Problems with Top Layer. May 04, 2017 03:03PM |
Re: Problems with Top Layer. May 05, 2017 02:08AM |
Re: Problems with Top Layer. May 05, 2017 12:04PM |
Re: Problems with Top Layer. May 06, 2017 07:36AM |
Re: Problems with Top Layer. June 28, 2017 11:29AM |
Re: Problems with Top Layer. June 29, 2017 05:08AM |
Re: Problems with Top Layer. June 29, 2017 08:20AM |
Re: Problems with Top Layer. June 29, 2017 12:23PM |
Re: Problems with Top Layer. June 29, 2017 12:42PM |
Inhumierer
For me the right cap looks better. On the top it looks like a little underextrusion. And 230 deg is AFAIK way too hot for PLA. Did you adjust Vref on your drivers? Checked the current to the steppers, especially the extruder stepper? Are you printing with 3mm or 1.75mm filament? What's your nozzle size? 3mm filament and 0.3mm nozzle can be hard work for the extruder stepper. Do you have the chance to test a geared extruder, like Wade's?
Re: Problems with Top Layer. June 29, 2017 12:43PM |
Re: Problems with Top Layer. June 29, 2017 12:57PM |
MCcarman
As you were printing at 190c we assume your using PLA so 230 is way to hot and explains the brown marks and the stringing. So I would set it back to 190.
Then you check if you can push the filament through by hand. If so the issue is the extruder as O-lampe has pointed out.
From the picture it looks like the idler arm gets very close to the mounting block so check you have clearance and good spring pressure with filament installed.
