Any ideas of what happened mid way through this print?
Posted by Gaz83
July 23, 2018 12:20PM
Ok so this is my print. I recently rebuilt my printer and this is the first thing I printed apart from a 20mm cube.
IMG_20180723_170906
As you can see, first few layers seems ok. Then all of sudden it looks like crap. What I did at this point was I paused the print, turned the extruder and heat bed off and went out. Came back and switch them both back on. Once they got to temperature, I continued the print. Seemed to print much better after that. Not perfect, I know. Looks like I have some tweaking but I don't get the middle section.
Using Marlin with Octoprint.
MKS GEN 1.4 board
TMC2100 drivers for all axis
DRV8825 for the extruder motor.
Re: Any ideas of what happened mid way through this print?
July 25, 2018 01:28AM
is it a pla plastic. if so then you had a temp to high....! it also seem a bit of overextruding. you have to add a fan and/or print with lower temps.
Delta Printer
Duet 0.8.5 firmware 1.19
July 25, 2018 01:26PM
It seems to be related to infill, because the lower and upper layers ( without infill ) look OK.
What is your setting for Infill/Perimeter-overlap? Infill-width and fill rate are also important.
