Simplify3D v4 issue December 02, 2019 05:25PM |
Re: Simplify3D v4 issue December 02, 2019 05:42PM |
TheMacDaddy
Hi, bit of a strange one. I'm using S3D & Wanhao Di3 v2.1 to print my models, however when the model has finished printing, S3D runs though the end G Code fine but then it starts to print that same model again.
My end G Code is as follows :
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle
to release some of the pressure
G1 Z+2 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops
so the head is out of the way
G1 Y150 F5000 ;move completed part out
M84 ;steppers off
G90 ;absolute positioning
When it tries to reprint the same model it does so at the edge of the build plate causing the stepper motors to grind and make strange noises.
This isn't an issue when I use Cura, but I prefer S3D.
Any suggestions would be appreciated, I'm pulling my hair out.
Re: Simplify3D v4 issue December 02, 2019 06:09PM |
Re: Simplify3D v4 issue December 03, 2019 11:17AM |
TheMacDaddy
Strange thing is I was using S3D a couple of years ago with no problems. I packed away my printer and only recently got it back up and running
and the problem started.
