print quality drops mid run... please help
Posted by fxmech
May 27, 2013 11:47AM
I am having a weird issue that as a newby am having trouble resolving.
I am printing multiple parts on an 200x200mm hotbed.
PLA rated 190-220C: running at 210C
hotbed set to 75C
; layer_height = 0.15
; perimeters = 4
; top_solid_layers = 4
; bottom_solid_layers = 4
; fill_density = .35
; perimeter_speed = 40
; infill_speed = 120
; travel_speed = 150
; nozzle_diameter = 0.35
; filament_diameter = 3.
; extrusion_multiplier = 1
; perimeters extrusion width = 0.40mm
; infill extrusion width = 0.67mm
; solid infill extrusion width = 0.59mm
; top infill extrusion width = 0.59mm
; support material extrusion width = 0.59mm
; first layer extrusion width = 0.35mm
I dropped the flowrate to 95%
The issue is that all of my parts start printing very nicely but in the thin wall areas that start about 1/8" elevation I get a large amounts of PLA "boogers" on every layer and every part on the bed.
I don't know if it could be a setting issue or some sort of clog in the tip.
Hope you guys can help me with some troubleshooting advice.
Im using a bukobot printer which has given me some extremely high quality parts in the past.
I also notice that in most cases the "boogers" only occur on one side of the part usually the side on the +Y or -Y end of the bed
Here is a picture of two identical parts grown on the same run with identical flaws...only on one side....
open | download - IMG_1572[1].jpg (37.2 KB)
Re: print quality drops mid run... please help
May 27, 2013 01:21PM
hi
might be 1 of 2 things in my opinion . Too hot and poor quality PLA . Ive had batches of PLA where similar issues occured ..almost like its boiling out the moisture . Not really supported by the fact its only on one side thou.
I would certainly try lower the temp
Your print speeds seem very high as well . Just to test try a test object at 30mm/s travel and see how it goes
Good luck
May 27, 2013 01:35PM
May 27, 2013 02:39PM
I think you're not looking correctly at your images. To me it seems the entire print isn't perfect, instead of starting to degrade during print. I think there is a different problem like calibration. Maybe retraction, maybe bad filament (variable width) or maybe wrong E-steps/mm.
But given you have printed nicely before, maybe it's a different filament, a dirty extruder, or just a setting specific to this print that needs to be changed.
