on the Z-axis helped a bit, but I still need a bit more adjustments.
Thx,
August 18, 2014 08:22AM
It can be a problem with your layerheight and your z-axis pitch.
Take a look at this.Taxonomy of Z axis artifacts in extrusion-based 3d printing
Edited 1 time(s). Last edit at 08/18/2014 09:03AM by gforce1.
August 18, 2014 08:40AM
What a wonderful piece of documentation !
Thank you,
