[solved] Semicircle printing failes...
Posted by o_lampe
July 06, 2015 04:00AM
I started yesterday with printing a new dual-E3D carrier. [www.thingiverse.com]
Every part went well, but the bracket for the lm8uu bearings turned out as a nightmare.
I got strings because the semicircles do not connect to the print.
Nozzle: 0.4
Layer 0.3
I tried to print it with 2.4mm shell size or 0.8 mm shell size. Even at 30mm/s with 210C, I couldn´t make it bond to the print.
I printed it upright, like it is shown in the picture. Should I try it flat, with support?
-Olaf
Edited 1 time(s). Last edit at 07/07/2015 11:15AM by o_lampe.
open | download - dual_e3d_bracket.jpg (186 KB)
Re: Semicircle printing failes...
July 06, 2015 04:35AM
I tried it one more time without the print-fan.
I observed the print closely and it seems, all off a sudden I have under extrusion...
I´ll clean the extruder gear and the nozzle, and try again later...
-Olaf
Re: [solved] Semicircle printing failes...
July 07, 2015 11:20AM
The 0.4 nozzle is clogged and after cleaning still is. I´ll look for a drill bit or thin wire from a wirebrush to clean the throat.
I also found the gear of the extruder was pretty loose, also none of the two grubscrews sat on the flat side of the stepper shaft?!
How stupid is that?
I exchanged the nozzle with 0.3 at 0.2 layer and it worked almost perfect.
-Olaf
open | download - dual_e3d_bracket_OK.jpg (133.7 KB)
