Hello,
I am trying to print a model of a building and am having trouble figuring out how to add supports in between the floors and underneath ramps. I use Slic3r and it seems that all I get is a big block of plastic and cannot figure out what is the model and what is support? Any ideas or settings that you may have would be appreciated. Thanks
Printer Info:
Model: AW3D XL
Build envelope WxDxH: 12″X 8″X 7″ (300 mm x 200 mm x 178 mm)
Nozzle diameter (mm): .5 (.35 is optional)
Layer thickness (mm): .25 (.1 to .4 possible)
Max Speed (mm/s): Perimeter 150 mm/s, Travel 400 mm/s
Positioning precision: .04 mm
Input format: GCode
Software: Marlin Firmware, Pronterface/Repetier Host Print Controller, Slic3r GCode generator
