Will a cooling fan solve this issue?
Posted by rtrahms
April 14, 2013 11:13AM
Hi all -
Configuration:
Mendel90 / Sanguinololu / Sprinter / Repetier
I have noticed that I get some strange curling during overhangs on certain prints. I did a calibration overhang print (images attached), which shows the curling. I do not have cooling fan built (yet), still need to procure parts for the switch.
Thanks,
Rob
open | download - IMG_1786.JPG (80.3 KB)
open | download - IMG_1787.JPG (67 KB)
Re: Will a cooling fan solve this issue?
April 14, 2013 11:36AM
Yes a cooling fan definitely helps with overhangs. See the difference between the windward and the leeward sides of this print: [2.bp.blogspot.com].
There is something else wrong with the print though, even before the overhang starts. It seems to have gaps in the outline.
April 14, 2013 12:53PM
The gaps are going to be inconsistent filament feeding, either because the filament is slipping on the hobbed bolt, or because you are printing slightly too cold.
April 17, 2013 03:05PM
I had similar trouble and the gaps but got then fixed by adjusting the steppermotor driver for the extruder a bit.
Edited 1 time(s). Last edit at 04/18/2013 02:02PM by darneg.
