Hi Everyone
I build a Printrbot from the files on Thingiverse, and run it from a Generation 7 version 1.4, with Teacup firmware and Pronterface.
You can read more details on my build here:
www.itux.co.za]
www.itux.co.za]
www.itux.co.za]
Now the issue I am having is that my printed parts have the following issues:
1. Even though the calibration cubes print with perfect exterior sizes, my interior sizes of all holes printed in the flat plane come out too small. i.e. X-Y movement. Holes printed in the sides of objects, come out fine.
I have done a lot of checks and my X/Y/Z calibration is not out by more than 0.1 - 0.2mm
The only theory I have is that I am extruding too wide and therefore the object is actually about half a extrution too narrow, and the width of the extrusion makes up the difference? This would also explain why holes are too small, as the extrution actually expans into the blank space where the hole should be. This is the biggest problem as for example in the print below, the linear bearings and m8 nuts doesnt fit in the holes.
2. I have precisely measured my filament feed with the straw and marker method. The 100% solid cube calibration test is perfect. However, ever here and there layers my nozzle stops extruding for a few mm.s This is fine on infill, but it messes up the exterior shells of my prints: Samples of print quality: [
www.itux.co.za]. I Print PLA at 185 degrees - works perfect for Bridges so don't want to heat much higher, and I would expect temp issues to be more of a problem with no extrution followed by a blob...
3. Suspect belt tension:
www.itux.co.za] - case in point - the exterior has random little bumps or it seems like the layers didnt stack exactly on top of each other. Could this be belt tension, or other issues with the Printed XL pulleys? Would it be worthwhile to upgrade to a proper XL pulleys bough from say RS-Online?
4. Stringing... a little bit of stringing, so might need to tweak retraction in Slic3r? [
www.itux.co.za]
General print quality: Everyone with a bit more experience, just looking at my print above, can you see anything else I might be doing wrong?
Print speeds? Too fast, too slow?
Here's a paste of my Slic3r profile:
acceleration = 0
bed_size = 200,200
bed_temperature = 0
bottom_layer_speed_ratio = 0.3
bridge_fan_speed = 100
bridge_flow_ratio = 1
bridge_speed = 60
complete_objects = 0
cooling = 0
disable_fan_first_layers = 1
duplicate = 1
duplicate_distance = 6
duplicate_grid = 1,1
end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors
extruder_clearance_height = 20
extruder_clearance_radius = 20
extrusion_axis = E
extrusion_multiplier = 1.1
extrusion_width_ratio = 1.67
fan_always_on = 0
fan_below_layer_time = 60
filament_diameter = 3
fill_angle = 45
fill_density = 0.8
fill_pattern = rectilinear
first_layer_bed_temperature = 0
first_layer_height_ratio = 1
first_layer_temperature = 190
g0 = 0
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = teacup
infill_acceleration = 50
infill_every_layers = 1
infill_speed = 60
layer_gcode =
layer_height = 0.30
max_fan_speed = 100
min_fan_speed = 35
min_print_speed = 10
notes =
nozzle_diameter = 0.5
output_filename_format = [input_filename_base].gcode
perimeter_acceleration = 25
perimeter_speed = 30
perimeters = 3
post_process =
print_center = 75,75
randomize_start = 1
retract_before_travel = 2
retract_length = 2
retract_lift = 0
retract_restart_extra = 0
retract_speed = 30
rotate = 0
scale = 1
skirt_distance = 6
skirt_height = 1
skirts = 2
slowdown_below_layer_time = 15
small_perimeter_speed = 30
solid_fill_pattern = rectilinear
solid_infill_speed = 60
solid_layers = 2
start_gcode = \nG28
support_material = 0
support_material_tool = 0
temperature = 188
threads = 2
travel_speed = 130
use_relative_e_distances = 0
z_offset = 0
Hoping you could help me, as I need to print some parts for a few bud's
Peter
