Printing blobs
Posted by drighter
Printing blobs
December 14, 2015 09:47AM
I just finished building an admittently somewhat crude reprap with nema 17 motors and 1/4-20 threaded rod for all three axis. I've been able to get the settings below to work without skipping steps and everythig appears to be calibrated within reason as I'm getting the proper amounts of filament through the extruder by measurement and the three axis move the proper distances.
My problem is that when printing the test prints, I seem to get a single blob of plastic. The 20mm cube appears to print all of the X movements, but nothing on the Y causing a blob of plastic that the extruder then digs through. Attempting to print a thin wall cube, I get a wall of plastic that is somewhat squished at the bottom. Again printing the X movements, but not the Y. With every print, the X, Y, and Z axis all move to initial positions.
I'm running Marlin firmware with Repetier-host for printing.
#define DEFAULT_AXIS_STEPS_PER_UNIT {2519.68,2519.68,2519.68,726.667}
#define DEFAULT_MAX_FEEDRATE {6, 6, 10, 2}
#define DEFAULT_MAX_ACCELERATION {100,100,100,18}
#define DEFAULT_ACCELERATION 3000
#define DEFAULT_RETRACT_ACCELERATION 3000
#define DEFAULT_TRAVEL_ACCELERATION 3000
#define DEFAULT_XYJERK 15.0
#define DEFAULT_ZJERK 0.4
#define DEFAULT_EJERK 5.0
Any imput on this is greatly appreciated.
Re: Printing blobs
December 14, 2015 01:39PM
does the motor try to turn and just whines?
2 things come to mind, vref set to low for the Y and/or you are tring to print too fast.
Re: Printing blobs
December 14, 2015 01:46PM
Initially the motor wasn't turning so I adjusted the power on the stepper driver. Now, the motor turns when the Y axis initially moves into position and when manually moving it with the software. It doesn't seem to whine, just doesn't appear to be doing anything when actually printing. Printing too fast?
Edited 1 time(s). Last edit at 12/14/2015 01:49PM by drighter.
Re: Printing blobs
December 16, 2015 03:21AM
Hi drighter,
this is probably not the cause of the Y-axis not moving during printing, but I would suggest to lower the #define DEFAULT_XYJERK 15.0 to something like 1 or 2.
If you jerk value is higher than you max federate, the driver will try to instantly bring the stepper to that speed. With 2500 steps per mm this is quite a speed jump.
Could you post parts of your g-code? Maybe something in the slicer settings is odd.
Edited 1 time(s). Last edit at 12/16/2015 03:23AM by coldlizard.
Re: Printing blobs
December 16, 2015 07:48AM
thin_wall_box g-code
; generated by Slic3r 1.2.9 on 2015-12-16 at 07:45:33
; external perimeters extrusion width = 0.42mm
; perimeters extrusion width = 0.42mm
; infill extrusion width = 0.42mm
; solid infill extrusion width = 0.42mm
; top infill extrusion width = 0.42mm
M107
M104 S210 ; set temperature
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
M109 S210 ; wait for temperature to be reached
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusion
G92 E0
G1 Z0.350 F6000.000
G1 E-1.00000 F2400.00000
G92 E0
G1 X190.498 Y282.187 F6000.000
G1 E1.00000 F2400.00000
G1 X191.491 Y281.612 E1.05761 F1200.000
G1 X191.689 Y281.520 E1.06857
G1 X192.727 Y281.143 E1.12398
G1 X192.937 Y281.087 E1.13489
G1 X194.049 Y280.895 E1.19151
G1 X194.268 Y280.877 E1.20254
G1 X194.790 Y280.855 E1.22877
G1 X214.788 Y280.855 E2.23239
G1 X215.308 Y280.876 E2.25850
G1 X215.528 Y280.895 E2.26960 F1200.000
G1 X216.641 Y281.087 E2.32626
G1 X216.851 Y281.143 E2.33717
G1 X217.889 Y281.520 E2.39259
G1 X218.087 Y281.612 E2.40355
G1 X219.080 Y282.187 E2.46113
G1 X219.258 Y282.313 E2.47210
G1 X220.079 Y283.005 E2.52597
G1 X220.232 Y283.159 E2.53690
G1 X220.925 Y283.980 E2.59078
G1 X221.051 Y284.158 E2.60172
G1 X221.626 Y285.150 E2.65929
G1 X221.718 Y285.348 E2.67025
G1 X222.095 Y286.387 E2.72570
G1 X222.151 Y286.597 E2.73661
G1 X222.338 Y287.652 E2.79038
G1 X222.385 Y288.450 E2.83049
G1 X222.385 Y308.448 E3.83410
G1 X222.338 Y309.245 E3.87419
G1 X222.151 Y310.301 E3.92801
G1 X222.095 Y310.511 E3.93892
G1 X221.718 Y311.550 E3.99435
G1 X221.626 Y311.748 E4.00530
G1 X221.051 Y312.740 E4.06287
G1 X220.925 Y312.918 E4.07381
G1 X220.232 Y313.739 E4.12770
G1 X220.079 Y313.893 E4.13863
G1 X219.258 Y314.585 E4.19249
G1 X219.080 Y314.711 E4.20344
G1 X218.088 Y315.286 E4.26100
G1 X217.890 Y315.378 E4.27196
G1 X216.851 Y315.755 E4.32742
G1 X216.641 Y315.811 E4.33833
G1 X215.586 Y315.998 E4.39212
G1 X215.367 Y316.018 E4.40312
G1 X214.788 Y316.045 E4.43222
G1 X194.790 Y316.045 E5.43584
G1 X193.993 Y315.998 E5.47592
G1 X192.938 Y315.811 E5.52968
G1 X192.727 Y315.755 E5.54063
G1 X191.689 Y315.378 E5.59606
G1 X191.490 Y315.286 E5.60705
G1 X190.498 Y314.711 E5.66462
G1 X190.320 Y314.584 E5.67557
G1 X189.500 Y313.893 E5.72937
G1 X189.346 Y313.739 E5.74034
G1 X188.653 Y312.918 E5.79424
G1 X188.527 Y312.740 E5.80519
G1 X187.952 Y311.748 E5.86274
G1 X187.860 Y311.550 E5.87371
G1 X187.484 Y310.512 E5.92910
G1 X187.427 Y310.301 E5.94006
G1 X187.235 Y309.188 E5.99673
G1 X187.217 Y308.970 E6.00771
G1 X187.195 Y308.448 E6.03394
G1 X187.195 Y288.450 E7.03756
G1 X187.217 Y287.929 E7.06375
G1 X187.235 Y287.710 E7.07477
G1 X187.427 Y286.597 E7.13143
G1 X187.483 Y286.387 E7.14234
G1 X187.859 Y285.350 E7.19769
G1 X187.952 Y285.150 E7.20875
G1 X188.527 Y284.158 E7.26630
G1 X188.653 Y283.980 E7.27726
G1 X189.346 Y283.159 E7.33114
G1 X189.499 Y283.005 E7.34207
G1 X190.449 Y282.222 E7.40385
G1 E6.40385 F2400.00000
G92 E0
G1 X193.666 Y288.440 F6000.000
G1 X193.684 Y288.243 E1.00991 F1200.000
G1 X193.732 Y288.065 E1.01919
G1 X193.809 Y287.898 E1.02842
G1 X193.927 Y287.726 E1.03888
G1 X194.059 Y287.594 E1.04821
G1 X194.227 Y287.474 E1.05859
G1 X194.405 Y287.392 E1.06843
G1 X194.593 Y287.341 E1.07823
G1 X194.795 Y287.325 E1.08839
G1 X214.787 Y287.325 E2.09168
G1 X214.985 Y287.341 E2.10165
G1 X215.173 Y287.392 E2.11145
G1 X215.351 Y287.474 E2.12129
G1 X215.512 Y287.587 E2.13114
G1 X215.658 Y287.735 E2.14158
G1 X215.764 Y287.887 E2.15086
G1 X215.841 Y288.054 E2.16009
G1 X215.897 Y288.254 E2.17052
G1 X215.914 Y288.456 E2.18069
G1 X215.914 Y308.442 E3.18372
G1 X215.897 Y308.644 E3.19389
G1 X215.846 Y308.833 E3.20372
G1 X215.764 Y309.011 E3.21356
G1 X215.651 Y309.172 E3.22341
G1 X215.503 Y309.318 E3.23385
G1 X215.351 Y309.424 E3.24312
G1 X215.184 Y309.501 E3.25236
G1 X214.984 Y309.557 E3.26279
G1 X214.782 Y309.574 E3.27295
G1 X194.796 Y309.574 E4.27599
G1 X194.594 Y309.557 E4.28616
G1 X194.405 Y309.506 E4.29599
G1 X194.227 Y309.424 E4.30583
G1 X194.066 Y309.311 E4.31568
G1 X193.920 Y309.163 E4.32612
G1 X193.814 Y309.011 E4.33539
G1 X193.737 Y308.844 E4.34463
G1 X193.681 Y308.645 E4.35503
G1 X193.665 Y308.443 E4.36519
G1 X193.666 Y288.440 E5.36905
M104 S200 ; set temperature
G1 Z0.750 F6000.000
G1 X193.684 Y288.243 E5.38001 F900.000
G1 X193.732 Y288.065 E5.39030
G1 X193.809 Y287.898 E5.40052
G1 X193.927 Y287.726 E5.41209
G1 X194.059 Y287.594 E5.42243
G1 X194.227 Y287.474 E5.43392
G1 X194.405 Y287.392 E5.44482
G1 X194.593 Y287.341 E5.45567
G1 X194.795 Y287.325 E5.46692
G1 X214.788 Y287.325 E6.57794
G1 X214.985 Y287.341 E6.58891
G1 X215.173 Y287.392 E6.59976
G1 X215.351 Y287.474 E6.61065
G1 X215.512 Y287.587 E6.62156
G1 X215.658 Y287.735 E6.63312
G1 X215.764 Y287.887 E6.64339
G1 X215.841 Y288.054 E6.65362
G1 X215.897 Y288.254 E6.66516
G1 X215.914 Y288.456 E6.67642
G1 X215.914 Y308.442 E7.78708
G1 X215.897 Y308.644 E7.79834
G1 X215.846 Y308.833 E7.80923
G1 X215.764 Y309.011 E7.82012
G1 X215.651 Y309.172 E7.83103
G1 X215.503 Y309.318 E7.84259
G1 X215.351 Y309.424 E7.85286
G1 X215.184 Y309.501 E7.86309
G1 X214.984 Y309.557 E7.87463
G1 X214.782 Y309.574 E7.88589
G1 X194.796 Y309.574 E8.99655
G1 X194.594 Y309.557 E9.00781
G1 X194.405 Y309.506 E9.01869
G1 X194.227 Y309.424 E9.02959
G1 X194.066 Y309.311 E9.04050
G1 X193.920 Y309.163 E9.05206
G1 X193.814 Y309.011 E9.06233
G1 X193.737 Y308.844 E9.07255
G1 X193.681 Y308.645 E9.08407
G1 X193.665 Y308.443 E9.09532
G1 X193.666 Y288.440 E10.20689
G1 Z1.150 F6000.000
G1 X193.684 Y288.243 E10.21786 F900.000
G1 X193.732 Y288.065 E10.22815
G1 X193.809 Y287.898 E10.23836
G1 X193.927 Y287.726 E10.24994
G1 X194.059 Y287.594 E10.26028
G1 X194.227 Y287.474 E10.27177
G1 X194.405 Y287.392 E10.28267
G1 X194.593 Y287.341 E10.29352
G1 X194.795 Y287.325 E10.30477
G1 X214.788 Y287.326 E11.41579
G1 X214.985 Y287.341 E11.42675
G1 X215.173 Y287.392 E11.43760
G1 X215.351 Y287.474 E11.44850
G1 X215.512 Y287.587 E11.45940
G1 X215.658 Y287.735 E11.47096
G1 X215.764 Y287.887 E11.48123
G1 X215.841 Y288.054 E11.49146
G1 X215.897 Y288.254 E11.50301
G1 X215.914 Y288.456 E11.51427
G1 X215.914 Y308.442 E12.62493
G1 X215.897 Y308.644 E12.63619
G1 X215.846 Y308.833 E12.64707
G1 X215.764 Y309.011 E12.65797
G1 X215.651 Y309.172 E12.66887
G1 X215.503 Y309.318 E12.68043
G1 X215.351 Y309.424 E12.69070
G1 X215.184 Y309.501 E12.70093
G1 X214.984 Y309.557 E12.71248
G1 X214.782 Y309.574 E12.72373
G1 X194.796 Y309.574 E13.83440
G1 X194.594 Y309.557 E13.84566
G1 X194.405 Y309.506 E13.85654
G1 X194.227 Y309.424 E13.86744
G1 X194.066 Y309.311 E13.87834
G1 X193.920 Y309.163 E13.88990
G1 X193.814 Y309.011 E13.90017
G1 X193.737 Y308.844 E13.91040
G1 X193.681 Y308.645 E13.92191
G1 X193.665 Y308.443 E13.93316
G1 X193.666 Y288.440 E15.04474
M106 S252.45
G1 Z1.550 F6000.000
G1 X193.684 Y288.243 E15.05571 F900.000
G1 X193.732 Y288.065 E15.06599
G1 X193.809 Y287.898 E15.07621
G1 X193.927 Y287.726 E15.08779
G1 X194.059 Y287.594 E15.09813
G1 X194.227 Y287.474 E15.10962
G1 X194.405 Y287.392 E15.12051
G1 X194.593 Y287.341 E15.13137
G1 X194.795 Y287.325 E15.14262
G1 X214.788 Y287.326 E16.25364
G1 X214.985 Y287.341 E16.26460
G1 X215.173 Y287.392 E16.27545
G1 X215.351 Y287.474 E16.28634
G1 X215.512 Y287.587 E16.29725
G1 X215.658 Y287.735 E16.30881
G1 X215.764 Y287.887 E16.31908
G1 X215.841 Y288.054 E16.32931
G1 X215.897 Y288.254 E16.34085
G1 X215.914 Y288.456 E16.35211
G1 X215.914 Y308.442 E17.46278
G1 X215.897 Y308.644 E17.47403
G1 X215.846 Y308.833 E17.48492
G1 X215.764 Y309.011 E17.49581
G1 X215.651 Y309.172 E17.50672
G1 X215.503 Y309.318 E17.51828
G1 X215.351 Y309.424 E17.52855
G1 X215.184 Y309.501 E17.53878
G1 X214.984 Y309.557 E17.55032
G1 X214.782 Y309.574 E17.56158
G1 X194.796 Y309.574 E18.67224
G1 X194.594 Y309.557 E18.68350
G1 X194.405 Y309.506 E18.69438
G1 X194.227 Y309.424 E18.70528
G1 X194.066 Y309.311 E18.71619
G1 X193.920 Y309.163 E18.72775
G1 X193.814 Y309.011 E18.73802
G1 X193.737 Y308.844 E18.74824
G1 X193.681 Y308.645 E18.75976
G1 X193.665 Y308.443 E18.77101
G1 X193.666 Y288.440 E19.88258
G1 Z1.950 F6000.000
G1 X193.684 Y288.243 E19.89355 F900.000
G1 X193.732 Y288.065 E19.90384
G1 X193.809 Y287.898 E19.91405
G1 X193.927 Y287.726 E19.92563
G1 X194.059 Y287.594 E19.93597
G1 X194.227 Y287.474 E19.94746
G1 X194.405 Y287.392 E19.95836
G1 X194.593 Y287.341 E19.96921
G1 X194.795 Y287.325 E19.98046
G1 X214.788 Y287.327 E21.09148
G1 X214.985 Y287.341 E21.10244
G1 X215.173 Y287.392 E21.11329
G1 X215.351 Y287.474 E21.12419
G1 X215.512 Y287.587 E21.13509
G1 X215.658 Y287.735 E21.14665
G1 X215.764 Y287.887 E21.15692
G1 X215.841 Y288.054 E21.16715
G1 X215.897 Y288.254 E21.17870
G1 X215.914 Y288.456 E21.18995
G1 X215.914 Y308.442 E22.30062
G1 X215.897 Y308.644 E22.31188
G1 X215.846 Y308.833 E22.32276
G1 X215.764 Y309.011 E22.33366
G1 X215.651 Y309.172 E22.34456
G1 X215.503 Y309.318 E22.35612
G1 X215.351 Y309.424 E22.36639
G1 X215.184 Y309.501 E22.37662
G1 X214.984 Y309.557 E22.38816
G1 X214.782 Y309.574 E22.39942
G1 X194.796 Y309.574 E23.51009
G1 X194.594 Y309.557 E23.52135
G1 X194.405 Y309.506 E23.53223
G1 X194.227 Y309.424 E23.54312
G1 X194.066 Y309.311 E23.55403
G1 X193.920 Y309.163 E23.56559
G1 X193.814 Y309.011 E23.57586
G1 X193.737 Y308.844 E23.58609
G1 X193.681 Y308.645 E23.59760
G1 X193.665 Y308.443 E23.60885
G1 X193.666 Y288.440 E24.72043
G1 Z2.350 F6000.000
G1 X193.664 Y308.431 F6000.000
G1 X193.665 Y288.455 E25.83053 F900.000
G1 X193.681 Y288.253 E25.84178
G1 X193.737 Y288.054 E25.85329
G1 X193.814 Y287.887 E25.86352
G1 X193.920 Y287.735 E25.87379
G1 X194.066 Y287.587 E25.88535
G1 X194.227 Y287.474 E25.89626
G1 X194.405 Y287.392 E25.90715
G1 X194.593 Y287.341 E25.91800
G1 X194.795 Y287.325 E25.92925
G1 X214.788 Y287.327 E27.04027
G1 X214.985 Y287.341 E27.05123
G1 X215.184 Y287.397 E27.06274
G1 X215.351 Y287.474 E27.07297
G1 X215.503 Y287.580 E27.08324
G1 X215.651 Y287.726 E27.09480
G1 X215.764 Y287.887 E27.10571
G1 X215.846 Y288.065 E27.11660
G1 X215.897 Y288.254 E27.12749
G1 X215.914 Y288.456 E27.13875
G1 X215.914 Y308.442 E28.24941
G1 X215.897 Y308.644 E28.26067
G1 X215.841 Y308.844 E28.27221
G1 X215.764 Y309.011 E28.28244
G1 X215.658 Y309.163 E28.29271
G1 X215.512 Y309.311 E28.30427
G1 X215.351 Y309.424 E28.31518
G1 X215.173 Y309.506 E28.32607
G1 X214.984 Y309.557 E28.33696
G1 X214.782 Y309.574 E28.34821
G1 X194.796 Y309.574 E29.45888
G1 X194.594 Y309.557 E29.47014
G1 X194.394 Y309.501 E29.48168
G1 X194.219 Y309.418 E29.49243
G1 X194.066 Y309.311 E29.50281
G1 X193.935 Y309.180 E29.51315
G1 X193.814 Y309.011 E29.52464
G1 X193.732 Y308.833 E29.53554
G1 X193.681 Y308.645 E29.54639
G1 X193.664 Y308.431 E29.55827
G1 Z2.750 F6000.000
G1 X193.684 Y288.243 E29.56924 F900.000
G1 X193.732 Y288.065 E29.57953
G1 X193.809 Y287.898 E29.58974
G1 X193.927 Y287.726 E29.60132
G1 X194.059 Y287.594 E29.61166
G1 X194.227 Y287.474 E29.62315
G1 X194.405 Y287.392 E29.63405
G1 X194.593 Y287.341 E29.64490
G1 X194.795 Y287.325 E29.65615
G1 X214.788 Y287.327 E30.76717
G1 X214.985 Y287.341 E30.77812
G1 X215.173 Y287.392 E30.78897
G1 X215.351 Y287.474 E30.79987
G1 X215.512 Y287.587 E30.81078
G1 X215.658 Y287.735 E30.82234
G1 X215.764 Y287.887 E30.83261
G1 X215.841 Y288.054 E30.84284
G1 X215.897 Y288.254 E30.85438
G1 X215.914 Y288.456 E30.86564
G1 X215.914 Y308.442 E31.97630
G1 X215.897 Y308.644 E31.98756
G1 X215.846 Y308.833 E31.99844
G1 X215.764 Y309.011 E32.00934
G1 X215.651 Y309.172 E32.02025
G1 X215.503 Y309.318 E32.03180
G1 X215.351 Y309.424 E32.04208
G1 X215.184 Y309.501 E32.05230
G1 X214.984 Y309.557 E32.06385
G1 X214.782 Y309.574 E32.07511
G1 X194.796 Y309.574 E33.18577
G1 X194.594 Y309.557 E33.19703
G1 X194.405 Y309.506 E33.20791
G1 X194.227 Y309.424 E33.21881
G1 X194.066 Y309.311 E33.22971
G1 X193.920 Y309.163 E33.24127
G1 X193.814 Y309.011 E33.25155
G1 X193.737 Y308.844 E33.26177
G1 X193.681 Y308.645 E33.27329
G1 X193.665 Y308.443 E33.28454
G1 X193.666 Y288.440 E34.39611
G1 Z3.150 F6000.000
G1 X193.684 Y288.243 E34.40708 F900.000
G1 X193.732 Y288.065 E34.41737
G1 X193.809 Y287.898 E34.42758
G1 X193.927 Y287.726 E34.43916
G1 X194.059 Y287.594 E34.44950
G1 X194.227 Y287.474 E34.46099
G1 X194.405 Y287.392 E34.47189
G1 X194.593 Y287.341 E34.48274
G1 X194.795 Y287.325 E34.49399
G1 X214.788 Y287.330 E35.60501
G1 X214.972 Y287.345 E35.61524
G1 X215.176 Y287.393 E35.62694
G1 X215.351 Y287.474 E35.63764
G1 X215.512 Y287.587 E35.64855
G1 X215.658 Y287.735 E35.66011
G1 X215.764 Y287.887 E35.67038
G1 X215.841 Y288.054 E35.68061
G1 X215.897 Y288.254 E35.69215
G1 X215.914 Y288.456 E35.70341
G1 X215.914 Y308.442 E36.81408
G1 X215.897 Y308.644 E36.82533
G1 X215.846 Y308.833 E36.83622
G1 X215.764 Y309.011 E36.84711
G1 X215.651 Y309.172 E36.85802
G1 X215.503 Y309.318 E36.86958
G1 X215.351 Y309.424 E36.87985
G1 X215.184 Y309.501 E36.89008
G1 X214.984 Y309.557 E36.90162
G1 X214.782 Y309.574 E36.91288
G1 X194.796 Y309.574 E38.02354
G1 X194.594 Y309.557 E38.03480
G1 X194.405 Y309.506 E38.04568
G1 X194.227 Y309.424 E38.05658
G1 X194.066 Y309.311 E38.06749
G1 X193.920 Y309.163 E38.07905
G1 X193.814 Y309.011 E38.08932
G1 X193.737 Y308.844 E38.09954
G1 X193.681 Y308.645 E38.11106
G1 X193.665 Y308.443 E38.12231
G1 X193.666 Y288.440 E39.23388
G1 Z3.550 F6000.000
G1 X193.684 Y288.243 E39.24485 F900.000
G1 X193.732 Y288.065 E39.25514
G1 X193.809 Y287.898 E39.26535
G1 X193.927 Y287.726 E39.27693
G1 X194.059 Y287.594 E39.28727
G1 X194.227 Y287.474 E39.29876
G1 X194.405 Y287.392 E39.30966
G1 X194.593 Y287.341 E39.32051
G1 X194.795 Y287.325 E39.33176
G1 X214.788 Y287.328 E40.44278
G1 X214.985 Y287.341 E40.45373
G1 X215.173 Y287.392 E40.46458
G1 X215.351 Y287.474 E40.47548
G1 X215.512 Y287.587 E40.48639
G1 X215.658 Y287.735 E40.49795
G1 X215.764 Y287.887 E40.50822
G1 X215.841 Y288.054 E40.51845
G1 X215.897 Y288.254 E40.52999
G1 X215.914 Y288.456 E40.54125
G1 X215.914 Y308.442 E41.65191
G1 X215.897 Y308.644 E41.66317
G1 X215.846 Y308.833 E41.67405
G1 X215.764 Y309.011 E41.68495
G1 X215.651 Y309.172 E41.69585
G1 X215.503 Y309.318 E41.70741
G1 X215.351 Y309.424 E41.71769
G1 X215.184 Y309.501 E41.72791
G1 X214.984 Y309.557 E41.73946
G1 X214.782 Y309.574 E41.75072
G1 X194.796 Y309.574 E42.86138
G1 X194.594 Y309.557 E42.87264
G1 X194.405 Y309.506 E42.88352
G1 X194.227 Y309.424 E42.89442
G1 X194.066 Y309.311 E42.90532
G1 X193.920 Y309.163 E42.91688
G1 X193.814 Y309.011 E42.92715
G1 X193.737 Y308.844 E42.93738
G1 X193.681 Y308.645 E42.94890
G1 X193.665 Y308.443 E42.96015
G1 X193.666 Y288.440 E44.07172
G1 Z3.950 F6000.000
G1 X193.684 Y288.243 E44.08269 F900.000
G1 X193.732 Y288.065 E44.09297
G1 X193.809 Y287.898 E44.10319
G1 X193.927 Y287.726 E44.11477
G1 X194.059 Y287.594 E44.12511
G1 X194.227 Y287.474 E44.13660
G1 X194.405 Y287.392 E44.14750
G1 X194.593 Y287.341 E44.15835
G1 X194.795 Y287.325 E44.16960
G1 X214.788 Y287.328 E45.28062
G1 X214.985 Y287.341 E45.29157
G1 X215.173 Y287.392 E45.30242
G1 X215.351 Y287.474 E45.31332
G1 X215.512 Y287.587 E45.32422
G1 X215.658 Y287.735 E45.33578
G1 X215.764 Y287.887 E45.34605
G1 X215.841 Y288.054 E45.35628
G1 X215.897 Y288.254 E45.36783
G1 X215.914 Y288.456 E45.37908
G1 X215.914 Y308.442 E46.48975
G1 X215.897 Y308.644 E46.50101
G1 X215.846 Y308.833 E46.51189
G1 X215.764 Y309.011 E46.52279
G1 X215.651 Y309.172 E46.53369
G1 X215.503 Y309.318 E46.54525
G1 X215.351 Y309.424 E46.55552
G1 X215.184 Y309.501 E46.56575
G1 X214.984 Y309.557 E46.57729
G1 X214.782 Y309.574 E46.58855
G1 X194.796 Y309.574 E47.69922
G1 X194.594 Y309.557 E47.71048
G1 X194.405 Y309.506 E47.72136
G1 X194.227 Y309.424 E47.73225
G1 X194.066 Y309.311 E47.74316
G1 X193.920 Y309.163 E47.75472
G1 X193.814 Y309.011 E47.76499
G1 X193.737 Y308.844 E47.77522
G1 X193.681 Y308.645 E47.78673
G1 X193.665 Y308.443 E47.79798
G1 X193.666 Y288.440 E48.90956
G1 Z4.350 F6000.000
G1 X193.684 Y288.243 E48.92053 F900.000
G1 X193.732 Y288.065 E48.93081
G1 X193.809 Y287.898 E48.94103
G1 X193.927 Y287.726 E48.95260
G1 X194.059 Y287.594 E48.96294
G1 X194.227 Y287.474 E48.97444
G1 X194.405 Y287.392 E48.98533
G1 X194.593 Y287.341 E48.99618
G1 X194.795 Y287.325 E49.00743
G1 X214.788 Y287.329 E50.11845
G1 X214.985 Y287.341 E50.12940
G1 X215.173 Y287.392 E50.14025
G1 X215.351 Y287.474 E50.15115
G1 X215.512 Y287.587 E50.16206
G1 X215.658 Y287.735 E50.17362
G1 X215.764 Y287.887 E50.18389
G1 X215.844 Y288.060 E50.19449
G1 X215.897 Y288.254 E50.20567
G1 X215.914 Y288.456 E50.21692
G1 X215.914 Y308.442 E51.32759
G1 X215.897 Y308.644 E51.33885
G1 X215.846 Y308.833 E51.34973
G1 X215.764 Y309.011 E51.36063
G1 X215.651 Y309.172 E51.37153
G1 X215.503 Y309.318 E51.38309
G1 X215.351 Y309.424 E51.39336
G1 X215.184 Y309.501 E51.40359
G1 X214.984 Y309.557 E51.41513
G1 X214.782 Y309.574 E51.42639
G1 X194.796 Y309.574 E52.53706
G1 X194.594 Y309.557 E52.54832
G1 X194.405 Y309.506 E52.55920
G1 X194.227 Y309.424 E52.57009
G1 X194.066 Y309.311 E52.58100
G1 X193.920 Y309.163 E52.59256
G1 X193.814 Y309.011 E52.60283
G1 X193.734 Y308.838 E52.61343
G1 X193.681 Y308.645 E52.62458
G1 X193.665 Y308.443 E52.63583
G1 X193.666 Y288.440 E53.74740
G1 Z4.750 F6000.000
G1 X193.684 Y288.243 E53.75837 F900.000
G1 X193.732 Y288.065 E53.76866
G1 X193.809 Y287.898 E53.77887
G1 X193.927 Y287.726 E53.79045
G1 X194.059 Y287.594 E53.80079
G1 X194.227 Y287.474 E53.81228
G1 X194.405 Y287.392 E53.82318
G1 X194.593 Y287.341 E53.83403
G1 X194.795 Y287.325 E53.84528
G1 X214.788 Y287.329 E54.95630
G1 X214.985 Y287.341 E54.96725
G1 X215.173 Y287.392 E54.97810
G1 X215.351 Y287.474 E54.98899
G1 X215.512 Y287.587 E54.99990
G1 X215.658 Y287.735 E55.01146
G1 X215.764 Y287.887 E55.02173
G1 X215.841 Y288.054 E55.03196
G1 X215.897 Y288.254 E55.04350
G1 X215.914 Y288.456 E55.05476
G1 X215.914 Y308.442 E56.16543
G1 X215.897 Y308.644 E56.17668
G1 X215.846 Y308.833 E56.18757
G1 X215.764 Y309.011 E56.19846
G1 X215.651 Y309.172 E56.20937
G1 X215.503 Y309.318 E56.22093
G1 X215.351 Y309.424 E56.23120
G1 X215.184 Y309.501 E56.24143
G1 X214.984 Y309.557 E56.25297
G1 X214.782 Y309.574 E56.26423
G1 X194.796 Y309.574 E57.37490
G1 X194.594 Y309.557 E57.38615
G1 X194.405 Y309.506 E57.39704
G1 X194.227 Y309.424 E57.40793
G1 X194.066 Y309.311 E57.41884
G1 X193.920 Y309.163 E57.43040
G1 X193.814 Y309.011 E57.44067
G1 X193.737 Y308.844 E57.45090
G1 X193.681 Y308.645 E57.46241
G1 X193.665 Y308.443 E57.47366
G1 X193.666 Y288.440 E58.58524
G1 Z5.150 F6000.000
G1 X193.684 Y288.243 E58.59620 F900.000
G1 X193.732 Y288.065 E58.60649
G1 X193.809 Y287.898 E58.61670
G1 X193.927 Y287.726 E58.62828
G1 X194.059 Y287.594 E58.63862
G1 X194.227 Y287.474 E58.65011
G1 X194.405 Y287.392 E58.66101
G1 X194.593 Y287.341 E58.67186
G1 X194.795 Y287.325 E58.68311
G1 X214.788 Y287.329 E59.79413
G1 X214.985 Y287.341 E59.80508
G1 X215.173 Y287.392 E59.81593
G1 X215.351 Y287.474 E59.82683
G1 X215.512 Y287.587 E59.83773
G1 X215.658 Y287.735 E59.84929
G1 X215.764 Y287.887 E59.85956
G1 X215.841 Y288.054 E59.86979
G1 X215.897 Y288.254 E59.88134
G1 X215.914 Y288.456 E59.89259
G1 X215.914 Y308.442 E61.00326
G1 X215.897 Y308.644 E61.01452
G1 X215.846 Y308.833 E61.02540
G1 X215.764 Y309.011 E61.03630
G1 X215.651 Y309.172 E61.04720
G1 X215.503 Y309.318 E61.05876
G1 X215.351 Y309.424 E61.06903
G1 X215.184 Y309.501 E61.07926
G1 X214.984 Y309.557 E61.09080
G1 X214.782 Y309.574 E61.10206
G1 X194.796 Y309.574 E62.21273
G1 X194.594 Y309.557 E62.22399
G1 X194.405 Y309.506 E62.23487
G1 X194.227 Y309.424 E62.24576
G1 X194.066 Y309.311 E62.25667
G1 X193.920 Y309.163 E62.26823
G1 X193.814 Y309.011 E62.27850
G1 X193.737 Y308.844 E62.28873
G1 X193.681 Y308.645 E62.30024
G1 X193.665 Y308.443 E62.31149
G1 X193.666 Y288.440 E63.42307
G1 Z5.550 F6000.000
G1 X193.684 Y288.243 E63.43404 F900.000
G1 X193.732 Y288.065 E63.44432
G1 X193.809 Y287.898 E63.45454
G1 X193.927 Y287.726 E63.46611
G1 X194.059 Y287.594 E63.47645
G1 X194.227 Y287.474 E63.48795
G1 X194.405 Y287.392 E63.49884
G1 X194.593 Y287.341 E63.50969
G1 X194.795 Y287.325 E63.52094
G1 X214.788 Y287.330 E64.63196
G1 X214.972 Y287.345 E64.64220
G1 X215.177 Y287.393 E64.65390
G1 X215.351 Y287.474 E64.66460
G1 X215.512 Y287.587 E64.67550
G1 X215.658 Y287.735 E64.68706
G1 X215.764 Y287.887 E64.69733
G1 X215.841 Y288.054 E64.70756
G1 X215.897 Y288.254 E64.71911
G1 X215.914 Y288.456 E64.73037
G1 X215.914 Y308.442 E65.84103
G1 X215.897 Y308.644 E65.85229
G1 X215.846 Y308.833 E65.86317
G1 X215.764 Y309.011 E65.87407
G1 X215.651 Y309.172 E65.88497
G1 X215.503 Y309.318 E65.89653
G1 X215.351 Y309.424 E65.90680
G1 X215.184 Y309.501 E65.91703
G1 X214.984 Y309.557 E65.92858
G1 X214.782 Y309.574 E65.93983
G1 X194.796 Y309.574 E67.05050
G1 X194.594 Y309.557 E67.06176
G1 X194.405 Y309.506 E67.07264
G1 X194.227 Y309.424 E67.08354
G1 X194.066 Y309.311 E67.09444
G1 X193.920 Y309.163 E67.10600
G1 X193.814 Y309.011 E67.11627
G1 X193.737 Y308.844 E67.12650
G1 X193.681 Y308.645 E67.13801
G1 X193.665 Y308.443 E67.14926
G1 X193.666 Y288.440 E68.26084
G1 Z5.950 F6000.000
G1 X193.684 Y288.243 E68.27181 F900.000
G1 X193.732 Y288.065 E68.28209
G1 X193.809 Y287.898 E68.29231
G1 X193.927 Y287.726 E68.30389
G1 X194.059 Y287.594 E68.31423
G1 X194.227 Y287.474 E68.32572
G1 X194.405 Y287.392 E68.33661
G1 X194.593 Y287.341 E68.34747
G1 X194.795 Y287.325 E68.35871
G1 X214.788 Y287.330 E69.46974
G1 X214.972 Y287.345 E69.47997
G1 X215.176 Y287.393 E69.49166
G1 X215.351 Y287.474 E69.50237
G1 X215.512 Y287.587 E69.51328
G1 X215.658 Y287.735 E69.52484
G1 X215.764 Y287.887 E69.53511
G1 X215.841 Y288.054 E69.54534
G1 X215.897 Y288.254 E69.55688
G1 X215.914 Y288.456 E69.56814
G1 X215.914 Y308.442 E70.67880
G1 X215.897 Y308.644 E70.69006
G1 X215.846 Y308.833 E70.70095
G1 X215.764 Y309.011 E70.71184
G1 X215.651 Y309.172 E70.72275
G1 X215.503 Y309.318 E70.73431
G1 X215.351 Y309.424 E70.74458
G1 X215.184 Y309.501 E70.75481
G1 X214.984 Y309.557 E70.76635
G1 X214.782 Y309.574 E70.77761
G1 X194.796 Y309.574 E71.88827
G1 X194.594 Y309.557 E71.89953
G1 X194.405 Y309.506 E71.91041
G1 X194.227 Y309.424 E71.92131
G1 X194.066 Y309.311 E71.93222
G1 X193.920 Y309.163 E71.94378
G1 X193.814 Y309.011 E71.95405
G1 X193.737 Y308.844 E71.96427
G1 X193.681 Y308.645 E71.97579
G1 X193.665 Y308.443 E71.98704
G1 X193.666 Y288.440 E73.09861
G1 Z6.350 F6000.000
G1 X193.684 Y288.243 E73.10958 F900.000
G1 X193.732 Y288.065 E73.11987
G1 X193.809 Y287.898 E73.13008
G1 X193.927 Y287.726 E73.14166
G1 X194.059 Y287.594 E73.15200
G1 X194.227 Y287.474 E73.16349
G1 X194.405 Y287.392 E73.17439
G1 X194.593 Y287.341 E73.18524
G1 X194.795 Y287.325 E73.19649
G1 X214.788 Y287.330 E74.30751
G1 X214.972 Y287.344 E74.31774
G1 X215.176 Y287.393 E74.32943
G1 X215.351 Y287.474 E74.34015
G1 X215.512 Y287.587 E74.35105
G1 X215.658 Y287.735 E74.36261
G1 X215.764 Y287.887 E74.37288
G1 X215.841 Y288.054 E74.38311
G1 X215.897 Y288.254 E74.39466
G1 X215.914 Y288.456 E74.40592
G1 X215.914 Y308.442 E75.51658
G1 X215.897 Y308.644 E75.52784
G1 X215.846 Y308.833 E75.53872
G1 X215.764 Y309.011 E75.54962
G1 X215.651 Y309.172 E75.56052
G1 X215.503 Y309.318 E75.57208
G1 X215.351 Y309.424 E75.58235
G1 X215.184 Y309.501 E75.59258
G1 X214.984 Y309.557 E75.60413
G1 X214.782 Y309.574 E75.61538
G1 X194.796 Y309.574 E76.72605
G1 X194.594 Y309.557 E76.73731
G1 X194.405 Y309.506 E76.74819
G1 X194.227 Y309.424 E76.75909
G1 X194.066 Y309.311 E76.76999
G1 X193.920 Y309.163 E76.78155
G1 X193.814 Y309.011 E76.79182
G1 X193.737 Y308.844 E76.80205
G1 X193.681 Y308.645 E76.81356
G1 X193.665 Y308.443 E76.82482
G1 X193.666 Y288.440 E77.93639
G1 Z6.750 F6000.000
G1 X193.684 Y288.243 E77.94736 F900.000
G1 X193.732 Y288.065 E77.95764
G1 X193.809 Y287.898 E77.96786
G1 X193.927 Y287.726 E77.97944
G1 X194.059 Y287.594 E77.98978
G1 X194.227 Y287.474 E78.00127
G1 X194.405 Y287.392 E78.01216
G1 X194.593 Y287.341 E78.02302
G1 X194.795 Y287.325 E78.03426
G1 X214.788 Y287.331 E79.14529
G1 X214.972 Y287.344 E79.15552
G1 X215.176 Y287.393 E79.16719
G1 X215.351 Y287.474 E79.17793
G1 X215.512 Y287.587 E79.18883
G1 X215.658 Y287.735 E79.20039
G1 X215.764 Y287.887 E79.21066
G1 X215.841 Y288.054 E79.22089
G1 X215.897 Y288.254 E79.23244
G1 X215.914 Y288.456 E79.24369
G1 X215.914 Y308.442 E80.35436
G1 X215.897 Y308.644 E80.36562
G1 X215.846 Y308.833 E80.37650
G1 X215.764 Y309.011 E80.38740
G1 X215.651 Y309.172 E80.39830
G1 X215.503 Y309.318 E80.40986
G1 X215.351 Y309.424 E80.42013
G1 X215.184 Y309.501 E80.43036
G1 X214.984 Y309.557 E80.44191
G1 X214.782 Y309.574 E80.45316
G1 X194.796 Y309.574 E81.56383
G1 X194.594 Y309.557 E81.57509
G1 X194.405 Y309.506 E81.58597
G1 X194.227 Y309.424 E81.59687
G1 X194.066 Y309.311 E81.60777
G1 X193.920 Y309.163 E81.61933
G1 X193.814 Y309.011 E81.62960
G1 X193.737 Y308.844 E81.63983
G1 X193.681 Y308.645 E81.65134
G1 X193.665 Y308.443 E81.66259
G1 X193.666 Y288.440 E82.77417
G1 Z7.150 F6000.000
G1 X193.684 Y288.243 E82.78514 F900.000
G1 X193.732 Y288.065 E82.79542
G1 X193.809 Y287.898 E82.80564
G1 X193.927 Y287.726 E82.81722
G1 X194.059 Y287.594 E82.82755
G1 X194.227 Y287.474 E82.83905
G1 X194.405 Y287.392 E82.84994
G1 X194.593 Y287.341 E82.86079
G1 X194.795 Y287.325 E82.87204
G1 X214.788 Y287.331 E83.98307
G1 X214.972 Y287.344 E83.99330
G1 X215.176 Y287.393 E84.00496
G1 X215.351 Y287.474 E84.01571
G1 X215.512 Y287.587 E84.02661
G1 X215.658 Y287.735 E84.03817
G1 X215.764 Y287.887 E84.04845
G1 X215.841 Y288.054 E84.05867
G1 X215.897 Y288.254 E84.07022
G1 X215.914 Y288.456 E84.08148
G1 X215.914 Y308.442 E85.19214
G1 X215.897 Y308.644 E85.20340
G1 X215.846 Y308.833 E85.21428
G1 X215.764 Y309.011 E85.22518
G1 X215.651 Y309.172 E85.23608
G1 X215.503 Y309.318 E85.24764
G1 X215.351 Y309.424 E85.25791
G1 X215.184 Y309.501 E85.26814
G1 X214.984 Y309.557 E85.27969
G1 X214.782 Y309.574 E85.29094
G1 X194.796 Y309.574 E86.40161
G1 X194.594 Y309.557 E86.41287
G1 X194.405 Y309.506 E86.42375
G1 X194.227 Y309.424 E86.43465
G1 X194.066 Y309.311 E86.44555
G1 X193.920 Y309.163 E86.45711
G1 X193.814 Y309.011 E86.46738
G1 X193.737 Y308.844 E86.47761
G1 X193.681 Y308.645 E86.48912
G1 X193.665 Y308.443 E86.50038
G1 X193.666 Y288.440 E87.61195
G1 Z7.550 F6000.000
G1 X193.684 Y288.243 E87.62292 F900.000
G1 X193.732 Y288.065 E87.63320
G1 X193.809 Y287.898 E87.64342
G1 X193.927 Y287.726 E87.65500
G1 X194.059 Y287.594 E87.66534
G1 X194.227 Y287.474 E87.67683
G1 X194.405 Y287.392 E87.68772
G1 X194.593 Y287.341 E87.69858
G1 X194.795 Y287.325 E87.70983
G1 X214.783 Y287.325 E88.82056
G1 X214.972 Y287.343 E88.83111
G1 X215.175 Y287.393 E88.84276
G1 X215.351 Y287.474 E88.85352
G1 X215.512 Y287.587 E88.86443
G1 X215.658 Y287.735 E88.87599
G1 X215.764 Y287.887 E88.88626
G1 X215.841 Y288.054 E88.89649
G1 X215.897 Y288.254 E88.90803
G1 X215.914 Y288.456 E88.91929
G1 X215.914 Y308.442 E90.02995
G1 X215.897 Y308.644 E90.04121
G1 X215.846 Y308.833 E90.05210
G1 X215.764 Y309.011 E90.06299
G1 X215.651 Y309.172 E90.07390
G1 X215.503 Y309.318 E90.08546
G1 X215.351 Y309.424 E90.09573
G1 X215.184 Y309.501 E90.10596
G1 X214.984 Y309.557 E90.11750
G1 X214.782 Y309.574 E90.12876
G1 X194.796 Y309.574 E91.23942
G1 X194.594 Y309.557 E91.25068
G1 X194.405 Y309.506 E91.26156
G1 X194.227 Y309.424 E91.27246
G1 X194.066 Y309.311 E91.28337
G1 X193.920 Y309.163 E91.29493
G1 X193.814 Y309.011 E91.30520
G1 X193.737 Y308.844 E91.31542
G1 X193.681 Y308.645 E91.32694
G1 X193.665 Y308.443 E91.33819
G1 X193.666 Y288.440 E92.44976
G1 Z7.950 F6000.000
G1 X193.684 Y288.243 E92.46073 F900.000
G1 X193.732 Y288.065 E92.47102
G1 X193.809 Y287.898 E92.48123
G1 X193.927 Y287.726 E92.49281
G1 X194.059 Y287.594 E92.50315
G1 X194.227 Y287.474 E92.51464
G1 X194.405 Y287.392 E92.52554
G1 X194.593 Y287.341 E92.53639
G1 X194.795 Y287.325 E92.54764
G1 X214.783 Y287.325 E93.65837
G1 X214.943 Y287.336 E93.66731
G1 X215.175 Y287.393 E93.68058
G1 X215.351 Y287.474 E93.69136
G1 X215.512 Y287.587 E93.70226
G1 X215.658 Y287.735 E93.71382
G1 X215.764 Y287.887 E93.72410
G1 X215.841 Y288.054 E93.73432
G1 X215.897 Y288.254 E93.74587
G1 X215.914 Y288.456 E93.75713
G1 X215.914 Y308.442 E94.86779
G1 X215.897 Y308.644 E94.87905
G1 X215.846 Y308.833 E94.88993
G1 X215.764 Y309.011 E94.90083
G1 X215.651 Y309.172 E94.91173
G1 X215.503 Y309.318 E94.92329
G1 X215.351 Y309.424 E94.93356
G1 X215.184 Y309.501 E94.94379
G1 X214.984 Y309.557 E94.95534
G1 X214.782 Y309.574 E94.96659
G1 X194.796 Y309.574 E96.07726
G1 X194.594 Y309.557 E96.08852
G1 X194.405 Y309.506 E96.09940
G1 X194.227 Y309.424 E96.11030
G1 X194.066 Y309.311 E96.12120
G1 X193.920 Y309.163 E96.13276
G1 X193.814 Y309.011 E96.14303
G1 X193.737 Y308.844 E96.15326
G1 X193.681 Y308.645 E96.16477
G1 X193.665 Y308.443 E96.17603
G1 X193.666 Y288.440 E97.28760
G1 Z8.350 F6000.000
G1 X193.684 Y288.243 E97.29857 F900.000
G1 X193.732 Y288.065 E97.30885
G1 X193.809 Y287.898 E97.31907
G1 X193.927 Y287.726 E97.33065
G1 X194.059 Y287.594 E97.34099
G1 X194.227 Y287.474 E97.35248
G1 X194.405 Y287.392 E97.36337
G1 X194.593 Y287.341 E97.37423
G1 X194.795 Y287.325 E97.38548
G1 X214.783 Y287.325 E98.49621
G1 X214.972 Y287.342 E98.50675
G1 X215.175 Y287.393 E98.51838
G1 X215.351 Y287.474 E98.52918
G1 X215.512 Y287.587 E98.54009
G1 X215.658 Y287.735 E98.55165
G1 X215.764 Y287.887 E98.56192
G1 X215.841 Y288.054 E98.57215
G1 X215.897 Y288.254 E98.58369
G1 X215.914 Y288.456 E98.59495
G1 X215.914 Y308.442 E99.70561
G1 X215.897 Y308.644 E99.71687
G1 X215.846 Y308.833 E99.72775
G1 X215.764 Y309.011 E99.73865
G1 X215.651 Y309.172 E99.74956
G1 X215.503 Y309.318 E99.76112
G1 X215.351 Y309.424 E99.77139
G1 X215.184 Y309.501 E99.78162
G1 X214.984 Y309.557 E99.79316
G1 X214.782 Y309.574 E99.80442
G1 X194.796 Y309.574 E100.91508
G1 X194.594 Y309.557 E100.92634
G1 X194.405 Y309.506 E100.93722
G1 X194.227 Y309.424 E100.94812
G1 X194.066 Y309.311 E100.95902
G1 X193.920 Y309.163 E100.97059
G1 X193.814 Y309.011 E100.98086
G1 X193.737 Y308.844 E100.99108
G1 X193.681 Y308.645 E101.00260
G1 X193.665 Y308.443 E101.01385
G1 X193.666 Y288.440 E102.12542
G1 Z8.750 F6000.000
G1 X193.684 Y288.243 E102.13639 F900.000
G1 X193.732 Y288.065 E102.14668
G1 X193.809 Y287.898 E102.15689
G1 X193.927 Y287.726 E102.16847
G1 X194.059 Y287.594 E102.17881
G1 X194.227 Y287.474 E102.19030
G1 X194.405 Y287.392 E102.20120
G1 X194.593 Y287.341 E102.21205
G1 X194.795 Y287.325 E102.22330
G1 X214.783 Y287.325 E103.33403
G1 X214.972 Y287.341 E103.34458
G1 X215.175 Y287.393 E103.35619
G1 X215.351 Y287.474 E103.36701
G1 X215.512 Y287.587 E103.37791
G1 X215.658 Y287.735 E103.38947
G1 X215.764 Y287.887 E103.39975
G1 X215.841 Y288.054 E103.40997
G1 X215.897 Y288.254 E103.42152
G1 X215.914 Y288.456 E103.43278
G1 X215.914 Y308.442 E104.54344
G1 X215.897 Y308.644 E104.55470
G1 X215.846 Y308.833 E104.56558
G1 X215.764 Y309.011 E104.57648
G1 X215.651 Y309.172 E104.58738
G1 X215.503 Y309.318 E104.59894
G1 X215.351 Y309.424 E104.60921
G1 X215.184 Y309.501 E104.61944
G1 X214.984 Y309.557 E104.63099
G1 X214.782 Y309.574 E104.64224
G1 X194.796 Y309.574 E105.75291
G1 X194.594 Y309.557 E105.76417
G1 X194.405 Y309.506 E105.77505
G1 X194.227 Y309.424 E105.78595
G1 X194.066 Y309.311 E105.79685
G1 X193.920 Y309.163 E105.80841
G1 X193.814 Y309.011 E105.81868
G1 X193.737 Y308.844 E105.82891
G1 X193.681 Y308.645 E105.84042
G1 X193.665 Y308.443 E105.85168
G1 X193.666 Y288.440 E106.96325
G1 Z9.150 F6000.000
G1 X193.684 Y288.243 E106.97422 F900.000
G1 X193.732 Y288.065 E106.98450
G1 X193.809 Y287.898 E106.99472
G1 X193.927 Y287.726 E107.00630
G1 X194.059 Y287.594 E107.01664
G1 X194.227 Y287.474 E107.02813
G1 X194.405 Y287.392 E107.03902
G1 X194.593 Y287.341 E107.04988
G1 X194.795 Y287.325 E107.06113
G1 X214.783 Y287.325 E108.17186
G1 X214.972 Y287.341 E108.18240
G1 X215.174 Y287.392 E108.19401
G1 X215.351 Y287.474 E108.20484
G1 X215.512 Y287.587 E108.21575
G1 X215.658 Y287.735 E108.22731
G1 X215.764 Y287.887 E108.23758
G1 X215.841 Y288.054 E108.24781
G1 X215.897 Y288.254 E108.25935
G1 X215.914 Y288.456 E108.27061
G1 X215.914 Y308.442 E109.38127
G1 X215.897 Y308.644 E109.39253
G1 X215.846 Y308.833 E109.40342
G1 X215.764 Y309.011 E109.41431
G1 X215.651 Y309.172 E109.42522
G1 X215.503 Y309.318 E109.43678
G1 X215.351 Y309.424 E109.44705
G1 X215.184 Y309.501 E109.45728
G1 X214.984 Y309.557 E109.46882
G1 X214.782 Y309.574 E109.48008
G1 X194.796 Y309.574 E110.59074
G1 X194.594 Y309.557 E110.60200
G1 X194.405 Y309.506 E110.61288
G1 X194.227 Y309.424 E110.62378
G1 X194.066 Y309.311 E110.63469
G1 X193.920 Y309.163 E110.64625
G1 X193.814 Y309.011 E110.65652
G1 X193.737 Y308.844 E110.66674
G1 X193.681 Y308.645 E110.67826
G1 X193.665 Y308.443 E110.68951
G1 X193.666 Y288.440 E111.80108
G1 Z9.550 F6000.000
G1 X193.684 Y288.243 E111.81205 F900.000
G1 X193.732 Y288.065 E111.82234
G1 X193.809 Y287.898 E111.83255
G1 X193.927 Y287.726 E111.84413
G1 X194.059 Y287.594 E111.85447
G1 X194.227 Y287.474 E111.86596
G1 X194.405 Y287.392 E111.87686
G1 X194.593 Y287.341 E111.88771
G1 X194.795 Y287.325 E111.89896
G1 X214.783 Y287.325 E113.00969
G1 X214.972 Y287.340 E113.02024
G1 X215.174 Y287.392 E113.03183
G1 X215.351 Y287.474 E113.04268
G1 X215.512 Y287.587 E113.05359
G1 X215.658 Y287.735 E113.06515
G1 X215.764 Y287.887 E113.07542
G1 X215.841 Y288.054 E113.08565
G1 X215.897 Y288.254 E113.09719
G1 X215.914 Y288.456 E113.10845
G1 X215.914 Y308.442 E114.21912
G1 X215.897 Y308.644 E114.23037
G1 X215.846 Y308.833 E114.24126
G1 X215.764 Y309.011 E114.25215
G1 X215.651 Y309.172 E114.26306
G1 X215.512 Y309.311 E114.27399
G1 X215.351 Y309.424 E114.28490
G1 X215.184 Y309.501 E114.29513
G1 X214.984 Y309.557 E114.30667
G1 X214.782 Y309.574 E114.31793
G1 X194.796 Y309.574 E115.42859
G1 X194.594 Y309.557 E115.43985
G1 X194.405 Y309.506 E115.45073
G1 X194.227 Y309.424 E115.46163
G1 X194.066 Y309.311 E115.47254
G1 X193.920 Y309.163 E115.48410
G1 X193.814 Y309.011 E115.49437
G1 X193.737 Y308.844 E115.50459
G1 X193.681 Y308.645 E115.51611
G1 X193.665 Y308.443 E115.52736
G1 X193.666 Y288.440 E116.63893
G1 Z9.950 F6000.000
G1 X193.684 Y288.243 E116.64990 F900.000
G1 X193.732 Y288.065 E116.66019
G1 X193.809 Y287.898 E116.67040
G1 X193.927 Y287.726 E116.68198
G1 X194.059 Y287.594 E116.69232
G1 X194.227 Y287.474 E116.70381
G1 X194.405 Y287.392 E116.71471
G1 X194.593 Y287.341 E116.72556
G1 X194.795 Y287.325 E116.73681
G1 X214.783 Y287.325 E117.84754
G1 X214.979 Y287.341 E117.85851
G1 X215.173 Y287.392 E117.86966
G1 X215.351 Y287.474 E117.88054
G1 X215.512 Y287.587 E117.89144
G1 X215.658 Y287.735 E117.90300
G1 X215.764 Y287.887 E117.91327
G1 X215.841 Y288.054 E117.92350
G1 X215.897 Y288.254 E117.93505
G1 X215.914 Y288.456 E117.94631
G1 X215.914 Y308.442 E119.05697
G1 X215.897 Y308.644 E119.06823
G1 X215.846 Y308.833 E119.07911
G1 X215.764 Y309.011 E119.09001
G1 X215.651 Y309.172 E119.10091
G1 X215.503 Y309.318 E119.11247
G1 X215.351 Y309.424 E119.12274
G1 X215.184 Y309.501 E119.13297
G1 X214.984 Y309.557 E119.14452
G1 X214.782 Y309.574 E119.15577
G1 X194.796 Y309.574 E120.26644
G1 X194.594 Y309.557 E120.27770
G1 X194.405 Y309.506 E120.28858
G1 X194.227 Y309.424 E120.29948
G1 X194.066 Y309.311 E120.31038
G1 X193.920 Y309.163 E120.32194
G1 X193.814 Y309.011 E120.33221
G1 X193.737 Y308.844 E120.34244
G1 X193.681 Y308.645 E120.35395
G1 X193.665 Y308.443 E120.36520
G1 X193.666 Y288.440 E121.47678
G1 E120.47678 F2400.00000
G92 E0
M107
M104 S0 ; turn off temperature
G28 X0 ; home X axis
M84 ; disable motors
; filament used = 126.9mm (0.3cm3)
; avoid_crossing_perimeters = 0
; bed_shape = 0x0,393.7x0,393.7x152,0x152
; bed_temperature = 0
; before_layer_gcode =
; bridge_acceleration = 0
; bridge_fan_speed = 100
; brim_width = 0
; complete_objects = 0
; cooling = 1
; default_acceleration = 0
; disable_fan_first_layers = 3
; duplicate_distance = 6
; end_gcode = M104 S0 ; turn off temperature\nG28 X0 ; home X axis\nM84 ; disable motors\n
; extruder_clearance_height = 20
; extruder_clearance_radius = 20
; extruder_offset = 0x0
; extrusion_axis = E
; extrusion_multiplier = 1
; fan_always_on = 0
; fan_below_layer_time = 60
; filament_colour = #FFFFFF
; filament_diameter = 1.75
; first_layer_acceleration = 0
; first_layer_bed_temperature = 0
; first_layer_extrusion_width = 120%
; first_layer_speed = 20
; first_layer_temperature = 210
; gcode_arcs = 0
; gcode_comments = 0
; gcode_flavor = reprap
; infill_acceleration = 0
; infill_first = 0
; layer_gcode =
; max_fan_speed = 100
; max_print_speed = 60
; max_volumetric_speed = 0
; min_fan_speed = 35
; min_print_speed = 10
; min_skirt_length = 0
; notes =
; nozzle_diameter = 0.4
; only_retract_when_crossing_perimeters = 1
; ooze_prevention = 0
; output_filename_format = [input_filename_base].gcode
; perimeter_acceleration = 0
; post_process =
; pressure_advance = 0
; resolution = 0
; retract_before_travel = 2
; retract_layer_change = 0
; retract_length = 1
; retract_length_toolchange = 10
; retract_lift = 0
; retract_restart_extra = 0
; retract_restart_extra_toolchange = 0
; retract_speed = 40
; skirt_distance = 6
; skirt_height = 1
; skirts = 1
; slowdown_below_layer_time = 5
; spiral_vase = 0
; standby_temperature_delta = -5
; start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\n
; temperature = 200
; threads = 2
; toolchange_gcode =
; travel_speed = 100
; use_firmware_retraction = 0
; use_relative_e_distances = 0
; use_volumetric_e = 0
; vibration_limit = 0
; wipe = 0
; z_offset = 0
; dont_support_bridges = 1
; extrusion_width = 0.42
; first_layer_height = 0.35
; infill_only_where_needed = 0
; interface_shells = 0
; layer_height = 0.4
; raft_layers = 0
; seam_position = aligned
; support_material = 0
; support_material_angle = 0
; support_material_contact_distance = 0.2
; support_material_enforce_layers = 0
; support_material_extruder = 1
; support_material_extrusion_width = 0
; support_material_interface_extruder = 1
; support_material_interface_layers = 3
; support_material_interface_spacing = 0
; support_material_interface_speed = 100%
; support_material_pattern = pillars
; support_material_spacing = 2.5
; support_material_speed = 60
; support_material_threshold = 0
; xy_size_compensation = 0
; bottom_solid_layers = 3
; bridge_flow_ratio = 1
; bridge_speed = 60
; external_fill_pattern = rectilinear
; external_perimeter_extrusion_width = 0
; external_perimeter_speed = 50%
; external_perimeters_first = 0
; extra_perimeters = 1
; fill_angle = 45
; fill_density = 40%
; fill_pattern = honeycomb
; gap_fill_speed = 20
; infill_every_layers = 1
; infill_extruder = 1
; infill_extrusion_width = 0
; infill_overlap = 15%
; infill_speed = 20
; overhangs = 1
; perimeter_extruder = 1
; perimeter_extrusion_width = 0
; perimeter_speed = 30
; perimeters = 3
; small_perimeter_speed = 15
; solid_infill_below_area = 70
; solid_infill_every_layers = 0
; solid_infill_extruder = 1
; solid_infill_extrusion_width = 0
; solid_infill_speed = 20
; thin_walls = 1
; top_infill_extrusion_width = 0
; top_solid_infill_speed = 15
; top_solid_layers = 3
Edited 1 time(s). Last edit at 12/16/2015 07:48AM by drighter.
Re: Printing blobs
December 16, 2015 07:49AM
20mm cube gcode attached
Re: Printing blobs
December 16, 2015 07:54AM
By greasing the slides and threaded rod I've been able to increase the max feed rate some.
#define DEFAULT_MAX_FEEDRATE {7, 8, 18, 2}
Re: Printing blobs
December 17, 2015 06:27AM
I see nothing wrong with your gcode. The speeds at which the slicer tries to move are too high, but that's rather a fine tuning thing as the firmware settings will limit the max speeds.
drighter
This would be 6000mm/min / 60s = 100mm/s
The maximum sensible speed in mm/min for your printer would be 18mm/s * 60s = 420mm/min.
You said that while manually driving the axis they all move correctly. Have you tried moving multiple axes at the same time.
For example do homing and then send "G1 X50 Y50 Z5 F420" through Pronterface or Repetier. Maybe there is some interference in the drivers when axes are driven simultaneously.
Edited 2 time(s). Last edit at 12/17/2015 06:29AM by coldlizard.
Re: Printing blobs
December 19, 2015 09:01PM
By adjusting my bed size, I've been able to get square prints, but now everything after the first layer is either collapsing, missing, or not adhering to the other layers? Here is my G-code from slicer.
; generated by Slic3r 1.2.9 on 2015-12-19 at 20:58:23
M107
M104 S208 ; set temperature
G28 ; home all axes
M109 S208 ; wait for temperature to be reached
G92 E0
G1 Z0.200 F6000.000
G1 E-1.00000 F1200.00000
G92 E0
G1 X171.510 Y57.815 F6000.000
G1 E1.00000 F1200.00000
G1 X172.649 Y55.908 E1.04009 F1200.000
G1 X174.387 Y54.524 E1.08019
G1 X177.330 Y53.783 E1.13497
G1 X197.330 Y53.783 E1.49598
G1 X199.515 Y54.180 E1.53607
G1 X201.422 Y55.319 E1.57616 F1200.000
G1 X202.806 Y57.057 E1.61626
G1 X203.547 Y60.000 E1.67104
G1 X203.547 Y80.000 E2.03205
G1 X203.150 Y82.185 E2.07214
G1 X202.011 Y84.092 E2.11223
G1 X200.273 Y85.476 E2.15233
G1 X197.330 Y86.217 E2.20712
G1 X177.330 Y86.217 E2.56812
G1 X175.145 Y85.820 E2.60821
G1 X173.238 Y84.681 E2.64831
G1 X171.854 Y82.943 E2.68840
G1 X171.113 Y80.000 E2.74319
G1 X171.113 Y60.000 E3.10419
G1 X171.499 Y57.874 E3.14320
G1 E2.14320 F1200.00000
G92 E0
G1 X196.766 Y79.436 F6000.000
G1 X177.894 Y79.436 E1.34064 F1200.000
G1 X177.894 Y60.564 E1.68128
G1 X196.766 Y60.564 E2.02192
G1 X196.766 Y79.376 E2.36147
G1 X196.983 Y79.653 F6000.000
G1 X177.677 Y79.653 E2.70995 F1200.000
G1 X177.677 Y60.347 E3.05842
G1 X196.983 Y60.347 E3.40690
G1 X196.983 Y79.593 E3.75429
G1 X197.200 Y79.870 F6000.000
G1 X177.460 Y79.870 E4.11060 F1200.000
G1 X177.460 Y60.130 E4.46691
G1 X197.200 Y60.130 E4.82322
G1 X197.200 Y79.810 E5.17845
G1 X196.854 Y79.670 F6000.000
G1 X196.647 Y60.815 F6000.000
G1 X196.515 Y60.683 E5.18184 F1200.000
G1 X196.207 Y60.683 E5.18743
G1 X196.647 Y61.123 E5.19873
G1 X196.647 Y61.431 E5.20432
G1 X195.899 Y60.683 E5.22352
G1 X195.590 Y60.683 E5.22911
G1 X196.647 Y61.740 E5.25622
G1 X196.647 Y62.048 E5.26181
G1 X195.282 Y60.683 E5.29683
G1 X194.973 Y60.683 E5.30242
G1 X196.647 Y62.357 E5.34534
G1 X196.647 Y62.665 E5.35094
G1 X194.665 Y60.683 E5.40177
G1 X194.357 Y60.683 E5.40736
G1 X196.647 Y62.973 E5.46610
G1 X196.647 Y63.282 E5.47169
G1 X194.048 Y60.683 E5.53834
G1 X193.740 Y60.683 E5.54393
G1 X196.647 Y63.590 E5.61848
G1 X196.647 Y63.898 E5.62407
G1 X193.432 Y60.683 E5.70653
G1 X193.123 Y60.683 E5.71213
G1 X196.647 Y64.207 E5.80249
G1 X196.647 Y64.515 E5.80809
G1 X192.815 Y60.683 E5.90636
G1 X192.506 Y60.683 E5.91195
G1 X196.647 Y64.824 E6.01814
G1 X196.647 Y65.132 E6.02373
G1 X192.198 Y60.683 E6.13782
G1 X191.890 Y60.683 E6.14341
G1 X196.647 Y65.440 E6.26541
G1 X196.647 Y65.749 E6.27100
G1 X191.581 Y60.683 E6.40091
G1 X191.273 Y60.683 E6.40650
G1 X196.647 Y66.057 E6.54431
G1 X196.647 Y66.366 E6.54990
G1 X190.964 Y60.683 E6.69562
G1 X190.656 Y60.683 E6.70121
G1 X196.647 Y66.674 E6.85484
G1 X196.647 Y66.982 E6.86043
G1 X190.348 Y60.683 E7.02197
G1 X190.039 Y60.683 E7.02756
G1 X196.647 Y67.291 E7.19700
G1 X196.647 Y67.599 E7.20259
G1 X189.731 Y60.683 E7.37994
G1 X189.423 Y60.683 E7.38553
G1 X196.647 Y67.907 E7.57079
G1 X196.647 Y68.216 E7.57638
G1 X189.114 Y60.683 E7.76955
G1 X188.806 Y60.683 E7.77514
G1 X196.647 Y68.524 E7.97621
G1 X196.647 Y68.833 E7.98180
G1 X188.497 Y60.683 E8.19078
G1 X188.189 Y60.683 E8.19637
G1 X196.647 Y69.141 E8.41326
G1 X196.647 Y69.449 E8.41885
G1 X187.881 Y60.683 E8.64365
G1 X187.572 Y60.683 E8.64924
G1 X196.647 Y69.758 E8.88194
G1 X196.647 Y70.066 E8.88753
G1 X187.264 Y60.683 E9.12814
G1 X186.956 Y60.683 E9.13373
G1 X196.647 Y70.374 E9.38225
G1 X196.647 Y70.683 E9.38784
G1 X186.647 Y60.683 E9.64427
G1 X186.339 Y60.683 E9.64986
G1 X196.647 Y70.991 E9.91419
G1 X196.647 Y71.300 E9.91978
G1 X186.030 Y60.683 E10.19202
G1 X185.722 Y60.683 E10.19761
G1 X196.647 Y71.608 E10.47776
G1 X196.647 Y71.916 E10.48335
G1 X185.414 Y60.683 E10.77140
G1 X185.105 Y60.683 E10.77699
G1 X196.647 Y72.225 E11.07295
G1 X196.647 Y72.533 E11.07855
G1 X184.797 Y60.683 E11.38241
G1 X184.489 Y60.683 E11.38801
G1 X196.647 Y72.841 E11.69978
G1 X196.647 Y73.150 E11.70537
G1 X184.180 Y60.683 E12.02506
G1 X183.872 Y60.683 E12.03065
G1 X196.647 Y73.458 E12.35824
G1 X196.647 Y73.767 E12.36383
G1 X183.563 Y60.683 E12.69933
G1 X183.255 Y60.683 E12.70492
G1 X196.647 Y74.075 E13.04832
G1 X196.647 Y74.383 E13.05392
G1 X182.947 Y60.683 E13.40523
G1 X182.638 Y60.683 E13.41082
G1 X196.647 Y74.692 E13.77004
G1 X196.647 Y75.000 E13.77563
G1 X182.330 Y60.683 E14.14276
G1 X182.021 Y60.683 E14.14835
G1 X196.647 Y75.309 E14.52339
G1 X196.647 Y75.617 E14.52898
G1 X181.713 Y60.683 E14.91192
G1 X181.405 Y60.683 E14.91751
G1 X196.647 Y75.925 E15.30836
G1 X196.647 Y76.234 E15.31395
G1 X181.096 Y60.683 E15.71271
G1 X180.788 Y60.683 E15.71830
G1 X196.647 Y76.542 E16.12497
G1 X196.647 Y76.850 E16.13056
G1 X180.480 Y60.683 E16.54513
G1 X180.171 Y60.683 E16.55072
G1 X196.647 Y77.159 E16.97320
G1 X196.647 Y77.467 E16.97879
G1 X179.863 Y60.683 E17.40918
G1 X179.554 Y60.683 E17.41477
G1 X196.647 Y77.776 E17.85306
G1 X196.647 Y78.084 E17.85866
G1 X179.246 Y60.683 E18.30486
G1 X178.938 Y60.683 E18.31045
G1 X196.647 Y78.392 E18.76456
G1 X196.647 Y78.701 E18.77015
G1 X178.629 Y60.683 E19.23217
G1 X178.321 Y60.683 E19.23776
G1 X196.647 Y79.009 E19.70768
G1 X196.627 Y79.297 E19.71292
G1 X178.033 Y60.703 E20.18973
G1 X178.013 Y60.991 E20.19497
G1 X196.339 Y79.317 E20.66489
G1 X196.031 Y79.317 E20.67048
G1 X178.013 Y61.299 E21.13249
G1 X178.013 Y61.608 E21.13809
G1 X195.722 Y79.317 E21.59219
G1 X195.414 Y79.317 E21.59778
G1 X178.013 Y61.916 E22.04398
G1 X178.013 Y62.225 E22.04957
G1 X195.105 Y79.317 E22.48787
G1 X194.797 Y79.317 E22.49346
G1 X178.013 Y62.533 E22.92384
G1 X178.013 Y62.841 E22.92943
G1 X194.489 Y79.317 E23.35191
G1 X194.180 Y79.317 E23.35750
G1 X178.013 Y63.150 E23.77207
G1 X178.013 Y63.458 E23.77766
G1 X193.872 Y79.317 E24.18432
G1 X193.564 Y79.317 E24.18992
G1 X178.013 Y63.766 E24.58867
G1 X178.013 Y64.075 E24.59426
G1 X193.255 Y79.317 E24.98511
G1 X192.947 Y79.317 E24.99070
G1 X178.013 Y64.383 E25.37364
G1 X178.013 Y64.692 E25.37923
G1 X192.638 Y79.317 E25.75426
G1 X192.330 Y79.317 E25.75985
G1 X178.013 Y65.000 E26.12698
G1 X178.013 Y65.308 E26.13257
G1 X192.022 Y79.317 E26.49179
G1 X191.713 Y79.317 E26.49738
G1 X178.013 Y65.617 E26.84869
G1 X178.013 Y65.925 E26.85428
G1 X191.405 Y79.317 E27.19768
G1 X191.097 Y79.317 E27.20328
G1 X178.013 Y66.233 E27.53877
G1 X178.013 Y66.542 E27.54436
G1 X190.788 Y79.317 E27.87195
G1 X190.480 Y79.317 E27.87754
G1 X178.013 Y66.850 E28.19722
G1 X178.013 Y67.159 E28.20281
G1 X190.171 Y79.317 E28.51459
G1 X189.863 Y79.317 E28.52018
G1 X178.013 Y67.467 E28.82404
G1 X178.013 Y67.775 E28.82964
G1 X189.555 Y79.317 E29.12559
G1 X189.246 Y79.317 E29.13119
G1 X178.013 Y68.084 E29.41924
G1 X178.013 Y68.392 E29.42483
G1 X188.938 Y79.317 E29.70497
G1 X188.629 Y79.317 E29.71056
G1 X178.013 Y68.701 E29.98280
G1 X178.013 Y69.009 E29.98839
G1 X188.321 Y79.317 E30.25272
G1 X188.013 Y79.317 E30.25831
G1 X178.013 Y69.317 E30.51473
G1 X178.013 Y69.626 E30.52032
G1 X187.704 Y79.317 E30.76884
G1 X187.396 Y79.317 E30.77443
G1 X178.013 Y69.934 E31.01504
G1 X178.013 Y70.242 E31.02063
G1 X187.088 Y79.317 E31.25333
G1 X186.779 Y79.317 E31.25892
G1 X178.013 Y70.551 E31.48371
G1 X178.013 Y70.859 E31.48930
G1 X186.471 Y79.317 E31.70619
G1 X186.162 Y79.317 E31.71178
G1 X178.013 Y71.168 E31.92075
G1 X178.013 Y71.476 E31.92634
G1 X185.854 Y79.317 E32.12741
G1 X185.546 Y79.317 E32.13301
G1 X178.013 Y71.784 E32.32617
G1 X178.013 Y72.093 E32.33176
G1 X185.237 Y79.317 E32.51701
G1 X184.929 Y79.317 E32.52261
G1 X178.013 Y72.401 E32.69995
G1 X178.013 Y72.709 E32.70554
G1 X184.621 Y79.317 E32.87498
G1 X184.312 Y79.317 E32.88058
G1 X178.013 Y73.018 E33.04211
G1 X178.013 Y73.326 E33.04770
G1 X184.004 Y79.317 E33.20132
G1 X183.695 Y79.317 E33.20692
G1 X178.013 Y73.635 E33.35263
G1 X178.013 Y73.943 E33.35823
G1 X183.387 Y79.317 E33.49604
G1 X183.079 Y79.317 E33.50163
G1 X178.013 Y74.251 E33.63153
G1 X178.013 Y74.560 E33.63712
G1 X182.770 Y79.317 E33.75912
G1 X182.462 Y79.317 E33.76471
G1 X178.013 Y74.868 E33.87880
G1 X178.013 Y75.176 E33.88439
G1 X182.154 Y79.317 E33.99057
G1 X181.845 Y79.317 E33.99616
G1 X178.013 Y75.485 E34.09443
G1 X178.013 Y75.793 E34.10002
G1 X181.537 Y79.317 E34.19039
G1 X181.228 Y79.317 E34.19598
G1 X178.013 Y76.102 E34.27844
G1 X178.013 Y76.410 E34.28403
G1 X180.920 Y79.317 E34.35858
G1 X180.612 Y79.317 E34.36417
G1 X178.013 Y76.718 E34.43082
G1 X178.013 Y77.027 E34.43641
G1 X180.303 Y79.317 E34.49515
G1 X179.995 Y79.317 E34.50074
G1 X178.013 Y77.335 E34.55157
G1 X178.013 Y77.644 E34.55716
G1 X179.686 Y79.317 E34.60008
G1 X179.378 Y79.317 E34.60567
G1 X178.013 Y77.952 E34.64068
G1 X178.013 Y78.260 E34.64628
G1 X179.070 Y79.317 E34.67338
G1 X178.761 Y79.317 E34.67897
G1 X178.013 Y78.569 E34.69817
G1 X178.013 Y78.877 E34.70376
G1 X178.453 Y79.317 E34.71506
G1 X178.145 Y79.317 E34.72065
G1 X178.013 Y79.185 E34.72403
M104 S202 ; set temperature
G1 Z0.600 F6000.000
G1 X196.452 Y79.122 F6000.000
G1 X178.208 Y79.122 E35.73783 F1080.000
G1 X178.208 Y60.878 E36.75163
G1 X196.452 Y60.878 E37.76543
G1 X196.452 Y79.062 E38.77590
G1 X196.786 Y79.456 F6000.000
G1 X177.874 Y79.456 E39.82684 F1080.000
G1 X177.874 Y60.544 E40.87778
G1 X196.786 Y60.544 E41.92872
G1 X196.786 Y79.396 E42.97632
G1 X197.120 Y79.790 F6000.000
G1 X177.540 Y79.790 E44.06440 F540.000
G1 X177.540 Y60.210 E45.15248
G1 X197.120 Y60.210 E46.24056
G1 X197.120 Y79.730 E47.32530
G1 X196.774 Y79.590 F6000.000
G1 X196.077 Y78.929 F6000.000
G1 X196.259 Y78.747 E47.33974 F1080.000
G1 X196.259 Y78.269 E47.36658
G1 X195.599 Y78.929 E47.41897
G1 X195.121 Y78.929 E47.44581
G1 X196.259 Y77.791 E47.53615
G1 X196.259 Y77.314 E47.56299
G1 X194.644 Y78.929 E47.69128
G1 X194.166 Y78.929 E47.71812
G1 X196.259 Y76.836 E47.88436
G1 X196.259 Y76.358 E47.91120
G1 X193.688 Y78.929 E48.11539
G1 X193.211 Y78.929 E48.14223
G1 X196.259 Y75.881 E48.38438
G1 X196.259 Y75.403 E48.41121
G1 X192.733 Y78.929 E48.69131
G1 X192.255 Y78.929 E48.71815
G1 X196.259 Y74.925 E49.03620
G1 X196.259 Y74.447 E49.06304
G1 X191.777 Y78.929 E49.41904
G1 X191.300 Y78.929 E49.44587
G1 X196.259 Y73.970 E49.83983
G1 X196.259 Y73.492 E49.86666
G1 X190.822 Y78.929 E50.29857
G1 X190.344 Y78.929 E50.32540
G1 X196.259 Y73.014 E50.79526
G1 X196.259 Y72.537 E50.82210
G1 X189.867 Y78.929 E51.32990
G1 X189.389 Y78.929 E51.35674
G1 X196.259 Y72.059 E51.90250
G1 X196.259 Y71.581 E51.92933
G1 X188.911 Y78.929 E52.51304
G1 X188.433 Y78.929 E52.53988
G1 X196.259 Y71.103 E53.16154
G1 X196.259 Y70.626 E53.18838
G1 X187.956 Y78.929 E53.84799
G1 X187.478 Y78.929 E53.87482
G1 X196.259 Y70.148 E54.57239
G1 X196.259 Y69.670 E54.59922
G1 X187.000 Y78.929 E55.33474
G1 X186.523 Y78.929 E55.36157
G1 X196.259 Y69.193 E56.13504
G1 X196.259 Y68.715 E56.16188
G1 X186.045 Y78.929 E56.97329
G1 X185.567 Y78.929 E57.00013
G1 X196.259 Y68.237 E57.84950
G1 X196.259 Y67.759 E57.87633
G1 X185.089 Y78.929 E58.76365
G1 X184.612 Y78.929 E58.79049
G1 X196.259 Y67.282 E59.71576
G1 X196.259 Y66.804 E59.74260
G1 X184.134 Y78.929 E60.70582
G1 X183.656 Y78.929 E60.73266
G1 X196.259 Y66.326 E61.73383
G1 X196.259 Y65.849 E61.76066
G1 X183.179 Y78.929 E62.79979
G1 X182.701 Y78.929 E62.82663
G1 X196.259 Y65.371 E63.90370
G1 X196.259 Y64.893 E63.93054
G1 X182.223 Y78.929 E65.04557
G1 X181.745 Y78.929 E65.07240
G1 X196.259 Y64.415 E66.22538
G1 X196.259 Y63.938 E66.25222
G1 X181.268 Y78.929 E67.44315
G1 X180.790 Y78.929 E67.46998
G1 X196.259 Y63.460 E68.69887
G1 X196.259 Y62.982 E68.72570
G1 X180.312 Y78.929 E69.99253
G1 X179.835 Y78.929 E70.01937
G1 X196.259 Y62.505 E71.32415
G1 X196.259 Y62.027 E71.35099
G1 X179.357 Y78.929 E72.69373
G1 X178.879 Y78.929 E72.72056
G1 X196.259 Y61.549 E74.10125
G1 X196.239 Y61.091 E74.12698
G1 X178.421 Y78.909 E75.54244
G1 X178.401 Y78.451 E75.56818
G1 X195.781 Y61.071 E76.94887
G1 X195.303 Y61.071 E76.97570
G1 X178.401 Y77.973 E78.31844
G1 X178.401 Y77.495 E78.34527
G1 X194.825 Y61.071 E79.65005
G1 X194.348 Y61.071 E79.67689
G1 X178.401 Y77.018 E80.94372
G1 X178.401 Y76.540 E80.97056
G1 X193.870 Y61.071 E82.19944
G1 X193.392 Y61.071 E82.22627
G1 X178.401 Y76.062 E83.41720
G1 X178.401 Y75.585 E83.44404
G1 X192.915 Y61.071 E84.59701
G1 X192.437 Y61.071 E84.62385
G1 X178.401 Y75.107 E85.73887
G1 X178.401 Y74.629 E85.76571
G1 X191.959 Y61.071 E86.84278
G1 X191.481 Y61.071 E86.86962
G1 X178.401 Y74.151 E87.90874
G1 X178.401 Y73.674 E87.93558
G1 X191.004 Y61.071 E88.93675
G1 X190.526 Y61.071 E88.96359
G1 X178.401 Y73.196 E89.92681
G1 X178.401 Y72.718 E89.95364
G1 X190.048 Y61.071 E90.87891
G1 X189.571 Y61.071 E90.90575
G1 X178.401 Y72.241 E91.79307
G1 X178.401 Y71.763 E91.81990
G1 X189.093 Y61.071 E92.66927
G1 X188.615 Y61.071 E92.69610
G1 X178.401 Y71.285 E93.50752
G1 X178.401 Y70.807 E93.53436
G1 X188.137 Y61.071 E94.30782
G1 X187.660 Y61.071 E94.33466
G1 X178.401 Y70.330 E95.07017
G1 X178.401 Y69.852 E95.09700
G1 X187.182 Y61.071 E95.79457
G1 X186.704 Y61.071 E95.82140
G1 X178.401 Y69.374 E96.48101
G1 X178.401 Y68.897 E96.50785
G1 X186.227 Y61.071 E97.12951
G1 X185.749 Y61.071 E97.15634
G1 X178.401 Y68.419 E97.74005
G1 X178.401 Y67.941 E97.76689
G1 X185.271 Y61.071 E98.31264
G1 X184.793 Y61.071 E98.33948
G1 X178.401 Y67.463 E98.84728
G1 X178.401 Y66.986 E98.87412
G1 X184.316 Y61.071 E99.34397
G1 X183.838 Y61.071 E99.37081
G1 X178.401 Y66.508 E99.80271
G1 X178.401 Y66.030 E99.82955
G1 X183.360 Y61.071 E100.22350
G1 X182.883 Y61.071 E100.25033
G1 X178.401 Y65.553 E100.60633
G1 X178.401 Y65.075 E100.63317
G1 X182.405 Y61.071 E100.95122
G1 X181.927 Y61.071 E100.97805
G1 X178.401 Y64.597 E101.25815
G1 X178.401 Y64.119 E101.28499
G1 X181.449 Y61.071 E101.52713
G1 X180.972 Y61.071 E101.55397
G1 X178.401 Y63.642 E101.75816
G1 X178.401 Y63.164 E101.78500
G1 X180.494 Y61.071 E101.95124
G1 X180.016 Y61.071 E101.97808
G1 X178.401 Y62.686 E102.10637
G1 X178.401 Y62.209 E102.13321
G1 X179.539 Y61.071 E102.22355
G1 X179.061 Y61.071 E102.25038
G1 X178.401 Y61.731 E102.30277
G1 X178.401 Y61.253 E102.32961
G1 X178.583 Y61.071 E102.34405
G1 Z1.000 F6000.000
G1 E101.34405 F1200.00000
G92 E0
G1 X178.208 Y79.122 E2.01380 F1080.000
G1 X178.208 Y60.878 E3.02760
G1 X196.452 Y60.878 E4.04140
G1 X196.452 Y79.062 E5.05187
G1 X177.874 Y79.456 E6.10281 F1080.000
G1 X177.874 Y60.544 E7.15375
G1 X196.786 Y60.544 E8.20469
G1 X196.786 Y79.396 E9.25229
G1 X177.540 Y79.790 E10.34037 F540.000
G1 X177.540 Y60.210 E11.42845
G1 X197.120 Y60.210 E12.51653
G1 X197.120 Y79.730 E13.60127
G1 E12.60127 F1200.00000
G92 E0
G1 X196.259 Y61.253 F6000.000
G1 X196.077 Y61.071 E1.01444 F900.000
G1 X195.599 Y61.071 E1.04128
G1 X196.259 Y61.731 E1.09367
G1 X196.259 Y62.209 E1.12050
G1 X195.121 Y61.071 E1.21085
G1 X194.644 Y61.071 E1.23768
G1 X196.259 Y62.686 E1.36598
G1 X196.259 Y63.164 E1.39281
G1 X194.166 Y61.071 E1.55906
G1 X193.688 Y61.071 E1.58589
G1 X196.259 Y63.642 E1.79009
G1 X196.259 Y64.119 E1.81693
G1 X193.211 Y61.071 E2.05908
G1 X192.733 Y61.071 E2.08591
G1 X196.259 Y64.597 E2.36601
G1 X196.259 Y65.075 E2.39285
G1 X192.255 Y61.071 E2.71090
G1 X191.777 Y61.071 E2.73773
G1 X196.259 Y65.553 E3.09374
G1 X196.259 Y66.030 E3.12057
G1 X191.300 Y61.071 E3.51452
G1 X190.822 Y61.071 E3.54136
G1 X196.259 Y66.508 E3.97326
G1 X196.259 Y66.986 E4.00010
G1 X190.344 Y61.071 E4.46996
G1 X189.867 Y61.071 E4.49679
G1 X196.259 Y67.463 E5.00460
G1 X196.259 Y67.941 E5.03144
G1 X189.389 Y61.071 E5.57719
G1 X188.911 Y61.071 E5.60403
G1 X196.259 Y68.419 E6.18774
G1 X196.259 Y68.897 E6.21458
G1 X188.433 Y61.071 E6.83624
G1 X187.956 Y61.071 E6.86307
G1 X196.259 Y69.374 E7.52268
G1 X196.259 Y69.852 E7.54952
G1 X187.478 Y61.071 E8.24708
G1 X187.000 Y61.071 E8.27392
G1 X196.259 Y70.330 E9.00943
G1 X196.259 Y70.807 E9.03627
G1 X186.523 Y61.071 E9.80974
G1 X186.045 Y61.071 E9.83657
G1 X196.259 Y71.285 E10.64799
G1 X196.259 Y71.763 E10.67483
G1 X185.567 Y61.071 E11.52419
G1 X185.089 Y61.071 E11.55103
G1 X196.259 Y72.241 E12.43835
G1 X196.259 Y72.718 E12.46519
G1 X184.612 Y61.071 E13.39046
G1 X184.134 Y61.071 E13.41729
G1 X196.259 Y73.196 E14.38052
G1 X196.259 Y73.674 E14.40735
G1 X183.656 Y61.071 E15.40853
G1 X183.179 Y61.071 E15.43536
G1 X196.259 Y74.151 E16.47449
G1 X196.259 Y74.629 E16.50132
G1 X182.701 Y61.071 E17.57840
G1 X182.223 Y61.071 E17.60524
G1 X196.259 Y75.107 E18.72026
G1 X196.259 Y75.585 E18.74710
G1 X181.745 Y61.071 E19.90008
G1 X181.268 Y61.071 E19.92691
G1 X196.259 Y76.062 E21.11784
G1 X196.259 Y76.540 E21.14468
G1 X180.790 Y61.071 E22.37356
G1 X180.312 Y61.071 E22.40040
G1 X196.259 Y77.018 E23.66723
G1 X196.259 Y77.495 E23.69407
G1 X179.835 Y61.071 E24.99885
G1 X179.357 Y61.071 E25.02569
G1 X196.259 Y77.973 E26.36842
G1 X196.259 Y78.451 E26.39526
G1 X178.879 Y61.071 E27.77594
G1 X178.421 Y61.091 E27.80168
G1 X196.239 Y78.909 E29.21714
G1 X195.781 Y78.929 E29.24288
G1 X178.401 Y61.549 E30.62356
G1 X178.401 Y62.027 E30.65040
G1 X195.303 Y78.929 E31.99313
G1 X194.825 Y78.929 E32.01997
G1 X178.401 Y62.505 E33.32475
G1 X178.401 Y62.982 E33.35158
G1 X194.348 Y78.929 E34.61842
G1 X193.870 Y78.929 E34.64525
G1 X178.401 Y63.460 E35.87413
G1 X178.401 Y63.938 E35.90097
G1 X193.392 Y78.929 E37.09190
G1 X192.915 Y78.929 E37.11873
G1 X178.401 Y64.415 E38.27171
G1 X178.401 Y64.893 E38.29854
G1 X192.437 Y78.929 E39.41357
G1 X191.959 Y78.929 E39.44040
G1 X178.401 Y65.371 E40.51748
G1 X178.401 Y65.849 E40.54432
G1 X191.481 Y78.929 E41.58344
G1 X191.004 Y78.929 E41.61027
G1 X178.401 Y66.326 E42.61145
G1 X178.401 Y66.804 E42.63828
G1 X190.526 Y78.929 E43.60150
G1 X190.048 Y78.929 E43.62834
G1 X178.401 Y67.282 E44.55361
G1 X178.401 Y67.759 E44.58044
G1 X189.571 Y78.929 E45.46776
G1 X189.093 Y78.929 E45.49460
G1 X178.401 Y68.237 E46.34396
G1 X178.401 Y68.715 E46.37080
G1 X188.615 Y78.929 E47.18221
G1 X188.137 Y78.929 E47.20905
G1 X178.401 Y69.193 E47.98251
G1 X178.401 Y69.670 E48.00935
G1 X187.660 Y78.929 E48.74486
G1 X187.182 Y78.929 E48.77170
G1 X178.401 Y70.148 E49.46926
G1 X178.401 Y70.626 E49.49610
G1 X186.704 Y78.929 E50.15571
G1 X186.227 Y78.929 E50.18254
G1 X178.401 Y71.103 E50.80420
G1 X178.401 Y71.581 E50.83104
G1 X185.749 Y78.929 E51.41474
G1 X185.271 Y78.929 E51.44158
G1 X178.401 Y72.059 E51.98734
G1 X178.401 Y72.537 E52.01417
G1 X184.793 Y78.929 E52.52198
G1 X184.316 Y78.929 E52.54881
G1 X178.401 Y73.014 E53.01867
G1 X178.401 Y73.492 E53.04550
G1 X183.838 Y78.929 E53.47741
G1 X183.360 Y78.929 E53.50424
G1 X178.401 Y73.970 E53.89819
G1 X178.401 Y74.447 E53.92503
G1 X182.883 Y78.929 E54.28103
G1 X182.405 Y78.929 E54.30786
G1 X178.401 Y74.925 E54.62591
G1 X178.401 Y75.403 E54.65275
G1 X181.927 Y78.929 E54.93284
G1 X181.449 Y78.929 E54.95968
G1 X178.401 Y75.881 E55.20183
G1 X178.401 Y76.358 E55.22866
G1 X180.972 Y78.929 E55.43286
G1 X180.494 Y78.929 E55.45969
G1 X178.401 Y76.836 E55.62594
G1 X178.401 Y77.314 E55.65277
G1 X180.016 Y78.929 E55.78106
G1 X179.539 Y78.929 E55.80790
G1 X178.401 Y77.791 E55.89824
G1 X178.401 Y78.269 E55.92508
G1 X179.061 Y78.929 E55.97747
G1 X178.583 Y78.929 E56.00430
G1 X178.401 Y78.747 E56.01874
M106 S201.45
G1 Z1.400 F6000.000
G1 E55.01874 F1200.00000
G92 E0
G1 X196.540 Y79.210 F6000.000
G1 X178.120 Y79.210 E2.02362 F540.000
G1 X178.120 Y60.790 E3.04723
G1 X196.540 Y60.790 E4.07085
G1 X196.540 Y79.150 E5.09113
G1 X196.540 Y79.610 F6000.000
G1 X177.540 Y79.790 E6.17921 F540.000
G1 X177.540 Y60.210 E7.26729
G1 X197.120 Y60.210 E8.35537
G1 X197.120 Y79.730 E9.44011
G1 X196.809 Y79.479 F6000.000
G1 X196.707 Y79.500 E9.44589 F900.000
G1 X177.953 Y79.500 E10.48807
G1 X177.851 Y79.479 E10.49385
G1 X177.830 Y79.377 E10.49963
G1 X177.830 Y60.623 E11.54181
G1 X177.851 Y60.521 E11.54759
G1 X177.953 Y60.500 E11.55337
G1 X196.707 Y60.500 E12.59555
G1 X196.809 Y60.521 E12.60133
G1 X196.830 Y60.623 E12.60711
G1 X196.821 Y79.420 E13.65169
G1 Z1.800 F6000.000
G1 X178.120 Y79.210 E14.67530 F540.000
G1 X178.120 Y60.790 E15.69892
G1 X196.540 Y60.790 E16.72253
G1 X196.540 Y79.150 E17.74282
G1 X177.540 Y79.790 E18.83090 F540.000
G1 X177.540 Y60.210 E19.91897
G1 X197.120 Y60.210 E21.00705
G1 X197.120 Y79.730 E22.09180
G1 X196.707 Y79.500 E22.09758 F900.000
G1 X177.953 Y79.500 E23.13976
G1 X177.851 Y79.479 E23.14554
G1 X177.830 Y79.377 E23.15132
G1 X177.830 Y60.623 E24.19350
G1 X177.851 Y60.521 E24.19928
G1 X177.953 Y60.500 E24.20506
G1 X196.707 Y60.500 E25.24724
G1 X196.809 Y60.521 E25.25302
G1 X196.830 Y60.623 E25.25880
G1 X196.821 Y79.420 E26.30337
G1 Z2.200 F6000.000
G1 X178.120 Y79.210 E27.32699 F540.000
G1 X178.120 Y60.790 E28.35061
G1 X196.540 Y60.790 E29.37422
G1 X196.540 Y79.150 E30.39450
G1 X177.540 Y79.790 E31.48258 F540.000
G1 X177.540 Y60.210 E32.57066
G1 X197.120 Y60.210 E33.65874
G1 X197.120 Y79.730 E34.74348
G1 X196.707 Y79.500 E34.74926 F900.000
G1 X177.953 Y79.500 E35.79144
G1 X177.851 Y79.479 E35.79722
G1 X177.830 Y79.377 E35.80300
G1 X177.830 Y60.623 E36.84518
G1 X177.851 Y60.521 E36.85096
G1 X177.953 Y60.500 E36.85674
G1 X196.707 Y60.500 E37.89893
G1 X196.809 Y60.521 E37.90470
G1 X196.830 Y60.623 E37.91048
G1 X196.821 Y79.420 E38.95506
G1 Z2.600 F6000.000
G1 X178.120 Y79.210 E39.97868 F540.000
G1 X178.120 Y60.790 E41.00229
G1 X196.540 Y60.790 E42.02591
G1 X196.540 Y79.150 E43.04619
G1 X177.540 Y79.790 E44.13427 F540.000
G1 X177.540 Y60.210 E45.22235
G1 X197.120 Y60.210 E46.31042
G1 X197.120 Y79.730 E47.39517
G1 X196.707 Y79.500 E47.40095 F900.000
G1 X177.953 Y79.500 E48.44313
G1 X177.851 Y79.479 E48.44891
G1 X177.830 Y79.377 E48.45469
G1 X177.830 Y60.623 E49.49687
G1 X177.851 Y60.521 E49.50265
G1 X177.953 Y60.500 E49.50843
G1 X196.707 Y60.500 E50.55061
G1 X196.809 Y60.521 E50.55639
G1 X196.830 Y60.623 E50.56217
G1 X196.821 Y79.420 E51.60675
G1 Z3.000 F6000.000
G1 X178.120 Y79.210 E52.63036 F540.000
G1 X178.120 Y60.790 E53.65398
G1 X196.540 Y60.790 E54.67759
G1 X196.540 Y79.150 E55.69788
G1 X177.540 Y79.790 E56.78595 F540.000
G1 X177.540 Y60.210 E57.87403
G1 X197.120 Y60.210 E58.96211
G1 X197.120 Y79.730 E60.04686
G1 X196.707 Y79.500 E60.05263 F900.000
G1 X177.953 Y79.500 E61.09482
G1 X177.851 Y79.479 E61.10060
G1 X177.830 Y79.377 E61.10637
G1 X177.830 Y60.623 E62.14856
G1 X177.851 Y60.521 E62.15434
G1 X177.953 Y60.500 E62.16012
G1 X196.707 Y60.500 E63.20230
G1 X196.809 Y60.521 E63.20808
G1 X196.830 Y60.623 E63.21386
G1 X196.821 Y79.420 E64.25843
G1 Z3.400 F6000.000
G1 X178.120 Y79.210 E65.28205 F540.000
G1 X178.120 Y60.790 E66.30566
G1 X196.540 Y60.790 E67.32928
G1 X196.540 Y79.150 E68.34956
G1 X177.540 Y79.790 E69.43764 F540.000
G1 X177.540 Y60.210 E70.52572
G1 X197.120 Y60.210 E71.61380
G1 X197.120 Y79.730 E72.69854
G1 X196.707 Y79.500 E72.70432 F900.000
G1 X177.953 Y79.500 E73.74650
G1 X177.851 Y79.479 E73.75228
G1 X177.830 Y79.377 E73.75806
G1 X177.830 Y60.623 E74.80024
G1 X177.851 Y60.521 E74.80602
G1 X177.953 Y60.500 E74.81180
G1 X196.707 Y60.500 E75.85398
G1 X196.809 Y60.521 E75.85976
G1 X196.830 Y60.623 E75.86554
G1 X196.821 Y79.420 E76.91012
G1 Z3.800 F6000.000
G1 X178.120 Y79.210 E77.93373 F540.000
G1 X178.120 Y60.790 E78.95735
G1 X196.540 Y60.790 E79.98097
G1 X196.540 Y79.150 E81.00125
G1 X177.540 Y79.790 E82.08933 F540.000
G1 X177.540 Y60.210 E83.17741
G1 X197.120 Y60.210 E84.26548
G1 X197.120 Y79.730 E85.35023
G1 X196.707 Y79.500 E85.35601 F900.000
G1 X177.953 Y79.500 E86.39819
G1 X177.851 Y79.479 E86.40397
G1 X177.830 Y79.377 E86.40975
G1 X177.830 Y60.623 E87.45193
G1 X177.851 Y60.521 E87.45771
G1 X177.953 Y60.500 E87.46349
G1 X196.707 Y60.500 E88.50567
G1 X196.809 Y60.521 E88.51145
G1 X196.830 Y60.623 E88.51723
G1 X196.821 Y79.420 E89.56181
G1 Z4.200 F6000.000
G1 X178.120 Y79.210 E90.58542 F540.000
G1 X178.120 Y60.790 E91.60904
G1 X196.540 Y60.790 E92.63265
G1 X196.540 Y79.150 E93.65294
G1 X177.540 Y79.790 E94.74101 F540.000
G1 X177.540 Y60.210 E95.82909
G1 X197.120 Y60.210 E96.91717
G1 X197.120 Y79.730 E98.00191
G1 X196.707 Y79.500 E98.00769 F900.000
G1 X177.953 Y79.500 E99.04988
G1 X177.851 Y79.479 E99.05566
G1 X177.830 Y79.377 E99.06143
G1 X177.830 Y60.623 E100.10362
G1 X177.851 Y60.521 E100.10940
G1 X177.953 Y60.500 E100.11517
G1 X196.707 Y60.500 E101.15736
G1 X196.809 Y60.521 E101.16314
G1 X196.830 Y60.623 E101.16892
G1 X196.821 Y79.420 E102.21349
G1 Z4.600 F6000.000
G1 X178.120 Y79.210 E103.23711 F540.000
G1 X178.120 Y60.790 E104.26072
G1 X196.540 Y60.790 E105.28434
G1 X196.540 Y79.150 E106.30462
G1 X177.540 Y79.790 E107.39270 F540.000
G1 X177.540 Y60.210 E108.48078
G1 X197.120 Y60.210 E109.56886
G1 X197.120 Y79.730 E110.65360
G1 X196.707 Y79.500 E110.65938 F900.000
G1 X177.953 Y79.500 E111.70156
G1 X177.851 Y79.479 E111.70734
G1 X177.830 Y79.377 E111.71312
G1 X177.830 Y60.623 E112.75530
G1 X177.851 Y60.521 E112.76108
G1 X177.953 Y60.500 E112.76686
G1 X196.707 Y60.500 E113.80904
G1 X196.809 Y60.521 E113.81482
G1 X196.830 Y60.623 E113.82060
G1 X196.821 Y79.420 E114.86518
G1 Z5.000 F6000.000
G1 X178.120 Y79.210 E115.88879 F540.000
G1 X178.120 Y60.790 E116.91241
G1 X196.540 Y60.790 E117.93603
G1 X196.540 Y79.150 E118.95631
G1 X177.540 Y79.790 E120.04439 F540.000
G1 X177.540 Y60.210 E121.13247
G1 X197.120 Y60.210 E122.22054
G1 X197.120 Y79.730 E123.30529
G1 X196.707 Y79.500 E123.31107 F900.000
G1 X177.953 Y79.500 E124.35325
G1 X177.851 Y79.479 E124.35903
G1 X177.830 Y79.377 E124.36481
G1 X177.830 Y60.623 E125.40699
G1 X177.851 Y60.521 E125.41277
G1 X177.953 Y60.500 E125.41855
G1 X196.707 Y60.500 E126.46073
G1 X196.809 Y60.521 E126.46651
G1 X196.830 Y60.623 E126.47229
G1 X196.821 Y79.420 E127.51686
G1 Z5.400 F6000.000
G1 X178.120 Y79.210 E128.54048 F540.000
G1 X178.120 Y60.790 E129.56410
G1 X196.540 Y60.790 E130.58771
G1 X196.540 Y79.150 E131.60799
G1 X177.540 Y79.790 E132.69607 F540.000
G1 X177.540 Y60.210 E133.78415
G1 X197.120 Y60.210 E134.87223
G1 X197.120 Y79.730 E135.95697
G1 X196.707 Y79.500 E135.96275 F900.000
G1 X177.953 Y79.500 E137.00494
G1 X177.851 Y79.479 E137.01071
G1 X177.830 Y79.377 E137.01649
G1 X177.830 Y60.623 E138.05868
G1 X177.851 Y60.521 E138.06446
G1 X177.953 Y60.500 E138.07023
G1 X196.707 Y60.500 E139.11242
G1 X196.809 Y60.521 E139.11820
G1 X196.830 Y60.623 E139.12397
G1 X196.821 Y79.420 E140.16855
G1 Z5.800 F6000.000
G1 X178.120 Y79.210 E141.19217 F540.000
G1 X178.120 Y60.790 E142.21578
G1 X196.540 Y60.790 E143.23940
G1 X196.540 Y79.150 E144.25968
G1 X177.540 Y79.790 E145.34776 F540.000
G1 X177.540 Y60.210 E146.43584
G1 X197.120 Y60.210 E147.52392
G1 X197.120 Y79.730 E148.60866
G1 X196.707 Y79.500 E148.61444 F900.000
G1 X177.953 Y79.500 E149.65662
G1 X177.851 Y79.479 E149.66240
G1 X177.830 Y79.377 E149.66818
G1 X177.830 Y60.623 E150.71036
G1 X177.851 Y60.521 E150.71614
G1 X177.953 Y60.500 E150.72192
G1 X196.707 Y60.500 E151.76410
G1 X196.809 Y60.521 E151.76988
G1 X196.830 Y60.623 E151.77566
G1 X196.821 Y79.420 E152.82024
G1 Z6.200 F6000.000
G1 X178.120 Y79.210 E153.84385 F540.000
G1 X178.120 Y60.790 E154.86747
G1 X196.540 Y60.790 E155.89109
G1 X196.540 Y79.150 E156.91137
G1 X177.540 Y79.790 E157.99945 F540.000
G1 X177.540 Y60.210 E159.08752
G1 X197.120 Y60.210 E160.17560
G1 X197.120 Y79.730 E161.26035
G1 X196.707 Y79.500 E161.26613 F900.000
G1 X177.953 Y79.500 E162.30831
G1 X177.851 Y79.479 E162.31409
G1 X177.830 Y79.377 E162.31987
G1 X177.830 Y60.623 E163.36205
G1 X177.851 Y60.521 E163.36783
G1 X177.953 Y60.500 E163.37361
G1 X196.707 Y60.500 E164.41579
G1 X196.809 Y60.521 E164.42157
G1 X196.830 Y60.623 E164.42735
G1 X196.821 Y79.420 E165.47192
G1 Z6.600 F6000.000
G1 X178.120 Y79.210 E166.49554 F540.000
G1 X178.120 Y60.790 E167.51916
G1 X196.540 Y60.790 E168.54277
G1 X196.540 Y79.150 E169.56305
G1 X177.540 Y79.790 E170.65113 F540.000
G1 X177.540 Y60.210 E171.73921
G1 X197.120 Y60.210 E172.82729
G1 X197.120 Y79.730 E173.91203
G1 X196.707 Y79.500 E173.91781 F900.000
G1 X177.953 Y79.500 E174.96000
G1 X177.851 Y79.479 E174.96577
G1 X177.830 Y79.377 E174.97155
G1 X177.830 Y60.623 E176.01374
G1 X177.851 Y60.521 E176.01951
G1 X177.953 Y60.500 E176.02529
G1 X196.707 Y60.500 E177.06748
G1 X196.809 Y60.521 E177.07326
G1 X196.830 Y60.623 E177.07903
G1 X196.821 Y79.420 E178.12361
G1 Z7.000 F6000.000
G1 X178.120 Y79.210 E179.14723 F540.000
G1 X178.120 Y60.790 E180.17084
G1 X196.540 Y60.790 E181.19446
G1 X196.540 Y79.150 E182.21474
G1 X177.540 Y79.790 E183.30282 F540.000
G1 X177.540 Y60.210 E184.39090
G1 X197.120 Y60.210 E185.47898
G1 X197.120 Y79.730 E186.56372
G1 X196.707 Y79.500 E186.56950 F900.000
G1 X177.953 Y79.500 E187.61168
G1 X177.851 Y79.479 E187.61746
G1 X177.830 Y79.377 E187.62324
G1 X177.830 Y60.623 E188.66542
G1 X177.851 Y60.521 E188.67120
G1 X177.953 Y60.500 E188.67698
G1 X196.707 Y60.500 E189.71916
G1 X196.809 Y60.521 E189.72494
G1 X196.830 Y60.623 E189.73072
G1 X196.821 Y79.420 E190.77530
G1 Z7.400 F6000.000
G1 X178.120 Y79.210 E191.79891 F540.000
G1 X178.120 Y60.790 E192.82253
G1 X196.540 Y60.790 E193.84615
G1 X196.540 Y79.150 E194.86643
G1 X177.540 Y79.790 E195.95451 F540.000
G1 X177.540 Y60.210 E197.04258
G1 X197.120 Y60.210 E198.13066
G1 X197.120 Y79.730 E199.21541
G1 X196.707 Y79.500 E199.22119 F900.000
G1 X177.953 Y79.500 E200.26337
G1 X177.851 Y79.479 E200.26915
G1 X177.830 Y79.377 E200.27493
G1 X177.830 Y60.623 E201.31711
G1 X177.851 Y60.521 E201.32289
G1 X177.953 Y60.500 E201.32867
G1 X196.707 Y60.500 E202.37085
G1 X196.809 Y60.521 E202.37663
G1 X196.830 Y60.623 E202.38241
G1 X196.821 Y79.420 E203.42698
G1 Z7.800 F6000.000
G1 X178.120 Y79.210 E204.45060 F540.000
G1 X178.120 Y60.790 E205.47422
G1 X196.540 Y60.790 E206.49783
G1 X196.540 Y79.150 E207.51811
G1 X177.540 Y79.790 E208.60619 F540.000
G1 X177.540 Y60.210 E209.69427
G1 X197.120 Y60.210 E210.78235
G1 X197.120 Y79.730 E211.86709
G1 X196.707 Y79.500 E211.87287 F900.000
G1 X177.953 Y79.500 E212.91505
G1 X177.851 Y79.479 E212.92083
G1 X177.830 Y79.377 E212.92661
G1 X177.830 Y60.623 E213.96880
G1 X177.851 Y60.521 E213.97457
G1 X177.953 Y60.500 E213.98035
G1 X196.707 Y60.500 E215.02254
G1 X196.809 Y60.521 E215.02831
G1 X196.830 Y60.623 E215.03409
G1 X196.821 Y79.420 E216.07867
G1 Z8.200 F6000.000
G1 X178.120 Y79.210 E217.10229 F540.000
G1 X178.120 Y60.790 E218.12590
G1 X196.540 Y60.790 E219.14952
G1 X196.540 Y79.150 E220.16980
G1 X177.540 Y79.790 E221.25788 F540.000
G1 X177.540 Y60.210 E222.34596
G1 X197.120 Y60.210 E223.43404
G1 X197.120 Y79.730 E224.51878
G1 X196.707 Y79.500 E224.52456 F900.000
G1 X177.953 Y79.500 E225.56674
G1 X177.851 Y79.479 E225.57252
G1 X177.830 Y79.377 E225.57830
G1 X177.830 Y60.623 E226.62048
G1 X177.851 Y60.521 E226.62626
G1 X177.953 Y60.500 E226.63204
G1 X196.707 Y60.500 E227.67422
G1 X196.809 Y60.521 E227.68000
G1 X196.830 Y60.623 E227.68578
G1 X196.821 Y79.420 E228.73036
G1 Z8.600 F6000.000
G1 X178.120 Y79.210 E229.75397 F540.000
G1 X178.120 Y60.790 E230.77759
G1 X196.540 Y60.790 E231.80120
G1 X196.540 Y79.150 E232.82149
G1 X177.540 Y79.790 E233.90956 F540.000
G1 X177.540 Y60.210 E234.99764
G1 X197.120 Y60.210 E236.08572
G1 X197.120 Y79.730 E237.17047
G1 X196.707 Y79.500 E237.17624 F900.000
G1 X177.953 Y79.500 E238.21843
G1 X177.851 Y79.479 E238.22421
G1 X177.830 Y79.377 E238.22999
G1 X177.830 Y60.623 E239.27217
G1 X177.851 Y60.521 E239.27795
G1 X177.953 Y60.500 E239.28373
G1 X196.707 Y60.500 E240.32591
G1 X196.809 Y60.521 E240.33169
G1 X196.830 Y60.623 E240.33747
G1 X196.821 Y79.420 E241.38204
G1 Z9.000 F6000.000
G1 X178.120 Y79.210 E242.40566 F540.000
G1 X178.120 Y60.790 E243.42927
G1 X196.540 Y60.790 E244.45289
G1 X196.540 Y79.150 E245.47317
G1 X177.540 Y79.790 E246.56125 F540.000
G1 X177.540 Y60.210 E247.64933
G1 X197.120 Y60.210 E248.73741
G1 X197.120 Y79.730 E249.82215
G1 X196.707 Y79.500 E249.82793 F900.000
G1 X177.953 Y79.500 E250.87011
G1 X177.851 Y79.479 E250.87589
G1 X177.830 Y79.377 E250.88167
G1 X177.830 Y60.623 E251.92385
G1 X177.851 Y60.521 E251.92963
G1 X177.953 Y60.500 E251.93541
G1 X196.707 Y60.500 E252.97759
G1 X196.809 Y60.521 E252.98337
G1 X196.830 Y60.623 E252.98915
G1 X196.821 Y79.420 E254.03373
G1 Z9.400 F6000.000
G1 X178.120 Y79.210 E255.05735 F540.000
G1 X178.120 Y60.790 E256.08096
G1 X196.540 Y60.790 E257.10458
G1 X196.540 Y79.150 E258.12486
G1 X177.540 Y79.790 E259.21294 F540.000
G1 X177.540 Y60.210 E260.30102
G1 X197.120 Y60.210 E261.38909
G1 X197.120 Y79.730 E262.47384
G1 X196.707 Y79.500 E262.47962 F900.000
G1 X177.953 Y79.500 E263.52180
G1 X177.851 Y79.479 E263.52758
G1 X177.830 Y79.377 E263.53336
G1 X177.830 Y60.623 E264.57554
G1 X177.851 Y60.521 E264.58132
G1 X177.953 Y60.500 E264.58710
G1 X196.707 Y60.500 E265.62928
G1 X196.809 Y60.521 E265.63506
G1 X196.830 Y60.623 E265.64084
G1 X196.821 Y79.420 E266.68542
G1 Z9.800 F6000.000
G1 X178.120 Y79.210 E267.70903 F540.000
G1 X178.120 Y60.790 E268.73265
G1 X196.540 Y60.790 E269.75626
G1 X196.540 Y79.150 E270.77655
G1 X177.540 Y79.790 E271.86462 F540.000
G1 X177.540 Y60.210 E272.95270
G1 X197.120 Y60.210 E274.04078
G1 X197.120 Y79.730 E275.12553
G1 X196.707 Y79.500 E275.13130 F900.000
G1 X177.953 Y79.500 E276.17349
G1 X177.851 Y79.479 E276.17927
G1 X177.830 Y79.377 E276.18504
G1 X177.830 Y60.623 E277.22723
G1 X177.851 Y60.521 E277.23301
G1 X177.953 Y60.500 E277.23879
G1 X196.707 Y60.500 E278.28097
G1 X196.809 Y60.521 E278.28675
G1 X196.830 Y60.623 E278.29253
G1 X196.821 Y79.420 E279.33710
G1 Z10.200 F6000.000
G1 X178.120 Y79.210 E280.36072 F540.000
G1 X178.120 Y60.790 E281.38433
G1 X196.540 Y60.790 E282.40795
G1 X196.540 Y79.150 E283.42823
G1 X177.540 Y79.790 E284.51631 F540.000
G1 X177.540 Y60.210 E285.60439
G1 X197.120 Y60.210 E286.69247
G1 X197.120 Y79.730 E287.77721
G1 X196.707 Y79.500 E287.78299 F900.000
G1 X177.953 Y79.500 E288.82517
G1 X177.851 Y79.479 E288.83095
G1 X177.830 Y79.377 E288.83673
G1 X177.830 Y60.623 E289.87891
G1 X177.851 Y60.521 E289.88469
G1 X177.953 Y60.500 E289.89047
G1 X196.707 Y60.500 E290.93265
G1 X196.809 Y60.521 E290.93843
G1 X196.830 Y60.623 E290.94421
G1 X196.821 Y79.420 E291.98879
G1 Z10.600 F6000.000
G1 X178.120 Y79.210 E293.01240 F540.000
G1 X178.120 Y60.790 E294.03602
G1 X196.540 Y60.790 E295.05964
G1 X196.540 Y79.150 E296.07992
G1 X177.540 Y79.790 E297.16800 F540.000
G1 X177.540 Y60.210 E298.25608
G1 X197.120 Y60.210 E299.34415
G1 X197.120 Y79.730 E300.42890
G1 X196.707 Y79.500 E300.43468 F900.000
G1 X177.953 Y79.500 E301.47686
G1 X177.851 Y79.479 E301.48264
G1 X177.830 Y79.377 E301.48842
G1 X177.830 Y60.623 E302.53060
G1 X177.851 Y60.521 E302.53638
G1 X177.953 Y60.500 E302.54216
G1 X196.707 Y60.500 E303.58434
G1 X196.809 Y60.521 E303.59012
G1 X196.830 Y60.623 E303.59590
G1 X196.821 Y79.420 E304.64048
G1 Z11.000 F6000.000
G1 X178.120 Y79.210 E305.66409 F540.000
G1 X178.120 Y60.790 E306.68771
G1 X196.540 Y60.790 E307.71132
G1 X196.540 Y79.150 E308.73161
G1 X177.540 Y79.790 E309.81968 F540.000
G1 X177.540 Y60.210 E310.90776
G1 X197.120 Y60.210 E311.99584
G1 X197.120 Y79.730 E313.08058
G1 X196.707 Y79.500 E313.08636 F900.000
G1 X177.953 Y79.500 E314.12855
G1 X177.851 Y79.479 E314.13433
G1 X177.830 Y79.377 E314.14010
G1 X177.830 Y60.623 E315.18229
G1 X177.851 Y60.521 E315.18807
G1 X177.953 Y60.500 E315.19384
G1 X196.707 Y60.500 E316.23603
G1 X196.809 Y60.521 E316.24181
G1 X196.830 Y60.623 E316.24759
G1 X196.821 Y79.420 E317.29216
M106 S94.35
G1 Z11.400 F6000.000
G1 X178.208 Y79.122 E318.30596 F1080.000
G1 X178.208 Y60.878 E319.31976
G1 X196.452 Y60.878 E320.33356
G1 X196.452 Y79.062 E321.34403
G1 X177.874 Y79.456 E322.39497 F1080.000
G1 X177.874 Y60.544 E323.44591
G1 X196.786 Y60.544 E324.49685
G1 X196.786 Y79.396 E325.54445
G1 X177.540 Y79.790 E326.63253 F540.000
G1 X177.540 Y60.210 E327.72061
G1 X197.120 Y60.210 E328.80869
G1 X197.120 Y79.730 E329.89343
G1 X196.245 Y78.780 F6000.000
M106 S255
G1 X178.415 Y78.780 E330.82607 F1080.000
G1 X178.415 Y78.330 E330.84962
G1 X196.245 Y78.330 E331.78225
G1 X196.245 Y77.879 E331.80580
G1 X178.415 Y77.879 E332.73844
G1 X178.415 Y77.429 E332.76199
G1 X196.245 Y77.429 E333.69462
G1 X196.245 Y76.979 E333.71817
G1 X178.415 Y76.979 E334.65081
G1 X178.415 Y76.529 E334.67436
G1 X196.245 Y76.529 E335.60699
G1 X196.245 Y76.078 E335.63055
G1 X178.415 Y76.078 E336.56318
G1 X178.415 Y75.628 E336.58673
G1 X196.245 Y75.628 E337.51937
G1 X196.245 Y75.178 E337.54292
G1 X178.415 Y75.178 E338.47555
G1 X178.415 Y74.728 E338.49910
G1 X196.245 Y74.728 E339.43174
G1 X196.245 Y74.277 E339.45529
G1 X178.415 Y74.277 E340.38792
G1 X178.415 Y73.827 E340.41147
G1 X196.245 Y73.827 E341.34411
G1 X196.245 Y73.377 E341.36766
G1 X178.415 Y73.377 E342.30029
G1 X178.415 Y72.927 E342.32385
G1 X196.245 Y72.927 E343.25648
G1 X196.245 Y72.476 E343.28003
G1 X178.415 Y72.476 E344.21267
G1 X178.415 Y72.026 E344.23622
G1 X196.245 Y72.026 E345.16885
G1 X196.245 Y71.576 E345.19240
G1 X178.415 Y71.576 E346.12504
G1 X178.415 Y71.126 E346.14859
G1 X196.245 Y71.126 E347.08122
G1 X196.245 Y70.675 E347.10477
G1 X178.415 Y70.675 E348.03741
G1 X178.415 Y70.225 E348.06096
G1 X196.245 Y70.225 E348.99359
G1 X196.245 Y69.775 E349.01714
G1 X178.415 Y69.775 E349.94978
G1 X178.415 Y69.325 E349.97333
G1 X196.245 Y69.325 E350.90596
G1 X196.245 Y68.874 E350.92952
G1 X178.415 Y68.874 E351.86215
G1 X178.415 Y68.424 E351.88570
G1 X196.245 Y68.424 E352.81834
G1 X196.245 Y67.974 E352.84189
G1 X178.415 Y67.974 E353.77452
G1 X178.415 Y67.524 E353.79807
G1 X196.245 Y67.524 E354.73071
G1 X196.245 Y67.073 E354.75426
G1 X178.415 Y67.073 E355.68689
G1 X178.415 Y66.623 E355.71044
G1 X196.245 Y66.623 E356.64308
G1 X196.245 Y66.173 E356.66663
G1 X178.415 Y66.173 E357.59926
G1 X178.415 Y65.723 E357.62282
G1 X196.245 Y65.723 E358.55545
G1 X196.245 Y65.272 E358.57900
G1 X178.415 Y65.272 E359.51164
G1 X178.415 Y64.822 E359.53519
G1 X196.245 Y64.822 E360.46782
G1 X196.245 Y64.372 E360.49137
G1 X178.415 Y64.372 E361.42401
G1 X178.415 Y63.922 E361.44756
G1 X196.245 Y63.922 E362.38019
G1 X196.245 Y63.471 E362.40374
G1 X178.415 Y63.471 E363.33638
G1 X178.415 Y63.021 E363.35993
G1 X196.245 Y63.021 E364.29256
G1 X196.245 Y62.571 E364.31612
G1 X178.415 Y62.571 E365.24875
G1 X178.415 Y62.121 E365.27230
G1 X196.245 Y62.121 E366.20494
G1 X196.245 Y61.670 E366.22849
G1 X178.415 Y61.670 E367.16112
G1 X178.415 Y61.220 E367.18467
G1 X196.245 Y61.220 E368.11731
M106 S94.35
M107
G1 Z11.800 F6000.000
G1 X178.208 Y79.122 E369.13111 F1080.000
G1 X178.208 Y60.878 E370.14491
G1 X196.452 Y60.878 E371.15871
G1 X196.452 Y79.062 E372.16917
G1 X177.874 Y79.456 E373.22011 F1080.000
G1 X177.874 Y60.544 E374.27105
G1 X196.786 Y60.544 E375.32199
G1 X196.786 Y79.396 E376.36960
G1 X177.540 Y79.790 E377.45768 F540.000
G1 X177.540 Y60.210 E378.54575
G1 X197.120 Y60.210 E379.63383
G1 X197.120 Y79.730 E380.71858
G1 X196.259 Y78.747 E380.73302 F1080.000
G1 X196.259 Y78.269 E380.75985
G1 X195.599 Y78.929 E380.81225
G1 X195.121 Y78.929 E380.83908
G1 X196.259 Y77.791 E380.92942
G1 X196.259 Y77.314 E380.95626
G1 X194.644 Y78.929 E381.08456
G1 X194.166 Y78.929 E381.11139
G1 X196.259 Y76.836 E381.27764
G1 X196.259 Y76.358 E381.30447
G1 X193.688 Y78.929 E381.50867
G1 X193.211 Y78.929 E381.53551
G1 X196.259 Y75.881 E381.77765
G1 X196.259 Y75.403 E381.80449
G1 X192.733 Y78.929 E382.08459
G1 X192.255 Y78.929 E382.11143
G1 X196.259 Y74.925 E382.42948
G1 X196.259 Y74.447 E382.45631
G1 X191.777 Y78.929 E382.81232
G1 X191.300 Y78.929 E382.83915
G1 X196.259 Y73.970 E383.23311
G1 X196.259 Y73.492 E383.25994
G1 X190.822 Y78.929 E383.69185
G1 X190.344 Y78.929 E383.71868
G1 X196.259 Y73.014 E384.18854
G1 X196.259 Y72.537 E384.21538
G1 X189.867 Y78.929 E384.72319
G1 X189.389 Y78.929 E384.75002
G1 X196.259 Y72.059 E385.29578
G1 X196.259 Y71.581 E385.32262
G1 X188.911 Y78.929 E385.90633
G1 X188.433 Y78.929 E385.93316
G1 X196.259 Y71.103 E386.55483
G1 X196.259 Y70.626 E386.58166
G1 X187.956 Y78.929 E387.24128
G1 X187.478 Y78.929 E387.26811
G1 X196.259 Y70.148 E387.96568
G1 X196.259 Y69.670 E387.99251
G1 X187.000 Y78.929 E388.72803
G1 X186.523 Y78.929 E388.75487
G1 X196.259 Y69.193 E389.52833
G1 X196.259 Y68.715 E389.55517
G1 X186.045 Y78.929 E390.36659
G1 X185.567 Y78.929 E390.39342
G1 X196.259 Y68.237 E391.24280
G1 X196.259 Y67.759 E391.26963
G1 X185.089 Y78.929 E392.15695
G1 X184.612 Y78.929 E392.18379
G1 X196.259 Y67.282 E393.10906
G1 X196.259 Y66.804 E393.13590
G1 X184.134 Y78.929 E394.09912
G1 X183.656 Y78.929 E394.12596
G1 X196.259 Y66.326 E395.12714
G1 X196.259 Y65.849 E395.15397
G1 X183.179 Y78.929 E396.19310
G1 X182.701 Y78.929 E396.21993
G1 X196.259 Y65.371 E397.29701
G1 X196.259 Y64.893 E397.32385
G1 X182.223 Y78.929 E398.43888
G1 X181.745 Y78.929 E398.46572
G1 X196.259 Y64.415 E399.61870
G1 X196.259 Y63.938 E399.64553
G1 X181.268 Y78.929 E400.83647
G1 X180.790 Y78.929 E400.86330
G1 X196.259 Y63.460 E402.09219
G1 X196.259 Y62.982 E402.11902
G1 X180.312 Y78.929 E403.38586
G1 X179.835 Y78.929 E403.41269
G1 X196.259 Y62.505 E404.71748
G1 X196.259 Y62.027 E404.74432
G1 X179.357 Y78.929 E406.08706
G1 X178.879 Y78.929 E406.11389
G1 X196.259 Y61.549 E407.49458
G1 X196.239 Y61.091 E407.52032
G1 X178.421 Y78.909 E408.93578
G1 X178.401 Y78.451 E408.96152
G1 X195.781 Y61.071 E410.34221
G1 X195.303 Y61.071 E410.36904
G1 X178.401 Y77.973 E411.71178
G1 X178.401 Y77.495 E411.73861
G1 X194.825 Y61.071 E413.04340
G1 X194.348 Y61.071 E413.07023
G1 X178.401 Y77.018 E414.33707
G1 X178.401 Y76.540 E414.36390
G1 X193.870 Y61.071 E415.59279
G1 X193.392 Y61.071 E415.61962
G1 X178.401 Y76.062 E416.81055
G1 X178.401 Y75.585 E416.83739
G1 X192.915 Y61.071 E417.99037
G1 X192.437 Y61.071 E418.01720
G1 X178.401 Y75.107 E419.13223
G1 X178.401 Y74.629 E419.15907
G1 X191.959 Y61.071 E420.23615
G1 X191.481 Y61.071 E420.26298
G1 X178.401 Y74.151 E421.30211
G1 X178.401 Y73.674 E421.32894
G1 X191.004 Y61.071 E422.33012
G1 X190.526 Y61.071 E422.35695
G1 X178.401 Y73.196 E423.32018
G1 X178.401 Y72.718 E423.34701
G1 X190.048 Y61.071 E424.27228
G1 X189.571 Y61.071 E424.29912
G1 X178.401 Y72.241 E425.18644
G1 X178.401 Y71.763 E425.21327
G1 X189.093 Y61.071 E426.06264
G1 X188.615 Y61.071 E426.08948
G1 X178.401 Y71.285 E426.90090
G1 X178.401 Y70.807 E426.92773
G1 X188.137 Y61.071 E427.70120
G1 X187.660 Y61.071 E427.72803
G1 X178.401 Y70.330 E428.46355
G1 X178.401 Y69.852 E428.49038
G1 X187.182 Y61.071 E429.18795
G1 X186.704 Y61.071 E429.21478
G1 X178.401 Y69.374 E429.87440
G1 X178.401 Y68.897 E429.90123
G1 X186.227 Y61.071 E430.52289
G1 X185.749 Y61.071 E430.54973
G1 X178.401 Y68.419 E431.13344
G1 X178.401 Y67.941 E431.16027
G1 X185.271 Y61.071 E431.70603
G1 X184.793 Y61.071 E431.73287
G1 X178.401 Y67.463 E432.24067
G1 X178.401 Y66.986 E432.26751
G1 X184.316 Y61.071 E432.73736
G1 X183.838 Y61.071 E432.76420
G1 X178.401 Y66.508 E433.19610
G1 X178.401 Y66.030 E433.22294
G1 X183.360 Y61.071 E433.61689
G1 X182.883 Y61.071 E433.64373
G1 X178.401 Y65.553 E433.99973
G1 X178.401 Y65.075 E434.02656
G1 X182.405 Y61.071 E434.34461
G1 X181.927 Y61.071 E434.37145
G1 X178.401 Y64.597 E434.65154
G1 X178.401 Y64.119 E434.67838
G1 X181.449 Y61.071 E434.92053
G1 X180.972 Y61.071 E434.94736
G1 X178.401 Y63.642 E435.15156
G1 X178.401 Y63.164 E435.17839
G1 X180.494 Y61.071 E435.34464
G1 X180.016 Y61.071 E435.37147
G1 X178.401 Y62.686 E435.49977
G1 X178.401 Y62.209 E435.52660
G1 X179.539 Y61.071 E435.61694
G1 X179.061 Y61.071 E435.64378
G1 X178.401 Y61.731 E435.69617
G1 X178.401 Y61.253 E435.72300
G1 X178.583 Y61.071 E435.73744
G1 Z12.200 F6000.000
G1 E434.73744 F1200.00000
G92 E0
G92 E0
G92 E0
; filament used = 673.5mm (1.6cm3)
; bed_shape = 0x0,393.7x0,393.7x140,0x140
; brim_width = 0
; cooling = 1
; fan_always_on = 0
; first_layer_extrusion_width = 130%
; first_layer_temperature = 208
; gcode_arcs = 0
; infill_first = 0
; layer_gcode =
; max_print_speed = 18
; notes =
; post_process =
; resolution = 0
; retract_lift = 0
; retract_speed = 20
; skirt_height = 1
; skirts = 1
; spiral_vase = 0
; temperature = 202
; threads = 2
; wipe = 0
; z_offset = 0
; first_layer_height = 0.2
; raft_layers = 0
; support_material_speed = 18
; bridge_speed = 18
; fill_angle = 45
; gap_fill_speed = 15
; infill_speed = 18
; overhangs = 1
; perimeter_speed = 18
; perimeters = 3
; solid_infill_speed = 18
; thin_walls = 1
Re: Printing blobs
December 19, 2015 09:02PM
I'm also wondering if the extrusion speed is too slow?
#define DEFAULT_AXIS_STEPS_PER_UNIT {2519.68,2519.68,5039.37,726.667} //MK7 96.43, MK8 185.198
//#define DEFAULT_AXIS_STEPS_PER_UNIT {AXIS_STEPS_PER_UNIT_X, AXIS_STEPS_PER_UNIT_Y, AXIS_STEPS_PER_UNIT_Z,500}
#define DEFAULT_MAX_FEEDRATE {7, 7, 18, 2} // (mm/sec)Stock25
#define DEFAULT_MAX_ACCELERATION {100,100,100,18} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration in mm/s^2 for retracts
#define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 2.0 // 15.0(mm/sec)
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Printing blobs
December 21, 2015 07:24AM
Here are the attachments of what the cube and thin wall currently look like when they print.
open | download - IMAG1040.jpg (103.7 KB)
open | download - IMAG1038.jpg (212.4 KB)
open | download - IMAG1037.jpg (151.6 KB)
