Hey guys. So I just built my first Prusa i3. Everything is working except for the X-Axis endstop. The physical switch itself works when I plug it into the Y or Z endstop pins on the RAMPS board for testing. The other switches do not work on the X-Axis pins on the RAMPS board though. So my first thought (an obvious wrong one) was that the RAMPS board or MEGA had a bad I/O pin. I swapped both out and the same issue persists. So it's obviously a software issue. I did try a fresh Marlin firmware, but no change. I'm asking for one of your ultra-reprap-wizards to give me any clue as to maybe what section of the firmware code to check to confirm that endstop is being recognized. This issue has been going on for over 1 month while I waited for replacement parts to come in to try and fix it. I'd just like to be able to use the printer....
Any help would be greatly appreciated!!
Thanks in advance,
Mike
UPDATE: 6/12/15: So I was messing around with a variety of the X-Axis Inverter/Endstop settings. It works when I have the endstop home set to '1', but not '-1'. Shouldn't home be the left front corner of the bed?
Edited 1 time(s). Last edit at 06/12/2015 09:20PM by mrmills129.
