Printing Speeds won't go up April 19, 2013 12:48PM |
Admin Registered: 10 years ago Posts: 3,096 |
Re: Printing Speeds won't go up April 20, 2013 05:52AM |
Re: Printing Speeds won't go up April 20, 2013 09:30PM |
Re: Printing Speeds won't go up April 21, 2013 06:26AM |
Re: Printing Speeds won't go up June 20, 2013 03:20PM |
Re: Printing Speeds won't go up November 28, 2016 09:06PM |
CapnBry
BrentB Wrote:
> If you have cooling enabled in Slic3r and the
> layer area is within the limits set in Slic3r, the
> printer will indeed be slowed. Any speed increases
> you make won't be seen.
Holy smokes thank you! I've been calibrating my printer and printing a ton of small test objects but none of the speed settings seemed to be doing anything. You just reduced my print time for a tiny block from 40 minutes down to just over 5. 120 layers at a minimum 30 seconds each would be 60 minutes! Thank goodness I was hitting the lower speed limit. I'm sure I'll use this setting later but trying to just knock out a quick block was really killing me.
