wavy edges
Posted by aterhune1984
wavy edges
June 03, 2013 11:04AM
Hey all,
Trying to tune my printer and getting very close, I'm seeing a strange phenomenon though.
This is a picture of the side of a frog, as you can see the edges are waving, there are like 5 layers at the same point on the edge then it juts inward instead of being a smooth taper.
I am printing at 195C black PLA at the default speeds of slic3r.
Any thoughts on how to fix this?
Thanks!
open | download - 20130531_112220.jpg (558.4 KB)
Re: wavy edges
June 03, 2013 03:29PM
Look for 'wobble' there are many posts with responses to your problem. :-)
Re: wavy edges
June 03, 2013 07:31PM
i would guess at over constrained z threaded rod, what sort of printer, got a pic?
Re: wavy edges
June 04, 2013 06:16AM
The threaded rods in the local metal shop were all bent, I managed to find one that was almost perfectly straight and it already took out all the wobble for me.
I also added an aluminum connector with a springy-cut middle part, this stabilizes the rod a bit more and catches some of the wobble.
Those are two things you can try.
Some people say it helps to 'fixate' the threaded rod on the free end, but in my experience, if you don't have a straight rod to begin with, it only makes the wobble worse and puts even more stress on your X-ends.
Re: wavy edges
June 07, 2013 10:52PM
It looks to me like maybe a polygon model or slicer issue? First, how smooth is the original solid model (stl)? The reason I say that is that going around the frog I see large polygon faces in other directions. The printer can only print as smooth as the model is defined. Are the faces/steps in the Z direction in the model? The perimeters in X and Y control the outlines of each layer which is what you are seeing- like successive layers using the same perimeter for several layers, then the next layer is different (in the X-Y plane).
Re: wavy edges
June 14, 2013 05:46AM
Make sure you oil the Z rods liberally the problem is often in the anti backlash system ... (nuts and springs ) in the Z axis carriages
