Blobs on the first layer
Posted by fsamir
March 22, 2013 08:31PM
Hi everyone,
I can't figure out what is causing these blobs on the first layer.
1.75mm PLA, 185C, blue painters tape, printing first layer at 20mm/sec
Any thoughts?
Cheers,
Franklin Dattein
Re: Blobs on the first layer
March 22, 2013 09:45PM
Hi Franklin
I saw similar issues on my rig when i first rebuilt it
Assuming your extuder is calibrated correctly ( always worth checking) and the nozzel is clean id try the following
2 perimeters
190 C
30 ( maybe even 40) mm/sec
It looks to me like too little material and too cold
Good luck
rgds
Phil
March 22, 2013 10:15PM
March 25, 2013 08:07PM
Thanks for helping, unfortunatelly none of the clues helped.
My first thought wast that the extruder was too low and I raised it 0.1mm at time, up to a point where filament wouldn't stick consistently to the blue tape.
Also, tried raising the temperature in 5C steps, up to 205C. It helped a bit, but didn't solve the problem.
Furtheremore, in Slic3r advanced settings I played with "extrusion width" and "first layer" settings. I've set "default extrusion width" to 0.35mm (size of my nozzle) also made a difference, but nothing great.
I have even swaped the filament, since that was the only thing I've changed when the problem began. Still didn't work.
It's been two days and I running out of options. The only thing I havent tried is to heat the bed to increase adhesion...
Any thoughts?
Cheers,
Franklin Dattein
March 25, 2013 08:09PM
Clean the tape with acetone or 99% rubbing alcohol. Then it will stick to the tape much more easily at the correct height.
March 25, 2013 08:11PM
Interesting. I will give it a shot tonight. Thanks.
ps. I've replaced the tape a couple of times to make sure the issue wasn't due to used tape.
March 26, 2013 06:37AM
It worked!
I did like you said and cleaned up the blue painters tape with Acetone and it works like a charm.
Thank you!
Cheers,
Franklin Dattein
March 26, 2013 12:59PM
