Re: PETg woes August 07, 2018 03:47PM |
Re: PETg woes August 08, 2018 12:27AM |
Re: PETg woes August 08, 2018 01:54PM |
Re: PETg woes August 22, 2018 10:09AM |
Re: PETg woes August 27, 2018 08:09AM |
Re: PETg woes September 06, 2018 01:00PM |
SupraGuy
No pictures to support, but PETg is making me crazy.
I had high hopes for it, and my first attempt seemed to be going well. Unfortunately my gcode file was truncated, so it just stopped printing after about 7mm, but up to there, it looked perfect.
Then I tried again, and I got about 2 layers, then it jammed. I had to disassemble the extruder, since the filament bent and wouldn't go through the nozzle. I tried slowing down the print speed, same thing. bumped up the temp from 240 to 245... 250. Still no good. Printed (In ABS) a piece to go between the extruder gears and print throat. It stopped folding the filament and shoving it out to the side, but instead just jammed, and stopped extruding. (By 250 deg C, it was also really stringy, and wouldn't stop oozing, but at the same time wouldn't extrude.) The first layer or two seems to work fine, bed adhesion is good, layer adhesion is good, but it just stops extruding at all after that. (After putting int he part to make folding the filament impossible, it still extrudes a tiny amount, basically reduced to a constant ooze.
Printer works fine for ABS, and PLA but I had a part that I wanted to print in PETg.
I have a modified Mk10 nozzle setup. I was worried that the aluminum bar was getting too hot, but it doesn't seem to be adversely affecting the ABS part that I printed at the top of the nozzle, and there is a part cooling fan mount attached to it as well, which seems to be fine. My feeling is that it's related to having an all-metal hotend somehow jamming at the heat break where the temperature is settling to be hot enough to melt the PETg, but too cool to let it flow freely. I really want to resolve this though.
As I write this, I kind of come to the conclusion that hotter and slower doesn't seem to be the answer. I might try dropping the temperature a little to see how that does.
Of course if I could just solve the problem of large ABS prints warping like crazy, I might not need to use PETg at all.
Re: PETg woes September 06, 2018 04:02PM |
Re: PETg woes September 10, 2018 11:57AM |
