First Print Didn't Go Well.... December 01, 2016 04:33PM |
Re: First Print Didn't Go Well.... December 01, 2016 10:42PM |
Re: First Print Didn't Go Well.... December 01, 2016 10:43PM |
Re: First Print Didn't Go Well.... December 01, 2016 11:49PM |
Re: First Print Didn't Go Well.... December 01, 2016 11:51PM |
the_digital_dentist
Picture 1: uneven spacing between the fill lines indicates a mechanical problem. One axis is not behaving properly. Reslice and set the infill angle to 0 degrees instead of 45 degrees. When you print you will see which axis has the problem. An error this large should be pretty easy to spot anyway...
Pictures 2 and 3: you probably don't have the Z axis calibrated and it is stepping more than you intend with the result that the layers are not sticking to each other.
Calibration is involved and takes time to do it right. Start here: [reprap.org]
Re: First Print Didn't Go Well.... December 02, 2016 12:40AM |
