E motors stops working after 1 layer June 01, 2019 07:20PM |
Re: E motors stops working after 1 layer June 02, 2019 03:54AM |
Re: E motors stops working after 1 layer June 02, 2019 06:23AM |
dc42
My guess is that the extruder stepper driver is going into thermal shutdown. Reduce the current setting on that driver, or try a new driver, or provide better cooling.
Re: E motors stops working after 1 layer June 02, 2019 05:25PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: E motors stops working after 1 layer June 03, 2019 03:02AM |
Re: E motors stops working after 1 layer June 03, 2019 11:01AM |
dc42
Is the hot end maintaining temperature all the while?
Do you turn the print cooling fan full on at the start of the second layer? If so, try turning it on only partially, and full on at layer 11 (because you said that from layer 11 you can print at full speed). It's not uncommon for the print cooling fan to cause a large drop in nozzle temperature when it turns on.
Re: E motors stops working after 1 layer June 03, 2019 03:44PM |
dc42
................................It's not uncommon for the print cooling fan to cause a large drop in nozzle temperature when it turns on.
Re: E motors stops working after 1 layer June 05, 2019 03:56PM |
Re: E motors stops working after 1 layer June 06, 2019 01:34PM |
Re: E motors stops working after 1 layer June 07, 2019 12:39PM |
Re: E motors stops working after 1 layer June 07, 2019 01:32PM |
Re: E motors stops working after 1 layer June 08, 2019 12:47AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: E motors stops working after 1 layer June 08, 2019 06:05PM |
Ohmarinus
I don't know why you ignored my comment but it still sounds like a clog to me ^_^ I had the same issues, changed everything. Then I replaced the hotend and everything worked smoothly again from there on.
Dust
Slicer PE and the new Prusa Slicer have one serious flaw (in my view). It disregards max feedrates, acceleration and jerk setting you have in your firmware. It instead takes the setting from its Printer setting|machine limits and generates gcodes to override the hardware limit you have set..
I wonder if you are falling foul of this...
Re: E motors stops working after 1 layer June 08, 2019 06:06PM |
Re: E motors stops working after 1 layer June 09, 2019 11:36AM |
JorKsX
Ohmarinus
not a clog, E motor would click for some time until over heat protection kicks in.
when I print normal speed 30mm/s, then suddenly change speed to +400%, E motors stops working, but everything else keeps going.
Dust
yes I noticed this that new slic3r PE did this, but for some reason I liked the settings and everything worked fine after the first update that had this feature. But not working anymore
Re: E motors stops working after 1 layer July 12, 2019 05:21AM |
