MKS GEN V1.4 WEIRD BEHAVIOR STEP MOTORS
Posted by eelias
June 05, 2020 02:32PM
Hi there !
I am building a printer, I used firstly an arduina mega + ramps 1.6 shield. In this configuration ir worked well.
Then i switched to MKS GEN V1.4 and used the same DRV8825 from the ramps 1.6 and same motors and cables.
All the jumpers below the DRV8825 are connected
I have changed the Merlin FW to GEN 1.3 and UP, added the DRV8825 as the driver
Uploaded the Firmaware on the board.
Everything works, however the motors are presenting a chalenge: using proterface i can make x and y move no problem. If select HOME for X or Y it remains in the same position and just a "clunk" sound is heard.
On the Z axis the motors are just buzzing.
EDIT: cable pairs seems to be fine, just tested again. However these are the same cables that worked on RAMPS 1.6
What is wrong?
Edited 1 time(s). Last edit at 06/05/2020 02:50PM by eelias.
Re: MKS GEN V1.4 WEIRD BEHAVIOR STEP MOTORS
June 14, 2020 09:38AM
If you can run X & Y the only diff for a HOME is the endstops are being used.
Verify they are plugged in correctly and set properly in f/w.
verify them with M119
Try placing head in center to give u time to hit stop or depower and try a home with endstop disconnected.
Buzzing on Z might be an indication that steps/mm are set wrong, current wrong or a power issue.
Edited 1 time(s). Last edit at 06/14/2020 09:40AM by ruggb.
