Huge inconsistent layer shifts
Posted by theblindsaint
July 31, 2017 10:22PM
[drive.google.com]
Anyone know what the root cause of this is? It's not a gradual layer shift so I'm not sure what went wrong
Re: Huge inconsistent layer shifts
August 01, 2017 02:43AM
A general rule is:
small shift = skipped steps
big shifts = overheated driver in temperature protection mode
August 01, 2017 03:36AM
thanks, so i should try to improve my cooling? Bigger cooling fan for the board?
August 02, 2017 01:41AM
Usually a normal fan is enough to cool the drivers. I'd start checking the Vref of the driver and try to reduce it. Also check for mechanical problems like cheap linear bearings or wires potentionally blocking motions.
August 02, 2017 01:46AM
after shifting the drivers around i can say for certain it is one driver in particular that is causing this problem, I'll just replace itand see?
August 02, 2017 07:25AM
If this is a newly built printer, try turning down the acceleration.
If it used to work fine and this is a new problem, it may be the driver or an intermittent cable.
