Extruder cooling/layer smash April 15, 2013 04:13PM |
Admin Registered: 12 years ago Posts: 3,096 |
Re: Extruder cooling/layer smash April 15, 2013 04:40PM |
Re: Extruder cooling/layer smash April 16, 2013 01:54AM |
Re: Extruder cooling/layer smash April 16, 2013 05:24AM |
Re: Extruder cooling/layer smash April 16, 2013 01:13PM |
Re: Extruder cooling/layer smash April 16, 2013 03:54PM |
Re: Extruder cooling/layer smash April 16, 2013 11:46PM |
Re: Extruder cooling/layer smash April 17, 2013 04:11AM |
Thanks for mentioning it though.|
Re: Extruder cooling/layer smash April 21, 2013 03:14PM |
Okay, I have solved most things, but now all of a sudden sometimes, I have the idea the Z-axis skips a few steps? It doesnt get hot, it doesn't really have much friction in going up or down, but just randomly it sometimes doesnt move up when it should and this means it prints two layers on the same height which means that small gaps are immediately closed up and the next layer it moves up, so it's actually 3 layers squashed in the area for 2 layers. It takes 2 more layers for the squashed layers to normalise again.
I don't know why this is happening, the motors don't shut off, and I can just manually move the Z-axis as much as I want.
I bought a digital caliper to calibrate my axes and I am sure that my axes are correctly configured. I have the values all with maximum of 5 decimals.
Should I maybe set even less decimals in my firmware, or can it be that there is a different problem?
I have locked my hotend completely, no movement up nor down, left nor right. The heatbed doesn't just jump up or anything, I have been constantly measuring and I sometimes can print nicely and sometimes randomly it just messes up a few layers.
This is driving me nuts.
Re: Extruder cooling/layer smash April 27, 2013 01:27PM |
Re: Extruder cooling/layer smash April 27, 2013 01:58PM |
Re: Extruder cooling/layer smash April 27, 2013 07:47PM |
Re: Extruder cooling/layer smash April 28, 2013 06:02PM |
Re: Extruder cooling/layer smash April 28, 2013 11:53PM |
Re: Extruder cooling/layer smash April 29, 2013 05:02AM |
I have switched out the stepper drivers, checked the connectors, everything, I have wiggled the connector while giving the motors a 'move 100mm up' command to see if it would lose connection sometimes...|
Re: Extruder cooling/layer smash April 29, 2013 10:31AM |
Re: Extruder cooling/layer smash April 29, 2013 12:45PM |
Re: Extruder cooling/layer smash April 30, 2013 06:59AM |
Re: Extruder cooling/layer smash April 30, 2013 11:27PM |
Re: Extruder cooling/layer smash May 01, 2013 05:52AM |
Re: Extruder cooling/layer smash May 01, 2013 06:33PM |
Re: Extruder cooling/layer smash May 01, 2013 07:25PM |
Re: Extruder cooling/layer smash May 02, 2013 06:25PM |
Re: Extruder cooling/layer smash May 03, 2013 02:04PM |
(And I hope I don't Jinx it now..).
Re: Extruder cooling/layer smash May 06, 2013 01:29PM |
Re: Extruder cooling/layer smash May 06, 2013 04:20PM |
