PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. February 23, 2017 06:42PM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. February 24, 2017 02:48AM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. February 24, 2017 03:16AM |
anvoice
As far as PETG is concerned, you can try slowing down the print a bit (I print it at 30mm/sec max and get good results) and see if it helps. Also for small parts, PETG retains heat for a while, so you either need active cooling of the part or you need to print the small parts together with something larger. When printing small parts without cooling, I can often deform them easily by hand when the print just finishes.
All in all, PETG is a great material once you have it dialed in and has very nice mechanical properties.
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. February 24, 2017 03:24AM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. February 24, 2017 05:59PM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. February 24, 2017 11:54PM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. February 27, 2017 02:54AM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. February 28, 2017 02:26AM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. March 01, 2017 03:36AM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. March 01, 2017 10:33PM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. March 03, 2017 11:47PM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. March 04, 2017 07:38PM |
will1384
I was able to keep the nozzle clean and stop the blobs by doing three things:
(1) Fine tuning the retraction, I was able to keep the nozzle clean but have messy parts by turning retraction to 0mm, but I wanted clean parts, so I slowly turned the retraction up from 0mm in 0.5mm steps, 2mm seemed to work best.
(2) Going slow seems to help, I have it set at 30mm/s, I will try to up the speed later.
(3) Printing hotter also seemed to help, I went up to 260.
(*) I also have a part cooling fan running as slow as it can.
Here are what my parts look like now:
[imgur.com]
and my nozzle after that print:
[imgur.com]
And my Cura Settings:
[imgur.com]
[imgur.com]
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. March 04, 2017 07:52PM |
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. March 04, 2017 09:01PM |
anvoice
The PETG glass transition temperature is about 78C, so you may want to be careful with those parts until they cool: they'll be quite soft due to the bed heat otherwise.
Re: PLA was printing almost perfect but PETG is giving me some trouble, and I have some electrical interference from a rewiring. March 18, 2017 12:57AM |
