Prints not being exact (enough) October 15, 2016 01:09PM |
Re: Prints not being exact (enough) October 15, 2016 04:01PM |
Re: Prints not being exact (enough) October 15, 2016 04:12PM |
Re: Prints not being exact (enough) October 16, 2016 01:50AM |
ggherbaz
ok, first you need to calibrate again your extruder so when you extrude 10 mm the filament on the infeed side of the extruder moves 10 mm, repeat that with 100 mm. adjust your steps per mm (using the biggest difference number) and repeat the process until you get exact results. Once satisfied you need to print single line extrusions in your built plate, with each line you are going to test your extrusion width and your extrusion multiplier in order to get the best extrusion line possible so:
if your nozzle is for example a 0.4 mm you will set one line with an extrusion width of 0.4 (manual) and one with auto (0.48), for each setting you will print several ones with different extrusion multipliers from 0.9 to 1.2 (although I never go higher than 1) in increments of 2 (0.90, 0.92......) repeat this process for every layer high you use (0.2, 0.3, 0.4, etc.) once you have collected all your extrusions measure all of them and select only the ones that will measure exact, from there you will have for each layer height the best extrusion width and extrusion multiplier and set those numbers in your slicer. Each material is different so you are better of set this test for each material you use and for each supplier you use (is a pain but worth the time).
Now few things you didn't mention and may cause your problems are: do you measure your filament in several places and set the filament width in the slicer? when you set your wall thickness are you calculating how many lines can actually fit in there? for a 0.4 nozzle with an auto width of 0.48 for 2 perimeters your wall needs to be set at 0.96, 3 at 1.44 and 4 at 1.92, anything different than that and you will have spaces in the perimeters forming the wall.
One last thing, circles will never be exact so you need to compensate for it, once you have your extrusion perfect you can print several test cylinders to find which is the best number for you, for me a 8 mm hole needs to be scaled to 8.2 so an M8 rod slide freely in the hole.
the_digital_dentist
Getting accurate results requires accurate printer construction and good calibration. For a printer construction example, if the belts that move the extruder carriage on the X axis are not kept parallel to the X axis at all positions of the extruder carriage, prints will not be accurate, and the error will depend on where they are printed along the X axis. The closer they are to the ends of the X axis, the worse the distortion will be. Even if you go to all the trouble to calibrate your printer, you are handicapped by its poor design. The Z axis screws, driven by two motors, can easily lose sync, tilting the X axis relative to the Z axis, causing prints to be skewed. Your hard work of calibrating won't last long and you'll be doing it again very soon due to this instability. If you want the calibration to last, drive the Z axis screws with a belt from a single motor.
Use a larger object to calibrate, preferably one as large as the bed will allow. Whenever you make a measurement, there will be some error. If you print a small object, measure it, then use that measurement to set steps/mm, the error in the measurement is multiplied when you print larger objects. If you calibrate with a larger object, when you print smaller objects the error gets divided.
Make sure you calibrate the extruder. I like this guide for getting good results: [reprap.org] Pay careful attention to the stuff about fine tuning the extruder steps/mm.
Re: Prints not being exact (enough) October 16, 2016 08:32AM |
Re: Prints not being exact (enough) October 17, 2016 10:32AM |
Re: Prints not being exact (enough) October 23, 2016 05:20AM |
Re: Prints not being exact (enough) October 23, 2016 08:44AM |
