Diagonal pattern September 14, 2015 12:36AM |
Re: Diagonal pattern September 14, 2015 02:10AM |
Re: Diagonal pattern September 14, 2015 06:27AM |
Re: Diagonal pattern September 14, 2015 11:21PM |
Re: Diagonal pattern September 15, 2015 01:51AM |
Re: Diagonal pattern September 15, 2015 11:57AM |
Downunder35m
I had similar issues after setting up a new hotend with the default settings.
Check your slicing settings for the start points of perimeters.
You did not mention if the pattern is all the way round...
I suspect it is the blob from the start of a new line, so maybe as simple as checking the retraction and wiping.
Re: Diagonal pattern September 15, 2015 04:29PM |
Re: Diagonal pattern September 15, 2015 06:54PM |
imqqmi
If you use A4988 you use 16x micro stepping, the 8825 uses 32 with the 3 jumpers in place.
The hack involves shorting R4 10k resistor on the A4988. For the 8825 you need to solder a wire to put it into the correct decay mode. On mine it was already replaced by a 000 Ohm resistor. They are tiny, but with a magnifier you can read them if your eye sight isn't perfect.
8825 hack
This illustrates the problem, it's almost like a second needle of a clock. I can imagine this would create the pattern you're seeing in your prints if the extruder motor moves in such a way:
Video illustrating the problem with 8825
Scroll down in the thread for the english version:
More info about decay hack
Re: Diagonal pattern September 15, 2015 08:12PM |
Re: Diagonal pattern September 15, 2015 10:08PM |
Re: Diagonal pattern September 16, 2015 04:00AM |
