Bad Print Quality April 17, 2015 12:08PM |
Re: Bad Print Quality April 17, 2015 12:29PM |
Re: Bad Print Quality April 17, 2015 12:33PM |
Re: Bad Print Quality April 17, 2015 01:14PM |
Re: Bad Print Quality April 17, 2015 01:25PM |
Re: Bad Print Quality April 17, 2015 02:53PM |
imqqmi
What temperature settings are you using, does increasing, lowering change anything? Speed settings, what slicer, what nozzle size, PLA or ABS.
Did you do the calibration on this page: http://reprap.org/wiki/Triffid_Hunter%27s_Calibration_Guide?
Is the e steps calibrated? Seems like some under extrusion but until the printer is fully calibrated it could be a lot other things. It could also be mechanical issues and slicing issues.
Re: Bad Print Quality April 17, 2015 03:13PM |
Re: Bad Print Quality April 17, 2015 03:15PM |
Re: Bad Print Quality April 17, 2015 04:55PM |
Re: Bad Print Quality April 20, 2015 10:03PM |
Re: Bad Print Quality April 20, 2015 11:46PM |
Re: Bad Print Quality April 21, 2015 11:54AM |
ggherbaz
Check your belts and pulleys, something it's still loose. You might be over extruding some, if you calibrated your extruder steps then adjust some your feedrate or extrusion multiplier.
Re: Bad Print Quality April 21, 2015 02:58PM |
Re: Bad Print Quality April 21, 2015 03:13PM |
Re: Bad Print Quality April 21, 2015 03:19PM |
Re: Bad Print Quality April 21, 2015 07:07PM |
Re: Bad Print Quality April 21, 2015 07:40PM |
Re: Bad Print Quality April 21, 2015 07:49PM |
Re: Bad Print Quality April 22, 2015 09:51AM |
JamesK
Ah, you mean the position of the print head started skipping, not the movement of filament through the extruder?
Re: Bad Print Quality April 22, 2015 01:15PM |
Re: Bad Print Quality April 22, 2015 01:17PM |
Re: Bad Print Quality April 22, 2015 01:59PM |
ggherbaz
Two things comes to my mind, first did you calibrate first your nozzle to bed at 0.1mm ? If you didn't when you set your first layer at 0.24 your nozzle might be too high, second is your threaded rod capable of that layer height? Have you checked which layer heights it can support?.
Re: Bad Print Quality April 22, 2015 09:26PM |
Re: Bad Print Quality April 23, 2015 02:44PM |
ggherbaz
That's fine, although I will recommend you to get a feeler gauge and use the 0.1 blade.
Did you checked your threaded rod for best layer selection?
What speed are you using for first layer? that might impact adhesion.
Also, now that I am at home and can see better the pictures, there is 2 things you need to adjust to get better prints. The first one is to increase your retraction settings so those blobs in the corners will disappear, second is to play with extrusion width and extrusion multiplier.
Extrusion Width: is the thickness of your extruded filament, if you print at 0.1mm layer height you can use same size as nozzle e.g 0.4, as you increase your layer height you need to increase the thickness of your extruded filament so layer 0.2 nozzle 0.42-0.44 layer 0.3 nozzle 0.44-0.46.
Extrusion Multiplier: is the multiplication factor that the slicer will use to each extrusion, this depends a lot on materials. I have found that PLA prints best at 1 while ABS is best at 0.9.
Re: Bad Print Quality April 24, 2015 12:10PM |
