Extrusion Fail with Simplify3D?
Posted by DeathmannX
December 16, 2016 05:52PM
Hello Guys,
i bought yesterday Simplify3D and set it up, but it dosen't work currently. sad smiley
I set up the Filament Diameter to 2.85 and checked my Filament.
I also checked my Z Probe Offset and tryed to print it from Simplify3D and my SD Card but
the Results are the same.
I use a Prusa i3 with a E3D V6 Bowden and a inductive Probe.
Result:
The strange Thing about this is that if i print the exact same Thing with Cura the Latest Version
it prints...
Edited 1 time(s). Last edit at 12/16/2016 05:52PM by DeathmannX.
Re: Extrusion Fail with Simplify3D?
December 16, 2016 07:18PM
S3D have several settings that you need to set right, isn't as simple as you might think and it take some experimentation to get perfect prints.
If you can post the screen shots of your process so I can check it including g code start.
Edited 1 time(s). Last edit at 12/16/2016 07:24PM by ggherbaz.
December 16, 2016 10:19PM
I make a few Screenshots to show you my Settings:
[Extruder]
[gyazo.com]
[Layer]
[gyazo.com]
[Additions]
[gyazo.com]
[Infill]
[gyazo.com]
[Support]
[gyazo.com]
[Temperature]
[gyazo.com]
[Cooling]
[gyazo.com]
[G-Code]
[gyazo.com]
[Start Scripts]
[gyazo.com]
[End Scripts]
[gyazo.com]
[Other]
[gyazo.com]
[Advanced]
[gyazo.com]
Why they don't insert a simple export function for this all. sad smiley
December 17, 2016 12:21AM
Ok, few things to try:
Lower retraction to 1~1.5
Increase retraction speed to 40 mm/s
Bring first layer height to 100% or under
First layer extrusion width 100%
Infill extrusion width 100%
XY movements 60 mm/s
Outline and solid infill underspeed 80%
Edited 1 time(s). Last edit at 12/17/2016 12:25AM by ggherbaz.
December 17, 2016 12:33AM
For the test uncheck:
Wipe, coast, perform retraction during wipe, wipe only on the outer most perimeters and relative extrusion distance.
After implement each one individually and tune them up.
One thing to note: if for some reason S3D doesn't want to take your printer Z offset from sensor, put it on the g code tab. (It does it to me once in a while)
Edited 1 time(s). Last edit at 12/17/2016 12:40AM by ggherbaz.
