Anet A8 first layer has changed dramatically January 09, 2019 08:11PM |
Re: Anet A8 first layer has changed dramatically January 11, 2019 04:32PM |
Re: Anet A8 first layer has changed dramatically January 11, 2019 04:49PM |
imqqmi
Expansion of the heated bed? Uneven bed? Bed mounting screws loose?
Re: Anet A8 first layer has changed dramatically January 14, 2019 07:27AM |
Re: Anet A8 first layer has changed dramatically January 14, 2019 12:57PM |
MCcarman
As your description of the issue is based on the extrusion quality you should also think about the hot end.
Anything reducing the nozle tip temperature (distance from the heater cartridge), airflow around the nozle, may thicken the filament. Extrusion speed increases may reduce heating time. Loose thermister.
