X/Y/Z Movement stops after 4-6 minutes of printing [SOLVED] May 19, 2015 01:22PM |
Re: X/Y/Z Movement stops after 4-6 minutes of printing May 19, 2015 01:48PM |
Re: X/Y/Z Movement stops after 4-6 minutes of printing May 19, 2015 03:03PM |
Re: X/Y/Z Movement stops after 4-6 minutes of printing May 19, 2015 03:45PM |
Re: X/Y/Z Movement stops after 4-6 minutes of printing May 19, 2015 04:13PM |
He mentions that when the problem occurs, the hot end "disengages", as well as when he switches the hotend off the motors begin to move again although slower. Both sound like symptoms of a polyfuse somewhere in the midst of tripping and restricting the amount of power available. Enough is making it through that the electronics don't reset and still try to operate, but not enough for the hot end to really heat up. And when the hot end gets shut off, what power was being drained in an attempt to heat can get used to move the motors a little more.Quote
dc42
Something is overheating, probably the stepper motor drivers. Try reducing the motor currents, or aiming a fan at the drivers, or using better drivers.
Re: X/Y/Z Movement stops after 4-6 minutes of printing May 19, 2015 04:42PM |
cdru
He mentions that when the problem occurs, the hot end "disengages", as well as when he switches the hotend off the motors begin to move again although slower. Both sound like symptoms of a polyfuse somewhere in the midst of tripping and restricting the amount of power available.Quote
dc42
Re: X/Y/Z Movement stops after 4-6 minutes of printing [SOLVED] May 19, 2015 04:54PM |
