Slic3r Help?
Posted by stealthocelot
Slic3r Help?
January 23, 2015 05:21PM
Hi, I think I am having problems with Slic3r... Included .gcode files on SD print just fine but imported models (Survival Knife & Phone Case) Are not printing correctly. The imported models are .gcode & I used the Slic3r-Settings Folder in the profiles folder of Slic3r... Thanks for reading... -StealthOcelot
(I'm using an Ormerod 2 with pronterface)
Edited 1 time(s). Last edit at 01/23/2015 05:44PM by stealthocelot.
Re: Slic3r Help?
January 24, 2015 12:28AM
gcode files will be a bit different for every machine. That is why you need slicer and a proper .ini file (prefs) for your machine. Since you did not provide any other info can't really tell you more.
Re: Slic3r Help?
January 24, 2015 09:45AM
Hi, sorry about that, Well anyway I uploaded the right .ini files (in slic3r-settings)
and prints sort of duplicate themselves on the second layer, slightly beside where it started. I have checked the model & that should not happen.
thanks
