Hi All -
During perimeter printing, the print head is pausing momentarily. As a result, little blobs are forming in the perimeter. This only happens in curves. It is like the Arduino can't keep up. I have a MendelMax 15+ and I am using Slic3r 0.9.0 with Maxbot's Marlin ZIP. The source file is from Alibre PE.
Any ideas appreciated.
TIA - Brad
PRINT SPEED
Perimeters 80mm/sec
Small perimeters 60mm/sec
External perimeters 100%
Infill : 80mm/sec
Solid Infill 80mm/sec
Top solid infill 60mm/sec
Bridges: 60mm/sec
Travel: 130mm/sec
First layer speed ratio: 50%
PRINT SETTINGS
Perimeters: 3
Solid Layers: 3
Fill DensityL: 0.5
Fill Pattern: Rectilinear
Solid Fill Pattern: Rectilinear
Randlmize Tsarting Points *YES!*
Generate Support Material *NO!*
RETRACTION
Length 1mm
Lift Z: 0
Speed: 30mm/s
Extra Length on Restart: 0mm
Minimum Travel after Restart: 2
