Pronterface problem April 14, 2016 11:15AM |
Re: Pronterface problem April 14, 2016 05:47PM |
Re: Pronterface problem April 15, 2016 01:37AM |
Re: Pronterface problem April 15, 2016 09:03AM |
Re: Pronterface problem April 15, 2016 06:10PM |
Re: Pronterface problem April 17, 2016 02:23AM |
Re: Pronterface problem April 17, 2016 10:11AM |
polisher44
Would the steps in the firmware be incorrect if it is working from the the old print files. I guess I am asking if the step/min/sec are contained in Gcode/*.G files. If this is the case then I can see way forward.
Will be checking again in the firmware for my Step/min/sec printer settings.
Thanks for advise so far.
Re: Pronterface problem April 18, 2016 03:28AM |
Re: Pronterface problem April 18, 2016 07:15AM |
polisher44
Thanks yes. Did this early on. All Pronterface manual commands are accurate. As are the prints I make off the SD card (on the Panelulo2) generated by the previous owner.
Just cannot print my designs, or any downloaded designs. Even though the pre-print report on Pronterface advises the the correct dimensions.
After three days of parameter changes and experimentation, I feel like my brain is stuck to the hotplate with Pritstick!!
