Missing/Uneven Perimeters! April 13, 2017 04:52PM |
Re: Missing/Uneven Perimeters! April 15, 2017 10:05AM |
Re: Missing/Uneven Perimeters! April 15, 2017 11:38AM |
Re: Missing/Uneven Perimeters! April 15, 2017 12:16PM |
Re: Missing/Uneven Perimeters! April 15, 2017 03:41PM |
Re: Missing/Uneven Perimeters! April 15, 2017 04:39PM |
Re: Missing/Uneven Perimeters! April 18, 2017 10:34AM |
Re: Missing/Uneven Perimeters! April 18, 2017 09:11PM |
MCcarman
Looks like an extruder issue to me. The corners seem fairly well aligned its just the under extruded layers that look bad. So it makes me think the position control is OK.
Check the spring tension on your pressure wheel. Try increasing it. If there is no adjuster put a washer underneath the spring. Someone on here reported they had a tension spring that was "set" overly compressed and had to stretch it to get good pressure. Also check the hobbed bolt/gear on the extruder is tight and that the pressure wheel can move enough to maintain pressure on the filament.
Re: Missing/Uneven Perimeters! April 21, 2017 06:07PM |
Re: Missing/Uneven Perimeters! May 12, 2017 03:25AM |
Re: Missing/Uneven Perimeters! May 12, 2017 04:14PM |
Re: Missing/Uneven Perimeters! May 13, 2017 05:06AM |
