Geeetech Rumba. Fill does not follow the contours.
Posted by AndOsb
November 15, 2015 11:35AM
Hallo!
I use a Geeetech Rumba control cards. When the printer is printing, the first contours is OK,
but when the printer starts to make a filling, between contours, is it as if X and Y change place,
and the printer goes in a completely different direction than it should. Eventually it reaches the end positions.
Does anyone know what is incorrect.
AndOsb
Re: Geeetech Rumba. Fill does not follow the contours.
November 16, 2015 03:51AM
Check acceleration and motor current. Set acceleration for x and y to 1000mm/s2. Also make sure tha axes move without binding. search the reprap.org wiki to set motor current.
Kind regards
Imqqmi
NFAN CoreXY printer:
[reprap.org]
November 17, 2015 07:22AM
Thanks Imqqmi I shall test that.
It seems as, if it is going in (+X,+Y) direction, it works all right, but when it should go in (-X,-Y) just -X works.
I have tested to print a 3D-figure with 8 corners, and that works OK in all 8 directions, when it writes the contour.
open | download - ZikZak.jpg (77.9 KB)
