Loops on Edges
Posted by lutjanus
Loops on Edges
August 15, 2013 12:56PM
Hi everyone,
I'm using an ORCA V.042 with a wade extruder, 1,75mm PLA and 0.35 nozzle. The printing quality with the newest version of repetier-host (slicing with slic3r) is ok, but on the edges (right angle) a loop is created, like there's too much material or mechanical cause when changing direction. I checked the hardware, everything seems ok. Does somebody know what to to or what causes this phenomenon?
This is how it looks like:
The left part was sliced with slic3r, the right part was sliced with skeinforge (which seems to work quite better).
Thanks for your help!
Lutjanus
Edited 3 time(s). Last edit at 08/16/2013 01:01PM by lutjanus.
Re: Loops on Edges
August 23, 2013 11:28PM
Blobs on one corner is usually due to the Z-axis move with the nozzle over the part at that location. The extra plastic due to ooze while the z moves is enough to give a little blob and usually the z moves with the print head at the same point on each layer. Skeinforge has some oozebane settings if you want to try enabling that.
